SunPoweredWorldTour
- Joined
- Sep 9, 2017
- Messages
- 40
I have 2 motors on my bike
A Bafang with it's own controller and an Ezee with a Cycle Analyst.
My problem is related to eBike signal.
On the Bafang. I have a lot of difficulty to find a position to place the magnet in a way that it will get further from the detector when I press the Brake lever.
i tested the wire and I find that when the magnet is there, all contact are open and the motor run
When the magnet get further, a contact close and motor is cut
On my other motor with cycle analyst, my eBrake is open when the motor run and when I pressed on the lever, the circuit close and the motor is cut. Which seem to be the same
Could I use the 5 volt from my ebrake on my Ezee and sent it to the Bafang
I saw this discussion but I don't understand the answer.
https://endless-sphere.com/forums/viewtopic.php?f=2&t=87008&p=1271802&hilit=Bafang+brake+cycle+analyst#p1271802
Thank you
Thank you
