KCR PANTERA Monsterbike
kcr   1 mW
Post by kcr » Aug 23 2019 5:30pm
Hi Everyone.
First i need to say hallo because i'm newbie here.
Second, if someone won't undestand me please ask, i will expalin what i meant - I'm from Poland and i'm not perfect in english ;)
Third, it will be a long post :D
About year ago i have seen e-bike in music video https://www.youtube.com/watch?v=mEcePRasi4Q and i had fall in love.
For this time i spent all free hours for reading and searching for informations in ebike category.
In the same time i finished study and i recieved mechatronic engineer diploma (without brag)
So i decide to make my own vision of powerfull ebike.
I meet some people who have monsterbikes with QS 205 motors, i taken few rides offroad and on asphalt and i was ensured about way which i will design my ebike.
below you can find list of issues which i decide to solve:
1 - ebike will have central motor but this motor will be a hub motor. I decide to make universal frame for QS 205 and QS 273 because this motors it the most used and standard in my country.
2 - frame will be universal - it means that all weight and height person will find good position on it.
3 - i had take few rides on Stealth type hub motor ebike with QS205 (150A from Sabvoton) and i was satisfied, but friend (who is owner of this ebike) told me that this motor warming up dangerously and sometimes thermal protection sensors cutting out power. So i decided to make grarbox by mine, between motor and rear wheel, to reduce power needed to move in forests, dowhill etc.
Thats where idea borned. I had opened my school licenced autodesk inventor and i started to learn it and make some drawings of shapes of ebike. Main inspiration was been Albatros enduro from this forum and Neematic FR1. Based of this 2 project i decided to make frame from pipes.
The most important part for me was gearbox because it will make my ebike unique.
Firstly i tryed to addapt Shimano Alfine but powers which i will put on it makes me affraid of living time of this hub so plan was abandoned. Also I've seen few projects of bicycle gearboxes (Effigear, Pinion) but it was protect by patent law so i decide to make gearbox based on motorcycle one.
Below plnas which i set to myself.
Max revolutions 1:1 motor to wheel will give me about 90km\h speed. I don't need more in hard terrain son i will reduce recoutions on wheel to recive more Nm on it and to protect motor for overheat.
- gear 1 - ratio 2:1 - 1 rpm of motor will give me 2 rpm of wheel and about 45 km\h of max speed
- gear 2 - ratio 1,66:1 - 1 rpm of motos will give me 1,66 rpm of wheel and about 60 km\h of max speed
- gear 3 - ratio 1,33:1 - 1 rpm of motos will give me 1,33 rpm of wheel and about 75 km\h of max speed
- gear 4 - ratio 1:1 - 1 rpm of motos will give me 1 rpm of wheel and about 90 km\h of max speed
photo from designing process
after it i decidet to produce subparts
project was too precise and gears wont' move so i decided to put valve paste on it and let it rotate on radial drill
after assy
after this operations i recieved ready gearbox which is already closed and filled with oil.
Next i tryed to make full ebike project with all components like motor, wheels, frame and gearbox.
First prototype looks like this and it was abandoned because i wasn't happy of rear swing arm.
pantera v1.jpg (415.14 KiB) Viewed 992 times
pantera v2.jpg (462.25 KiB) Viewed 992 times
pantera v2-1.jpg (141.33 KiB) Viewed 992 times
It looks terrible because all frame had 140mm width but swing arm (mounted on QS axis) were about 60-70 mm more width.
I didn't happy of it and i started again with new project regarding to knowledge recived from this project.
Second version of this project created few problems with gearbox so i decide to resign.
It was too big and heavy - better idea will be to make 2 or 3 changeable sprockets on rear wheel and chain tensioner.
Also here i decide to use QS 273 in the same frame and make it unversal for both QS 205 and 273 hub motors.
Below you can see results
pantera v3.jpg (435.32 KiB) Viewed 992 times
pantera v3-1.jpg (418.25 KiB) Viewed 992 times
pantera v3-2.jpg (368.04 KiB) Viewed 992 times
Also tere was one more thig that i decide to abandon - it was pedals. I dont have idewa where to put i because motor was placed on siwngarm. Maybe i should remodel it and remove QS from swingarm and connect it from pedals?
Please let me know your opionins about this project, i will be very happy for your comments.
Is this way is a good way? Or maybe should i change something? What do you thinking about it?
Kind regards for all who readed it ;)
let the force be with you:)
I don't have YT, Instagram or Facebook channles, its too early to show this project. Maybe i will create it when i will start to produce parts for ready version, now i don't have time for this actions - i prefer to waste time for designing ;)
You are the first who can see this ideas ;)
andrebandre   100 W
w
Post by andrebandre » Aug 23 2019 5:38pm
Why the front brake on the right side?
I think it looks great and will probably work great too.
I wish Neematic did happen.
flat tire   1 MW
Re: w
Post by flat tire » Aug 23 2019 5:43pm
Extremely impressive design and engineering work, kcr!
andrebandre wrote:
Aug 23 2019 5:38pm
Because that's where it belongs. All my bicycles have flipflopped brakes. Motorcycles and all that.
andrebandre   100 W
Re: KCR PANTERA Monsterbike
Post by andrebandre » Aug 23 2019 5:45pm
Personally i don't see the point of pedals on high power ebikes.
andrebandre   100 W
Re: w
Post by andrebandre » Aug 23 2019 5:51pm
flat tire wrote:
Aug 23 2019 5:43pm
andrebandre wrote:
Aug 23 2019 5:38pm
What is the purpose for have them crisscrossed?
Do they keep the bike on a straighter path when both applied hard?
Kind of ballance each other out in some way?
flat tire   1 MW
Post by flat tire » Aug 23 2019 6:18pm
No, it's because convention for motorcycle front brake is the right bar lever. So if you ride both motorcycles and ebikes you don't want to be juggling 2 control configurations with the same lever.
efMX Trials Electric Freeride   1 MW
Post by efMX Trials Electric Freeride » Aug 23 2019 7:05pm
there's no brake levers in the rendering.. only brake rotor, which is on the wrong side of fork? if its a dh bike fork, rotor is on the left.. switching brake levers from right to left is usually easy and just personal preference..
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
litespeed   100 kW
Post by litespeed » Aug 24 2019 9:14am
Excellent design.
Tom
andrebandre   100 W
Post by andrebandre » Aug 24 2019 6:27pm
efMX Trials Electric Freeride wrote:
Aug 23 2019 7:05pm
That's what i meant (rotor), i thought there is some reason for it that i'm not aware of.
Makes sense to have the front brake lever on the right when riding both motorcycles and bicycles.
Thank you guys both for clearing it up.
Grantmac   10 kW
Post by Grantmac » Aug 24 2019 10:33pm
If you are going through the trouble of building a gear reduction then I'd look for a properly sized in runner rather than a hub motor. The power density is much higher and cooling is less of an issue.
Usually the problem is the RPM but with even a moderate first stage reduction like 3:1 it should be no problem.
kcr   1 mW
Re: w
Post by kcr » Aug 26 2019 3:28pm
andrebandre wrote:
Aug 23 2019 5:38pm
It's only design and i don't know where break clip will be. Its depends of fork type.
Thanks for good words :)
flat tire wrote:
Aug 23 2019 5:43pm
Thank you :)
andrebandre wrote:
Aug 23 2019 5:45pm
That's why i will try to make this ebike without pedals. Only one reason why i tryed to add it is fact that in PL we don't have regulated law for electic vechicles and ebikes (with pedals) are treated like normal bicycles, even very powerfull ebikes.
andrebandre wrote:
Aug 23 2019 5:51pm
Like i said - i dont know where breaks will be it depends for fork.
Thakns for comment
flat tire wrote:
Aug 23 2019 6:18pm
Youre right, i will keep it in my mind :) Thanks
Aug 23 2019 7:05pm
Thats right, i have to buy Rockshoxx boxxer and i thinking about it. If i will do it breaks will be on opposite side.
litespeed wrote:
Aug 24 2019 9:14am
Excellent design.
Tom
Thank you Tom :)
andrebandre wrote:
Aug 24 2019 6:27pm
Aug 23 2019 7:05pm
exactly
Grantmac wrote:
Aug 24 2019 10:33pm
Yes, thats why i decide to use changeable sprocket on rear wheel, If i will need power in hard terrain i can use reduction sprocket which allow to recieve 3x(for example) more power on wheel. The same situation when i will need some speed on straight way, then i will use 1:1 sprocet and i will have about 90km\h max speed
Grantmac   10 kW
Post by Grantmac » Aug 26 2019 4:06pm
But you are still using a hub motor, it's just in the middle.
Much better to use a motor designed for mid-drive use. It will have better cooling and operate at higher RPM.
For gear reduction all you need is a low and direct gear which could be done with a single planetary.
kcr   1 mW
Post by kcr » Aug 26 2019 4:40pm
Grantmac wrote:
Aug 26 2019 4:06pm
So you thought that hub motor in a middle is a bad idea?
Btw. Do you know powerfull hub motor which i can use instead? I don't have knowledge in other motors than hub, my friends have hub ebikes too so i don't know where to find informations.
If you know motor with simiar or better preformance like QS 273 for similar or better price and good dimesions-weight ratio please let me know - each information will be very helpful. I can still change project because i didn't started production of parts yet.
Grantmac   10 kW
Post by Grantmac » Aug 26 2019 7:00pm
QS offer motors which peak up to 30kw, how much do you need?
john61ct   10 GW
Post by john61ct » Aug 30 2019 8:32am
Do they make powerful front hub motors?
fechter   100 GW
Post by fechter » Aug 30 2019 10:01am
For an electric motor, the transmission can have much wider ratios between gears. In most cases, just two or three speeds would be enough. Most people run with a single speed.
Here's a bike with a design similar to your build:
https://www.hpcbikes.com/pages/typhoonpro
