stefanhack
- Joined
- Sep 14, 2018
- Messages
- 4
help for s06s controller programmed perfectly but the speed does not change ... about 30km. I do not understand if it is a limit of the tdcm a2b engine, the battery is 37 volts 14 ah. then where should I connect the torque sensor? in the pas or throttle connector? thank you
