Bafang MAX drive (250W) readout
maz0n1   1 µW
Re: Bafang MAX drive (250W) readout
Post by maz0n1 » Jun 18 2018 2:06am
I tried that cable "hiekkis" mentioned to connect thumb throttle to max drive. No dice. Connector is different to controllers end.
Next i will try bafang ultra drive eb-bus cable.
I have a 48v version max drive 350w with 17A controller. Runs great 100% keep current ja current decay 8.
Fat bike frame slowers down top speeds, but tops out at ~42km/h with clown pedalin on flat :)
dannyb0uy   1 µW
Post by dannyb0uy » Oct 31 2018 4:31am
Any luck with the thumb throttle?
brikmange   1 µW
Post by brikmange » Nov 22 2018 8:02am
Hi! New here, and been reading this thread a lot. I've got an Evobike mid engine 8 geared bike. Thinking about maybe reprogramming my 250w engine to make it 350w. Anyone got readouts of factory setting for a 36v 350W max drive? @Elenhinan, where did you find info about that the sw06 controller is good for 350w?
Well, first I need to check if I can access the connection port easily, and then find a programming cable. If so, let's see. :)
