Dengfu M09 Endruo/Freeride build log
Show off your Ebike creation here.
Simonten   1 W
Re: Dengfu M09 Endruo/Freeride build log
Post by Simonten » Dec 16 2019 4:54pm
Firstly Kepler, the bike looks fantastic.
How do you think a 170-180mm front shock with 27.5+ front wheel and a 1.5 Degree Angle Headset adjustment to make the head angle 65 degrees would go on this frame. I am in New Zealand so luna will not ship to me.
Kepler   1.21 GW
1.21 GW
Post by Kepler » Dec 16 2019 5:17pm
I think that would be no problems at all. My set up with a 160mm travel 29er fork with a 29er wheel would be very similar in total length to what you are proposing.
Current Rides
Lightest true ebike on the planet: ON ROAD viewtopic.php?f=6&t=74269
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
Simonten   1 W
Post by Simonten » Dec 17 2019 4:37am
Thanks Keplar
The 150mm rear shock will that be ok with 180mm of front fork travel? In my reading it says that its good to keep the front rear travel with in 20mm. Any thoughts?
Kepler   1.21 GW
1.21 GW
Post by Kepler » Dec 17 2019 5:13pm
Yes rule of thumb is no more more then 20mm. So stick with a 170mm fork if want to play safe. However I still cant see an issue with the 180mm travel fork as I know that total front end height works well on the bike. Only thing is an imbalance of plushness between the back and front. Nothing that an extra 10psi in the 180mm fork wont fix or maybe the addition of an extra volume spacer.
Current Rides
artyy   10 mW
Post by artyy » Apr 12 2020 2:00am
Hi,
Finally, I got to build my bike based on Dengfu E 09 frame with Bafang G521 motor. I made my own battery as you but 13s5p. I'd be happy if you would tell me how you connected a throttle. As I can figure out it needs 5v supply from canbus but three is no canbus in my DIY battery. I think of using DC/DC step down inverter 54v/5v like on the pic but I am afraid of frying controller or something. I'd be very thankfull for your advice.
battery throttle.jpg (150.55 KiB) Viewed 1681 times
MDW195   1 µW
Post by MDW195 » Jul 14 2020 1:05pm
Is this thread no longer active? Seems odd, seeing as there is so much good information being exchanged here.
Anyway, I just purchased, and am waiting on delivery of, the X1.
On the luna website, it states that the bike has "* 6" of travel front and 7.8" rear"...so I am wondering what is truly the case? Does the bike have 150mm front and rear, or does it have 150mm front, and 198mm rear?
Is it possible that the frame might support 198mm of rear travel, but that travel is restricted by the stroke of the Monarch shock? That still seems shady to report as 7.8" rear travel.
I am only asking out of curiousity...I plan to ride the bike as is for a while before making any changes such as slackening the bike via longer travel forks, or combination of forks and 29er front wheel (mullet).
Anyway, thoughts on this are appreciated...
Mike
theflyinglandwalrus   1 mW
Post by theflyinglandwalrus » Jul 23 2020 8:09pm
artyy wrote:
Apr 12 2020 2:00am
Hi,
Throttle is connected to the 2 prong main wire that connects directly to the motor (the other wire goes to the display). No splicing needed as everything is plug and play. Similary setup to you, Dengfu E-09 with the M600 but with their in house battery.
Rix   100 GW
Post by Rix » Jul 27 2020 10:05pm
Kepler wrote:
Oct 13 2019 8:33pm
Here is a quick video (nothing too exciting) of the bike setup with with 27.5+ 2.8" rear and 29er 2.6" front on a 29er ebike specific Fox 36 fork. Really happy with the way the bike rides in this configuration. The level of noise is pretty accurate to what you are really hearing on the bike. Also added a charge plug that doubles as range extender plug and fitted the thumb throttle just to see how it feels.
Damn Kep, you got this machine built and dialed in. Beautiful job. BTW, our mutual friend asked me to email this link to him, so I did.
Kepler   1.21 GW
1.21 GW
Post by Kepler » Aug 05 2020 2:48am
Thanks Rix. Its a nice bike and a heap of fun to ride. Must catch up with JK after we get out of lock down.
Current Rides
Rix   100 GW
Post by Rix » Aug 07 2020 11:17am
Kepler wrote:
Aug 05 2020 2:48am
I know he would like that.
Tom   1 kW
Post by Tom » Aug 08 2020 5:31pm
Kepler, just curious if you notice is a distinct difference in torque sensing on your stock M600 below and above 50% PAS. On my Luna X1 (non-ludi) I find PAS 1 and 2 (of 5) requires constant pressure on the pedals or assist cuts out. Not very smooth or pleasant to ride on flats. PAS 3+ is much smoother. Do you notice the same? I'm wondering if perhaps this is something specfic to the Luna tuning. I suspect Luna had to dial back PAS 1 and 2 for the Ludi controller and naively applied the same tuning to the stock M600. Or perhaps I got the Ludi tuning by mistake. I posted in the main M600 thread but didn't get much feedback.
Kepler   1.21 GW
1.21 GW
Post by Kepler » Aug 09 2020 2:41am
What I have found is that it is makes a difference if you turn the bike on and let it sit without moving the bike or touching the pedals. If you do this the PAS is much smoother especially in low power settings and light pedaling effort.
What I have noticed is if you just jump on the bike, start pedaling, and turn the bike on while you are are going, the PAS is much more choppy. I presume the drive must calibrate the PAS each time you turn the bike on.
I thought this was my imagination for a while but the above method definitely makes a difference on my bike anyway.
Would be interesting if anyone notices the same.
Current Rides
Desmodromic   1 µW
Post by Desmodromic » Aug 11 2020 8:11am
Kepler wrote:
Aug 09 2020 2:41am
This is a really interesting thought and makes sense to me. If it's true, I wonder what the initialization time is? Do you need to wait for a certain time before you see this difference? Would explain some of the weird behavior others have reported with this motor setup.
henrip   1 µW
Post by henrip » Aug 30 2020 2:45am
How did you guys make the order and payment to Dengfu? I've mailed with Melody and she has sent me an invoice with part list (E09 frame, M600, headset, rear axle and battery case). Part I'm worried about is that she wants me to arrange payment to paypal account tony@greatkeen.com.cn. I can't find any mention about this account past 2012.
Is this valid account for Dengfu?
Thanks!
Kepler   1.21 GW
1.21 GW
Post by Kepler » Aug 30 2020 3:21am
Fair enough to be cautious. This is the same PayPal address that i did all my transactions with when i built my bike.
Current Rides
Rix   100 GW
Post by Rix » Aug 31 2020 11:28am
henrip wrote:
Aug 30 2020 2:45am
Thanks!
Adding to what Kepler said, all of my transaction with China based business have been done utilizing paypal. Ironically, I have never been burned.
fruitygreen   1 µW
Post by fruitygreen » Sep 03 2020 12:36am
i too am experiencing the same from Dengfu. Melody seems helpful, but I am uneasy they way they do transactions. I have heard others had success but still.
Did you know there are 2 completely different website.
Dengfubike.com (with paypal builtin)
And
Dengfubikes.com (they send you a paypal payment request). How bizarre.
Anyways I was about to pay for my E10 motor and M600 to
TONY@GREATKEEN.COM.CN
as per Paypal request.
Havent done yet, I am waiting for someone with true experience this way to give me confidence.
After all its a $2300 risk.
Waynemarlow   10 kW
Post by Waynemarlow » Sep 03 2020 9:29am
Yes my E10 has just arrived via paying at the Tony paypal address. If you pay it as a friend you not have to pay the surcharge but you run the risk of it going missing etc in the post. I paid as a commercial invoice which gives some protection but had to pay the additional surcharge of I think 2%. I did question that but apparently its company policy.
The good thing is the frame is of very high quality and the Gloss coat I had ordered is of very good quality. Sadly the Gloss order took a bit longer than expected by a few weeks but Melody did explain this on order.
fruitygreen   1 µW
Post by fruitygreen » Sep 03 2020 3:03pm
Thanks,
I was quoted with 4٪ to Paypal.
derekjames   1 µW
Post by derekjames » Sep 13 2020 4:13am
Hello all - this is my first post on endless-sphere so please be gentle.
@Kepler, fantastic build and many thanks for this detailed outline of your experience with DengFu build which is a great resource for newbies. :bigthumb:
I have had a look at @waynebergman's thread and he also did a great outline. :bigthumb:
Both your posts have motivated me with the right nudge to embark on my first custom build which will be based on the E10 framekit.
Hence this is a thank you and introduction post only :)
derekjames   1 µW
Post by derekjames » Sep 13 2020 4:21am
Waynemarlow wrote:
Sep 03 2020 9:29am
Nice to here more successful orders as i am struggling to get my order in with a further delay on the M600 motor being out of stock.
Do you have pictures of the gloss finish? There seem to only be the matt finish pictures online. Also, i see you are in the UK which i also am, can you share your shipping experience - costs (frame & shipping), delivery schedules, taxes (if any)...etc. Did you order the battery kit too? I was quoted 4.2%, looks as though there are inconsistencies in dealing with Dengfu.
bbbbking   1 mW
Post by bbbbking » Sep 18 2020 9:56pm
dengfu insist its normal, will u accept it?ImageImageImageImage
Sent from my HMA-L29 using Tapatalk
Kepler   1.21 GW
1.21 GW
Post by Kepler » Sep 19 2020 1:35am
They must he joking. That is not acceptable. Its hard to tell from the pictures but make sure its just not release agent that hasn't been cleaned off.
Current Rides
Kepler   1.21 GW
1.21 GW
Post by Kepler » Sep 27 2020 1:59am
Quick update on this bike. Been riding it quite a bit around our local tracks and enjoying the bike a lot. So glad I fitted the silent gear and I am finding that after 500km of riding, the drive is quieter then ever.
Few other changes. Fitted the large Luna display. The stock display works fine but its just too small for me. Those with young eyes wont have a problem though.
Another great change has been fitting a rather cheap DNM coil over rear shock. Seriously, this shock feels great on this bike and is heaps more plush then then the Fox DPX2 that I had originally fitted. Also really nice over jumps with a well controlled rebound and very hard to bottom out. For $170 bucks, this shock is bargain addition to this bike. Down side is that the shock is heavy (twice the weight of the DPX2). Also the bushing doesn't have the same tolerances as the Fox. Just spray painted the coil to make it look like a Fox factory coil over (from a distance :) ).
Current Rides
Animalector   10 kW
Post by Animalector » Sep 27 2020 2:28am
Nice work. I fitted a coil shock to my giant reign. More than double the weight of the original super deluxe but you can't beat the plushness of a coil.
