Tommm 100 kW
Post
by Tommm » Jun 23 2020 7:51pm
Chambers wrote: ↑Jun 23 2020 7:29pm
The goal of this project is to design and build an integrated 'bicycle like' frame for the cyclone coaxial that is 'better' than the elite frame.
People have also asked for plans... same applies, I am not willing to supply plans until I have built and tested the unit, I cannot in good concience supply for plans for something that is untested.
My god, buying an untested frame or building from half baked plans, that's exactly how the elite frame came to life in the first place
If you use bearings everywhere with a 74mm stroke shock, you'll already be way ahead.
Chambers 100 W
Post
by Chambers » Jun 23 2020 7:53pm
Tommm wrote: ↑Jun 23 2020 7:51pm
Chambers 100 W
Post
by Chambers » Jun 24 2020 3:38am
I already have a linkage designed - Loosely based on a Turner DHR set up - Same basic linkage on both frames. This will have bearings I just haven't modeled them yet.
- Linkage.JPG (40.68 KiB) Viewed 2171 times
- coaxial -21.JPG (86.82 KiB) Viewed 2171 times
Or am I misunderstanding?
The linkages themselves will be made on my home CNC if the parts ever arrive! Otherwise it's not too daunting of a task to make them by hand - Just time consuming to get right.
The reason I chose this set up is that it isn't too difficult to modify/swap the linkages for fine tuning. It also allows for a solid swing-arm which should handle the torque of an electric motor better than a multi-piece swing-arm.
Tommm 100 kW
Post
by Tommm » Jun 25 2020 6:45am
Some inspiration
https://shop.sondors.com/pages/rockstar
The rear main bering being kind of integrated to the seatpost makes the rear chainstay a lot shorter. It looks a lot more complex to do though.
Chambers 100 W
Post
by Chambers » Jun 25 2020 6:59am
Tommm wrote: ↑Jun 25 2020 6:45am
Some inspiration
Yeah saw that this morning - Looks quite good actually.
Curious how big the internal battery space is?
Elaguila 1 mW
Post
by Elaguila » Jun 26 2020 4:15am
Right the downtube size would be interesting, but no dimensions are shown.
The homepage says: New, 48 Volt, 21 Amp Hour, Lithium-ion battery with genuine LG 3500 cells.
They might have packed 13s6p into the body.
Chambers 100 W
Post
by Chambers » Jun 30 2020 3:16am
Elaguila wrote: ↑Jun 26 2020 4:15am
Yep shame I can't justify the cost on a custom forged design
Tommm 100 kW
Post
by Tommm » Jun 30 2020 6:06am
Chambers wrote: ↑Jun 30 2020 3:16am
You interested in doing a left hand drive design? With crank on the right? Cyclone already done it for eeb frames.
Elaguila 1 mW
Post
by Elaguila » Jul 01 2020 12:42pm
Tommm wrote: ↑Jun 30 2020 6:06am
Yes definetively this would be the best drivetrain setup imho: left hand drive by e-motor and fixed gear chain drive and right hand side by crank and rear derailleur. I have already experienced the cyclone coaxial motor with all-in-one right hand side drive train but it was not a perfect layout since this motor is too strong for the bike gear cassette and all the remaining bike parts. Especially if you do controller tuning and may go up to 6-10kW.
On the left hand side I think chain drive would be preferred over belt drive due to parts availability, easyness to shorten the chain, etc. LMX 64 has perfectly demonstrated the left hand drive setup with motorbike parts.
Is it possible to design the rear swing arm with enough clearance for the chain considering a 30t front/50t rear sprocket setup?
You are right, Cyclone already has shown this drivetrain layout at an enduro bike:
https://youtu.be/0C5hlyI6F1E
Skaiwerd 100 W
Post
by Skaiwerd » Jul 01 2020 2:49pm
I can see the dual set up working well with the chains on both sides. The pulley on left side looks like it uses the “five holes” as it’s called referring to freewheel mounting. So a five holes to 104bcd adaptor would work? Cyclone and sick bike parts sells this part. Anyone to try to convert or convince cyclone “paco” to do dual chain?
Tommm 100 kW
Post
by Tommm » Jul 01 2020 3:03pm
Skaiwerd wrote: ↑Jul 01 2020 2:49pm
The reason he went belt here is because the drive and motor is on one unsuspended piece. Hence there is no chain growth. On any other frame you would need a tensioner.
As far as I can see paco is using a brake disc to bcd104 adaptor, so any 104bcd cog will fit yes. For the coaxial motor, the freewheel is inside the motor, no need for a 5 hole one outside.
Chambers 100 W
Post
by Chambers » Jul 02 2020 1:57am
I plan on making this frame capable of either motor - Probably 219 chain conversion on the LHS with tensioner, I am conscious of the noise factor though so if I can figure out a suitable belt tensioner I may go that route - Definitely more difficult to do a belt tensioner effectively though .
Tommm wrote: ↑Jul 01 2020 3:03pm
Elaguila wrote: ↑Jul 01 2020 12:42pm
[Especially if you do controller tuning and may go up to 6-10kW.
This is my thinking too - With dual drive more power is possible .... How much more? We'll have to find out
the limiting factor will likely be the planetary gear box. The 4.8kw version uses steel gears so it will be interesting to see how much power they can take.
Chambers on Jul 02 2020 2:45am, edited 1 time in total.
Chambers 100 W
Post
by Chambers » Jul 02 2020 2:01am
When I emailed Paco earlier in the week he said
"dual side motor with crank Can use both side chain"
Chambers 100 W
Post
by Chambers » Jul 03 2020 3:18am
For those asking about dual side chain - this just popped up today
Tommm 100 kW
Post
by Tommm » Jul 03 2020 6:34am
Drooling mate. Shame my hub is lightened at the brake bolts in one direction.
Definitely the way to go.
Elaguila 1 mW
Post
by Elaguila » Jul 04 2020 12:32pm
Chambers wrote: ↑Jun 24 2020 3:38am
I already have a linkage designed - Loosely based on a Turner DHR set up - Same basic linkage on both frames. This will have bearings I just haven't modeled them yet.Linkage.JPGcoaxial -21.JPG
Chambers, could you please advise which damper you have considered as of today - do you think a coil damper with 240x76 would fit?
Chambers 100 W
Post
by Chambers » Jul 04 2020 10:20pm
Elaguila wrote: ↑Jul 04 2020 12:32pm
The shock pictured is a FOX DHX 5.0 230mm eye to eye - I already had the model from a previous project (lazy drafting
) but I don't have the shock so open to suggestions.
To answer your question -theoretically yes, it's possible to fit a shock that size depending on the overall dimensions - Have you found a good deal on something?
I plan to make the shock mount adjustable for fine tuning the ride, but won't know 100% until I have everything in my hands and the frame tacked up on the bench.
Chambers 100 W
Post
by Chambers » Jul 04 2020 10:22pm
Yeah it's good stuff -
The cyclone motor already freewheels so no need for the dual freewheel hub.
Chambers 100 W
Post
by Chambers » Jul 04 2020 10:23pm
Tommm wrote: ↑Jul 03 2020 6:34am
Dual Chain motor ordered! - Now the waiting game.... I'm sure the motor will turn up before the nuc' 12f though
Elaguila 1 mW
Post
by Elaguila » Jul 05 2020 4:27pm
Chambers wrote: ↑Jul 04 2020 10:20pm
OK I assume that for your first prototype you are going to use the 230mm damper version...You are right there has been a good offer with a 240mm eye to eye. But what I´ve learned in the past is to make no compromise on chassis parts so basically the original designed geometry will be the best setup
What is the rear wheel travel you could realize with that kind of damper?
Thanks for sharing the YouTube video with the cyclone 4.8kW dual chain drive!
Chambers 100 W
Post
by Chambers » Jul 06 2020 2:05am
Elaguila wrote: ↑Jul 05 2020 4:27pm
Theoretically 208mm rear travel based on the components modeled - TBH I'm not set on any shock yet, I will likely do a few mods to accommodate something more readily available and affordable.
Cheers
Chambers 100 W
Post
by Chambers » Jul 07 2020 3:40am
- coaxial -27.JPG (45.89 KiB) Viewed 1850 times
Thinking about inserting the battery from underneath - through the motor mount. This would keep the frame much stronger than having a large cut out.
Could still have an 'inspection window' but it wouldn't need to be as large.
This would also mean I could make the down-tube even smaller because I wouldn't need flanges for bolting the door/panel.
Could save +/- 20mm in the vertical direction on the taller frame - The other one already inserts from the bottom but is offset from the motor mount.
Tommm 100 kW
Post
by Tommm » Jul 07 2020 3:45am
Chambers wrote: ↑Jul 07 2020 3:40am
How does it go *through* the motor mount?
