Do the Q128C and Q128H use same gears for 36V 328RPM builds?
pullin-gs
Q128C and Q128H motors use the same gears for 36V 328RPM?
I'm running my Q128C (rated for 500W) at 600watts and does not even break a sweat (or so it seems).
Motor does not even get warm after a few miles at full throttle.
If it uses the same gears as the 800W Q128H, can I safely assume that gear failure would not be of concern?
http://www.topbikekit.com/ebike-gear-set-for-q128cst-akm128cst-48v-500w-gear-set-for-replacement-p-735.html
It’s not much help, but I ran a q128c at 20a for over 300 Miles and it never once got warm.
I did mostly use PAS but was sometimes using the throttle and hitting 1000w to it.
I burned my Q128C at 48volt 18a up a long steep hil where I have used Bafang bpm and Bafang swx02 and Mxus xf18 without any problems.I also have used a Q128H (same no load speed) at 48v 18a up a steeper/longer hil with no problems
Thanks 1boris.
"burned" as in fried the motor's windings? Or did the gears give out?
