Hey guys. What do you guys use for a power/watt meter for a 72V ebike. When I had my 36V system, I used the RC 60V power meter. It was really easy to install since you just wire it as you would a connector. But, I am looking at the ones for the above 60V, and they require a shunt with like lead wires to the power meter. This seems really confusing to me and I am hesitant to do it since I am sure I am gonna fook something up disasteriously.
Is there a more simple power/watt meter like the RC onces where I just connect negative and positive for a 72V system. What would happen if I run 72V through the 60V RC power meter? I don't mind if the voltage doesnt read I just need the amps and amp-hours.
