I'm working with Electric God to see what kind of max power we can get out of the Big Block. Even though the Big Block runs very cool compared to most other motors we decided to port the end cases and give it a better shaft driven fan than the factory provides.
Here's a 3D print of the new axial fan that E-G and I designed:
It fits the motor shaft perfectly:
Cool air gets drawn in through the output shaft side due to negative pressure created by the axial fan on the other end. According to cooling experts (Matt) axial fans are the most efficient way to move air through a motor.
This is the fan that that the factory provides. It's meant to pull air in through the end grate on a plastic fan shroud and then push it over the cooling fins on the center case. We're trying to move air through the core of the motor so we flipped the fan to put the air dam on the outside. While we were at it we gave it larger vanes to move more air.
The fan ships out to E-G today. I'm sure you'll be seeing photos of the assembled motor very soon. He's also experimenting with delta/wye switching on the Big Block to see if we can have a two speed electronic "transmission" through one fixed gear ratio. The Big Block makes more torque in delta but should make 70% more rpm in wye. E-G was making nearly 60 mph in Delta so I hope he'll be okay with 70% more revs. It's hard to find good technicians!
