Paco007
Hi all,
I'm new to lithium battery technology. I bought a used V-Power 48v 20ah 13s lithium battery. The battery charger is going to green although the battery is only getting up to 48.9 Volts. I checked the 13 wires going into the bms and calculated the differences in volts. It looks like the 5th cell group is causing the bms to shutdown the charge and preventing an overcharge. I would like to know the best process to either discharge the 5th cell or possibly replace the bms (if that is causing the issue)? I tried leaving the charger plugged into the battery overnight but the battery voltage still only gets to 48.9 volts.
3.5
3.7
3.6
3.7
4.2
3.9
3.5
3.6
3.9
3.9
3.4
3.5
3.4
3.5
3.7
3.6
3.7
4.2
3.9
3.5
3.6
3.9
3.9
3.4
3.5
3.4
