New "Lingbei MM28.250 torque sensor mid drive"
ScooterMan101   1 MW
Re: New "Lingbei MM28.250 torque sensor mid drive"
Post by ScooterMan101 » Oct 18 2018 9:24am
I must use a throttle,
Can you make a switch to put on the handlebar , so that you can have both the temperature sensor, and , the throttle connected to the controller then switch back between each ?
Note that most everyone who does DIY e-bike conversion on their bike would know when they are pushing the limits of their motor so they can just let off the throttle for a few seconds , switch over to the temp sensor then back again.
casainho wrote:
Oct 18 2018 7:54am
I have to install motor temperature sensor on my TSDZ2 motors: https://github.com/OpenSource-EBike-fir ... ure-sensor
My first conversion ...
https://endless-sphere.com/forums/viewt ... 1#p1077497
It's 2018 already, lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
casainho   100 MW
Post by casainho » Oct 18 2018 9:31am
ScooterMan101 wrote:
Oct 18 2018 9:24am
casainho wrote:
Oct 18 2018 7:54am
It is not possible.
Sometimes the rider is someone like my son or girlfriend that does not know nothing about so they would burn the motor if the system do not protect.
Developer of the Flexible OpenSource firmware for EBike motor controllers (TSDZ2 and KT) and LCDs (KT-LCD3 and Bafang 850C color LCD).
ScooterMan101   1 MW
Post by ScooterMan101 » Oct 18 2018 9:53am
Not Possible ??
or
Just not desirable for you because of your Son and Girlfriend .
stinkycats   1 mW
Post by stinkycats » Oct 18 2018 10:41am
wheelyphased wrote:
Oct 18 2018 4:08am
There is no other sensor either on, or adjacent the clutched gear. Compared to kisazul’s images, there is no difference between his earlier motor and my latest V2 motor. So, if the speculation in this thread that a torque signal is derived from the change in phase between these 2 sensors under shaft torsion, it must all happen in the shaft between these 2 rings, right?
Can you find out for certain how many poles are on one ring? Count how many pulses you get from one hall sensor in one full rotation. This will be important for figuring out if we can do fine or course torque measurement.
wheelyphased wrote:
Oct 18 2018 4:08am
That’s a maximum peripheral deflection between the rings of 0.024mm or just over 1 thou.
Assuming a cadence of 100rpm, that will be a maximum of 40ms (0.024*100 / 60) of sampling time. If we sample at a relatively low 1KHz, that would give us a 40-1 ratio between torque maximum and minimum levels -- plenty of room to provide multi-level torque assistance.
stancecoke   10 kW
Post by stancecoke » Oct 21 2018 12:30pm
wheelyphased wrote:
Oct 18 2018 4:08am
That’s all. There is no other sensor either on, or adjacent the clutched gear. Compared to kisazul’s images, there is no difference between his earlier motor and my latest V2 motor. So, if the speculation in this thread that a torque signal is derived from the change in phase between these 2 sensors under shaft torsion, it must all happen in the shaft between these 2 rings, right?
I can't believe, that you'll get a proper torque signal from this little deflection. The deflection even would only appear from the torque of the pedal that’s opposite the freewheel clutch. I think there must be three coaxial parts:
1. the shaft itself
2. a tube, geared with the shaft somewhere on middle or slightly the right in the picture, with the freewheel clutch and the outer magnet ring on the left
3. a second tube, fixed to the shaft on the right with the inner magnet ring on it.
In this way you would get a bigger deflection and sensitivity from both crancks.
regards
stancecoke
ScooterMan101   1 MW
Post by ScooterMan101 » Oct 27 2018 8:37am
Can someone here make a list of vendors...
that sell the newer version of this Lingbi that have the 12 mosfets in the controller and can run on 22 amps and 52 volt ( 14s ) battery pack .
How can we tell that or if , they sell the latest 12 fet model ?
( markings on case and/or after what serial number , etc )
Has Lingbi corrected the lack of enough grease in the motor at this time?
Or do we have to buy grease and open up the motor to add enough as a buyer ?
English Speaking Vendors that will communicate in English to a buyer pre and post purchase
are most desirable.
stinkycats   1 mW
Post by stinkycats » Oct 27 2018 11:57am
Oct 27 2018 8:37am
Can someone here make a list of vendors...that sell the newer version of this Lingbi that have the 12 mosfets in the controller and can run on 22 amps and 52 volt ( 14s ) battery pack.
According to Ling Bei, there is only one version -- it has 9 MOSFETs. The latest revision of the motor includes a connection for a programming cable (sold separately) and the ability to handle 52V with a maximum of 750W. I don't know if they've changed the grease, but they are very responsive to emails, so you can ask them yourself.
ScooterMan101   1 MW
Post by ScooterMan101 » Oct 28 2018 10:01am
I am not finding Lingbei's webpage on a google search.
Only a Alixxxxxx link, but who knows who is selling any product on that large site from what I have heard and seen myself there are many sellers of any product there on Alixxxxxxx . that are just middlemen/sellers who do not really know much about products they sell .
Anyone who sells the newest version let us know what is going on.
So far it looks like one would have to order the C 600 display in order to get a throttle.
Are there other display's now available for this like a color one?
What kinds of different throttles are available ? It is it easy to just solder in the Red and Black and other color wire from any throttle to make it work with this motor ?
stinkycats   1 mW
Post by stinkycats » Oct 28 2018 3:35pm
Oct 28 2018 10:01am
http://www.lingbeimotor.com/
Select "English" from the round, grey button at the top with "CN" on it.
Also, the current list of sellers: viewtopic.php?f=28&t=94220&start=200#p1415336
fantasy2   10 W
Post by fantasy2 » Nov 02 2018 11:12am
Has anyone heard if the manufacturer is going to improve their firmware once again?
maitilupas   100 W
Post by maitilupas » Nov 03 2018 12:37pm
I have just purchased one of these motors, the sensation of cycling with this motor is outstanding.
I do think I have one of the last firmwares but i still think its really unbalanced between 1 , 2 , 3 4,5 and power and eco and std modes.
is there any way to advance program this motor without taking the motor apart?
if not ,can you Fantasy help me with this? i really need more sensing torque in the first speeds , at least till 3.
I live near Rotterdam, I can travel any place and can pay you hour rate if you feel like helping me out
thanks
Jose
maitilupas   100 W
Post by maitilupas » Nov 08 2018 11:10am
do i have an old version ?
i dont feel almost difference in pas 1,2,3,4,5 and 6levels as well in the eco std and power modes, almost not noticeable difference .
also , any improvment i can make for a better torque arm? only a small torque arm in one side is a bit alarmy
maitilupas   100 W
Post by maitilupas » Nov 09 2018 2:27pm
well that was just the display version , ihave the 2.0 motor but i find it stupid the way they programed the pas levels and the lack of good testing , i hope soon we have a way to program this controller a bit better than this shit.
maitilupas   100 W
Post by maitilupas » Nov 09 2018 2:30pm
wheelyphased was absolutely right
wheelyphased   1 mW
Post by wheelyphased » Nov 09 2018 11:09pm
maitilupas, you can check the motor data info underneath to confirm V2.0. It should look like this:
Lingbei do say these motors are programmable through the green 5-pin display plug just like the Bafangs (no surprises there, then). I have a 2 minute video from Linda at Lingbei showing how to connect via a special box and start the “TREEDE” software.
I’ve lost interest in the motor because it clearly can’t sense pedal torque like my TSDZ2 despite what you read on here and you’ve discovered for yourself how this programming works. Set the assist really high then make it drop off to a low current with cadence so when you encounter a hill without downshifting, the cadence drops & the current ramps up. My BBSHD with the better firmwares (em3EV and Karl’s magic sauce) does something similar and that’s how I use it. However the HD has 30A so you can have a progressive PAS from a base level.
With some improved programming, this will be a nice little BBS02 alternative but it will take the clever people on here to do it, just like the casainho TSDZ2 and the various Bafang flavors. I'm just left wondering if, given all the similarities to Bafang, we can use its firmware too. I'm not putting my hand up for that, it will end in tears and burned controllers.
wheelyphased   1 mW
Post by wheelyphased » Nov 09 2018 11:15pm
In the interest of science, anyone else prepared to rip into this motor will discover that to get the crankshaft out, you have to pretty much destroy the non-drive side oil seal. My oil seal man sent me too many so I have a few spare 16x26x7 I can post. PM me if you need.
Marty
StevenLee   1 µW
Post by StevenLee » Dec 03 2018 5:36am
where did you buy it, what is the price?
1boris   1 W
Post by 1boris » Jan 20 2019 4:47am
Is this lingbei motor stronger than the bafang bbs?
The motor (stator and rotor)seems wider than bafang,does it give 100%power on pedals only or do you need to use throttle to get 100% power like with the bafang bbs
Anybody tried the 250w and know how powerful it is?
maitilupas   100 W
Post by maitilupas » Jan 20 2019 6:27am
you get 100% on pedal in the current configuration actualy the throtle gives you a bit less % than the pedal in full speed and torque.
the motor 350w is very powerfull think it puls like 500 or 600w undeload , i do think 250w versions dont exist.
fantasy2   10 W
Post by fantasy2 » Jan 20 2019 6:29am
Has there been another firmware release that works better?
maitilupas   100 W
Post by maitilupas » Jan 20 2019 9:58am
i dont know , and how do you update it?
