If the mobile app works, then the change to DFU works, at lest for me. See on the firmware the UUID for the endpoint that you should use to write the 99.beemac wrote: ↑Mar 28 2021 8:20amThanks i'm trying to flash the wireless controller fw on my test bike - because I've wrapped it in tape I wanted to update OTA. Never actually managed to get OTA working - I always flash using the STLINK...rananna wrote: ↑Mar 28 2021 7:58amShort answer: using the Nordic app to modify the Bluetooth characteristic.
Longer answer: you only need 0x99 for setting the ANT ID to something other than 0 ( 0 pairs with any motor)
For all other options I simpified the operation of the wireless remote to avoid the need to use the Nordic app for configuration.
Full instructions here:
https://opensourceebike.github.io/operation.html
See configuration mode.
However, usually no configuration is necessary, it should work out if the box if you are not using a Garmin.
What are you trying to change?
In nrf connect - i don't see ANT ID as a parameter for the motor controller as shown in your video - just a generic unknown service in addition to the 0x1800/0x1801 name fields - it does have a single updateable parameter - currently set to 0x3. If I change this to 0x99 -the wireless controller reboots - but does not go into DFU mode...
I've disconnected the debugger just in case...
Any other handy hints![]()
TSDZ2 EBike wireless standard (like Specialized Turbo Levo) - OpenSource
Re: TSDZ2 EBike wireless standard (like Specialized Turbo Levo) - OpenSource
- EBike wireless standard: wireless motor, wireless cycling GPS display Garmin Edge and wireless remote with wireless brake sensor
- TSDZ2 OpenSource firmware
Developer of OpenSource knowledge and technology for ebikes: Wireless EBike standard ANT+ and Bluetooth, TSDZ2 OpenSource firmware, KT motor controllers and displays: Bafang 850C color, SW102 Bluetooth and KT-LCD3.
Please consider a donation to help developments: paypal.me/jorgecasa
Ok - checking the UUIDs in code I am changing the value under the ANT UUID - but the controller still just reboots after a second or so... does not go into DFU mode... i see the power on led sequence - so I know it's not going into bootloader..casainho wrote: ↑Mar 28 2021 8:28amIf the mobile app works, then the change to DFU works, at lest for me. See on the firmware the UUID for the endpoint that you should use to write the 99.beemac wrote: ↑Mar 28 2021 8:20amThanks i'm trying to flash the wireless controller fw on my test bike - because I've wrapped it in tape I wanted to update OTA. Never actually managed to get OTA working - I always flash using the STLINK...rananna wrote: ↑Mar 28 2021 7:58amShort answer: using the Nordic app to modify the Bluetooth characteristic.
OK - seems I am doing it right - but for whatever reason the reset into bootloader isn't working... i added one line to show the LED blue when it was about to go into bootloader - and I see that LED.beemac wrote: ↑Mar 28 2021 8:47amOk - checking the UUIDs in code I am changing the value under the ANT UUID - but the controller still just reboots after a second or so... does not go into DFU mode... i see the power on led sequence - so I know it's not going into bootloader..casainho wrote: ↑Mar 28 2021 8:28amIf the mobile app works, then the change to DFU works, at lest for me. See on the firmware the UUID for the endpoint that you should use to write the 99.beemac wrote: ↑Mar 28 2021 8:20amThanks i'm trying to flash the wireless controller fw on my test bike - because I've wrapped it in tape I wanted to update OTA. Never actually managed to get OTA working - I always flash using the STLINK...rananna wrote: ↑Mar 28 2021 7:58am
if (mp_ui_vars->ui8_enter_bootloader) //check to see if reboot into the bootloader is needed
mp_ui_vars->ui8_enter_bootloader = 0;
nrf_power_gpregret_set(BOOTLOADER_DFU_START); //set the dfu register
bsp_board_led_on(LED_B__PIN); // Indicate about to enter bootloader
nrf_delay_ms(1000); //wait for write to complete
eeprom_write_variables();
nrf_delay_ms(3000); //wait for write to complete
NVIC_SystemReset(); //reboot into bootloader
Ah maybe I don't have a bootloader? If I've always flashed using stlink....?
Hello there !
This project seems excellent ! I intend to order a TSDZ2, and would be interresting to control it with my smartphone.
Am I correctly understanding that it is posible to control the bike only with a smartphone ? including controlling the lights ? ( i won't have money to buy a bike gps yet)
Should I order a display allong with the motor, or would the wireless connection be enough ? Is it possible to cumulate a small cheap display and the wireless connectivity, in order to use the standard wired display as backup ?
Thank you all, especially Casainho
Hmmm... what a pita - cannot get the bootloader to work from source - even if I flash the bootloader only - I can't get into DFU..beemac wrote: ↑Mar 28 2021 9:01amOK - seems I am doing it right - but for whatever reason the reset into bootloader isn't working... i added one line to show the LED blue when it was about to go into bootloader - and I see that LED.beemac wrote: ↑Mar 28 2021 8:47amOk - checking the UUIDs in code I am changing the value under the ANT UUID - but the controller still just reboots after a second or so... does not go into DFU mode... i see the power on led sequence - so I know it's not going into bootloader..casainho wrote: ↑Mar 28 2021 8:28amIf the mobile app works, then the change to DFU works, at lest for me. See on the firmware the UUID for the endpoint that you should use to write the 99.beemac wrote: ↑Mar 28 2021 8:20am
I'll try the posted binaries - might be something odd with my make/link files..
You will need to build at least one board based on the nrf52840 - see the documentation https://opensourceebike.github.io/theflyingjaguar wrote: ↑Mar 28 2021 9:14amHello there !
There will be documentation put up for the wired remote option soon - where the buttons/brakes are wired directly to the controller as an alternative to the bluetooth remote.
Yes I understand that I have to build the wireless board. I just want to make sure it is the only thing I need for now.beemac wrote: ↑Mar 28 2021 9:35amYou will need to build at least one board based on the nrf52840 - see the documentation https://opensourceebike.github.io/
Also I'm not sure to understand where I would plug the break sensor, I thought there were plug onto the display (at least on VCLD5)
Ok - so going back to the published 0.9.0 bootloader binary (it's not that easy to find since it's not included in the latest releases) - and things work as expected - plus once I flash the fw - I can write 0x99 and it boots into _DFU mode as expected...beemac wrote: ↑Mar 28 2021 9:31amHmmm... what a pita - cannot get the bootloader to work from source - even if I flash the bootloader only - I can't get into DFU..beemac wrote: ↑Mar 28 2021 9:01amOK - seems I am doing it right - but for whatever reason the reset into bootloader isn't working... i added one line to show the LED blue when it was about to go into bootloader - and I see that LED.
Wonder why my built bootloader binaries don't work...
@casainho - which source for the bootloader should I be using? Think I should be using the 2nd one - might be my problem...beemac wrote: ↑Mar 28 2021 10:20amOk - so going back to the published 0.9.0 bootloader binary (it's not that easy to find since it's not included in the latest releases) - and things work as expected - plus once I flash the fw - I can write 0x99 and it boots into _DFU mode as expected...beemac wrote: ↑Mar 28 2021 9:31amHmmm... what a pita - cannot get the bootloader to work from source - even if I flash the bootloader only - I can't get into DFU..beemac wrote: ↑Mar 28 2021 9:01amOK - seems I am doing it right - but for whatever reason the reset into bootloader isn't working... i added one line to show the LED blue when it was about to go into bootloader - and I see that LED.
https://github.com/OpenSourceEBike/TSDZ ... bootloader
or
edit: Ok doesn't matter - both compile and build to identical binaries... but it still doesn't work... binaries don't match the published 0.9.0 binary. That is the same up until about the final quarter - 0EB000 onwards...
Any ideas why the published binary differs to what gets built from source...? Am using the standard makefile - runs cleanly on Windows.
The wireless board and all the components as in seen on the documentation on how to buid it + a remote like the VLCD5 remote.theflyingjaguar wrote: ↑Mar 28 2021 10:03amYes I understand that I have to build the wireless board. I just want to make sure it is the only thing I need for now.
There is the wireless remote option but I think I am the only one using it yet and I am having some issues, the regular remote will be easier much easier for build and at anytime you can build the wireless remote if you prefer.
Draft info here that explains the differences in configurations - and where brakes connect - pending merge into main docs:theflyingjaguar wrote: ↑Mar 28 2021 10:03amYes I understand that I have to build the wireless board. I just want to make sure it is the only thing I need for now.beemac wrote: ↑Mar 28 2021 9:35amYou will need to build at least one board based on the nrf52840 - see the documentation https://opensourceebike.github.io/
https://github.com/4var1/OpenSourceEBik ... 2_board.md
Ok - PR submitted for wired remote docs + to add brake LED signal to wired remote.casainho wrote: ↑Mar 28 2021 11:01amThe wireless board and all the components as in seen on the documentation on how to buid it + a remote like the VLCD5 remote.theflyingjaguar wrote: ↑Mar 28 2021 10:03amYes I understand that I have to build the wireless board. I just want to make sure it is the only thing I need for now.
I've given up on OTA updates again - can't see why my compiled bootloader differs from the published - driving me crazy...
We have a repository for the bootloader and I think it is the only one used by the others, when building the code for debug.
For instance, the SDK, is on the common firmware folder that we should use on all the firmwares although there is some issues that the SDK on the common firmware folder makes the wireless remote not working for some unknown reason and it is used a copy of SDK on this firmware... so, I am not sure about the bootloader, this kind of strange things can happen - this means there is a LOT of work to do
Yes, we are all using the same compiled bootloader image when building the firmware.casainho wrote: ↑Mar 29 2021 6:04amWe have a repository for the bootloader and I think it is the only one used by the others, when building the code for debug.
For instance, the SDK, is on the common firmware folder that we should use on all the firmwares although there is some issues that the SDK on the common firmware folder makes the wireless remote not working for some unknown reason and it is used a copy of SDK on this firmware... so, I am not sure about the bootloader, this kind of strange things can happen - this means there is a LOT of work to do![]()
I'm really scratching my head today with this issue with the motor with the dodgy torque sensor. I replaced the motor controller and the sensor seems to be working - is giving sensible numbers - 150ish unloaded rising to 300 or so with 105kg on it - so all good.casainho wrote: ↑Mar 29 2021 6:04amWe have a repository for the bootloader and I think it is the only one used by the others, when building the code for debug.
However I cannot get the assist back properly. I copied the program/data/options from my non-test bike which is still running code from about three weeks ago. Now I can get assist to work briefly - but then cuts out...
Walk assist still works fine...
One thing on the Android app - that I've seen before but doesn't do it all the time - but now I can't stop it doing it - is when saving config parameters it prompts for street mode power limit - that's always 0 in the settings so the config won't save as it needs to be between 25-2500. Saving a value never sticks - so the next time you go into config - it's zero again and you get an error saving...
Going to call it a day - time for a beer in the sun...
Quick update as I found out a couple of things.beemac wrote: ↑Mar 29 2021 11:51amI'm really scratching my head today with this issue with the motor with the dodgy torque sensor. I replaced the motor controller and the sensor seems to be working - is giving sensible numbers - 150ish unloaded rising to 300 or so with 105kg on it - so all good.casainho wrote: ↑Mar 29 2021 6:04amWe have a repository for the bootloader and I think it is the only one used by the others, when building the code for debug.
I noticed that the PR before last that I submitted still had street mode enabled from when I was testing - it's not present in the last PR. But wondered if that might be the cause of your assist issues casainho? Sorry if it was!
Also - the Android app only shows the issue when saving parameters if street mode is enabled. So that's why I don't see it all the time.
Happy days... maybe I'll get to ride my new fsr this week after allbeemac wrote: ↑Mar 29 2021 1:13pmQuick update as I found out a couple of things.beemac wrote: ↑Mar 29 2021 11:51amI'm really scratching my head today with this issue with the motor with the dodgy torque sensor. I replaced the motor controller and the sensor seems to be working - is giving sensible numbers - 150ish unloaded rising to 300 or so with 105kg on it - so all good.casainho wrote: ↑Mar 29 2021 6:04amWe have a repository for the bootloader and I think it is the only one used by the others, when building the code for debug.
Seems the reason why assist wasn't working despite the torque sensor working fine the PAS sensor wasn't reading anything - looks like a dodgy connection.
I had to get the old serial tap out to see what was going on - but as is so often the way - then found this which describes my issue perfectly.
https://github.com/OpenSourceEBike/TSDZ ... ensor_fail
I wrote that page. Tha this why I wish to have a configuration to disable each sensor, like PAS sensor or the brake, for instance.beemac wrote: ↑Mar 30 2021 11:12amHappy days... maybe I'll get to ride my new fsr this week after all
Thanks it was useful - up until today I assumed the black lump on the end of the motor controller was just to align things mechanically - didn't realise it was another sensor!casainho wrote: ↑Mar 30 2021 1:38pmI wrote that page. Tha this why I wish to have a configuration to disable each sensor, like PAS sensor or the brake, for instance.beemac wrote: ↑Mar 30 2021 11:12amHappy days... maybe I'll get to ride my new fsr this week after all
Yea agreed - we need to put together a list of new configuration parameters so we can work on the new configuration packet format. I've got quite a list!
Would be hard to run without a PAS sensor though unless we put vthrottle back. I can sort of see how you'd be able to infer cadence from the torque sensor only but might have some odd results!
qq - is the latest source for the android app up on github? Last time I looked it was only the v30 source not v31...
Hello everyone!
Thank you to all the developers for taking on this amazing project to make the TSDZ2 wireless! I am very excited about this project.
Just last night, I ordered all the parts listed on the new Wiki page to build the wireless controller for the motor and for the remote. I am wondering if anyone in the community has made a PCB for it and has gerber files that I can send to a PCB vendor. If not, I will simply use a protoboard as the Wiki says. Also, are there any STL files available for the motor controller enclosure? And the STL files for the remote are the latest ones on the Wiki?
Looking forward to receiving my parts and getting rid of the wires on my bike!
Will update the thread once I have the parts built!
Thank you!
Thank you!
If you bought the parts listed on the wiki then is best to build the DIY version as the PCB version seems to use some different parts. No one did document the PCB version yet, you need to search on this thread.sidmodi wrote: ↑Mar 31 2021 11:34amJust last night, I ordered all the parts listed on the new Wiki page to build the wireless controller for the motor and for the remote. I am wondering if anyone in the community has made a PCB for it and has gerber files that I can send to a PCB vendor. If not, I will simply use a protoboard as the Wiki says. Also, are there any STL files available for the motor controller enclosure? And the STL files for the remote are the latest ones on the Wiki?
Yes, the STL files are the last ones for the wireless remote but if you want you can try to go with the wired remote as will be much easy to build.
Yes, please share. If you take good photos from a clean build, they may be used on the documentation - would be your contribution.
Great - this post has photos of one of my wired remote boards - photos aren't great but might be useful to help you lay things out.sidmodi wrote: ↑Mar 31 2021 11:34amHello everyone!
Thank you!
viewtopic.php?f=28&t=106346&start=1325#p1626311
If you go the wired route - I recommend putting the controller on the handlebars. I've just completed a 2nd build and this time put the controller on the bars - much better for being able to see what's going on. See pics I posted on the other thread:
viewtopic.php?f=28&t=79788&start=8400#p1628875
I think this would be better:beemac wrote: ↑Mar 31 2021 11:56amIf you go the wired route - I recommend putting the controller on the handlebars. I've just completed a 2nd build and this time put the controller on the bars - much better for being able to see what's going on. See pics I posted on the other thread:
Why don't you 3D print the wireless remote enclosure and use it? you would not use the coin battery and install the DC-DC converter near the TSDZ2 display connector.
I was hoping to make the wireless remote and make an almost completely wireless bike (except for the brake cable). I am curious about why you and beemac are both recommending a wired remote setup. Is it just because of the difficulty to build the system? Or is it because it is not quite ready to be tested? If it is just about the difficulty to build it, I don't really mind - I have access to a 3D printer so I can print the remote case as well as the box for the wireless motor controller. Here is the list of the parts that I ordered:casainho wrote: ↑Mar 31 2021 11:42amIf you bought the parts listed on the wiki then is best to build the DIY version as the PCB version seems to use some different parts. No one did document the PCB version yet, you need to search on this thread.sidmodi wrote: ↑Mar 31 2021 11:34amJust last night, I ordered all the parts listed on the new Wiki page to build the wireless controller for the motor and for the remote. I am wondering if anyone in the community has made a PCB for it and has gerber files that I can send to a PCB vendor. If not, I will simply use a protoboard as the Wiki says. Also, are there any STL files available for the motor controller enclosure? And the STL files for the remote are the latest ones on the Wiki?
NRF52840-DONGLE x 2
TEC 2-4811WI
BSP296N
ITS4140N
I wasn't suggesting you go either route - only that if you went wired I recommend putting the box on the handlebar rather than near the motor. I haven't built or tested the wireless solution so not sure what it's like in real world use - any issues though should be fixable so if you want to go wireless you should be ok.sidmodi wrote: ↑Apr 01 2021 1:05amI was hoping to make the wireless remote and make an almost completely wireless bike (except for the brake cable). I am curious about why you and beemac are both recommending a wired remote setup. Is it just because of the difficulty to build the system? Or is it because it is not quite ready to be tested? If it is just about the difficulty to build it, I don't really mind - I have access to a 3D printer so I can print the remote case as well as the box for the wireless motor controller. Here is the list of the parts that I ordered:casainho wrote: ↑Mar 31 2021 11:42amIf you bought the parts listed on the wiki then is best to build the DIY version as the PCB version seems to use some different parts. No one did document the PCB version yet, you need to search on this thread.sidmodi wrote: ↑Mar 31 2021 11:34amJust last night, I ordered all the parts listed on the new Wiki page to build the wireless controller for the motor and for the remote. I am wondering if anyone in the community has made a PCB for it and has gerber files that I can send to a PCB vendor. If not, I will simply use a protoboard as the Wiki says. Also, are there any STL files available for the motor controller enclosure? And the STL files for the remote are the latest ones on the Wiki?
NRF52840-DONGLE x 2
TEC 2-4811WI
BSP296N
ITS4140N
