You need to use your device's software and it should work.jodiug wrote: ↑Nov 12 2020 11:37amI have this CAN analyzer: https://www.antratek.nl/usb-can-analyzerCiDi wrote: ↑Nov 03 2020 4:08amTo configure the Bafang M500 / M600 motor without using the BESST programmer, you can use this interface.
Link interface USB to CAN on Amazon:
https://www.amazon.co.uk/USB-Converter- ... 709&sr=8-2
Link cables Bafang HMI M500/M600 on e-bike-technologies:
https://www.e-bike-technologies.de/inde ... 5-f-detail
Below are the software and the instructions for configuration and use.
After wiring the white/green/black cable I connected it to my bike and turned on the battery. I installed the driver on my PC. The InnoMaker software is not showing any Device Index, so I might have to order the other USB interface. Should the device index show up automatically when the USB is plugged in and the bike is turned on?
Search here:
https://github.com/SeeedDocument/USB-CA ... /res/V7.20
Let me know if it works.
It could be better than the innomaker interface.
