What is the best motor for a friction drive for a 27.5in 2.25in tire?
I am planning to use a 6s3p battery pack.
I am currently looking at these two:
https://hobbyking.com/en_us/turnigy-aer ... motor.html
Should I go with a lower KV motor or high KV motor? I should stay below the legal speed limit of 25km/h.
Also, the motors are rated 10-12S Lipo, will they work with a 6s pack?
Best Motor for friction drive
Re: Best Motor for friction drive
For friction drive, the size of the tire doesn't matter.. the wheel is acting as an idler gear, transferring the surface speed of the motor to the road.
In other words, the road speed will be the same as the surface speed of the motor (or drive roller) regardless of wheel diameter.
You can work out the theoretical surface speed of the motor using battery voltage, motor kV and motor (or drive roller) radius. Actual speed under load will be a bit lower.
Motor selection will depend on the performance you are hoping to achieve.
Remember that there is a limit to how much power that can be transmitted from a roller to a tire by friction, especially if the tire is wet or muddy. If you haven't already, I suggest you read Kepler's threads.. he is one of the more experienced users of friction drive systems and has worked out clever solutions to the problems he has encountered in implementing them.
Thank You! I will start reading his threads..Drum wrote: ↑Aug 16 2019 2:37pmFor friction drive, the size of the tire doesn't matter.. the wheel is acting as an idler gear, transferring the surface speed of the motor to the road.
- spinningmagnets 100 GW
A relatively smooth tread has better traction than a knobby tire.
Zibbby's build, which turned into a friction drive index
http://endless-sphere.com/forums/viewto ... 28&t=14403
