crossbreak
OLD Topic Name: Custom RV120 for ebike use: group order Rv120-ES edition
If you look for the CB120 go to page 6 https://endless-sphere.com/forums/viewtopic.php?f=28&t=80516&p=1277160#p1277160
The RV120pro looks like a good motor. better than RV160short and RV120short (low Km² motor constant and way too high no load loss). Still, for me the RV120pro design looks not optimal for ebike use, as it does not fit between the cranks, a lot of length is wasted to the complicated bearing design. So I'd like to get rid of the shaft and make things much more simple. We dont need it. Hub drives show us how. This saves quite some space where we need it: length. I know, hubbies run low RPM. This motor runs faster. Unbalance can be an issue. That may be a point to discuss... i hope the bearing config may work at that 1000 to 3000 rpm where it performs best. what do you think?
i also hope that bearing loss can be reduced due the smaller bearing dia of the rear bearing.
in this drawing, i not only got rid of the shaft and replaced it with an axle...i also got rid of those nuts for fastening. I replaced them with bolts so over all length can be reduced further. Another point to discuss. Countersunk screws have drawbacks though...still, multiple Allen bolts are shorter than a nut though
the last drawing of the RV120 is from revolt http://www.revolt.org.il/rv-120/rv-120pro-2/
some spces:
bearings: 16005 (25x47x8mm) and 6003 (17x35x10mm)
Sprocket: custom 13T type 410 (BMX chain), 32mm BCD, 6 bolts M5x10
Phase wires: 5mm dia, shall fit AWG8 with insulation, max bend radius is 6mm
left side mount: single M8 bolt
right side mount: 4x M5 bolts, 18mm BCD
some spces:
