Hello
I need help to programming my controller bike.
I use a Fatbike 26x4.0 with a rear hub bafang 48v500wand a 10.4ah battery.
I use a controller KT 48v14A and and other 48v22A with a lcd kt-lcd8.
I can use my throttle and my pas.
I have 2issues:
-When the battery loose power (less 50%) and when I want to use too much power like pas 5 or throttle, the motor shut down.
-Other issue, the monitoring speed is not correct. start to display few second after start engin and when I do not use pas down to 0kmh.
My controller setting is:
P1 = 100 (Motor Characteristic Parameter Setting Mode, 1 - 255)
P2 = 1 (Wheel Speed Pulse Signal Setting Mode, 0 - 6)
P3 = 1 (Power Assist Control Mode, 0 or 1)
P4 = 0 (Handlebar Startup Mode, 0 or 1)
P5 = 15 (Power Monitoring Mode, 0 - 40)
C1 = 5 (Power Assist Sensor and Parameter Select Mode, 00 - 07)
C2 = 0 (Motor Phase Classification Coding Mode, 0 - 7, 0:sin wave)
C3 = 1 (Power Assist Ratio Gear Initialization Mode, 0 - 8 ) (C3=6 WARNING! Bike starts running forward on it’s own at power up!)
C4 = 3 (Handlebar Function Setting Mode, 0 - 4)
C5 = 4(try 1 to 10) (Controller Maximum Current Adjustment Mode, 00 - 10)
C6 = 1 (Backlight Brightness Adjustment Mode, 1 - 5)
C7 = 1 (Cruise Function Setting Mode, 0 or 1)
C8 = 0 (Motor Operating Temperature Display Mode, 0 or 1)
C9 = 0 (Startup Password Setting Mode, 0 or 1)
C10 = n (Automatically Restore Default Setting Mode, n or y)
C11 = 0 (Attribute Selection Mode, 0 - 2)
C12 = 4(try 1 to 7) (Controller Minimum Voltage Adjustment Mode, 0 - 7)
C13 = 0 (Brake energy recovery - recuperation - only works with the corresponding controller, 0 - 5)
C14 = 2(try 1 to 3) (Coordination of support levels, 1 - 3, 2 = standard)
thank you
I have 2issues:
thank you
