Whats the verdict: strongest crank freehweel?
12-C   100 W
Post by 12-C » Aug 31 2020 8:31pm
I'm going to replace the freewheel since it's starting to act up a bit.
I'm considering the SBP UHD freewheel
http://sickbikeparts.com/front-freewhee ... eavy-duty/
Whats the verdict on durable freewheels?
briangv99   100 W
Re: Whats the verdict: strongest crank freehweel?
Post by briangv99 » Aug 31 2020 11:47pm
The UHD SBP/White freewheel is definitely the best I've used. It combines the best of the regular White freewheel but with a second bearing to provide lateral support to hold the side loading introduced by a motor running into it.
All the single support bearing FWs, even the standard duty White Eno, eventually flog out without a secondary bearing for support.
Second best are the ACS Crossfires FWs that I believe have two bearings to transmit side loadings evenly. Sealing isn't as good as the White/SBP FW though
briangv99   100 W
Post by briangv99 » Aug 31 2020 11:50pm
note that the SBP FW is slightly thicker than a regular FW because of the extra bearing, so you may need to adjust your chainline to suit
Skaiwerd   100 W
Post by Skaiwerd » Sep 03 2020 10:45am
I’ve had good luck with the $85 version...
http://sickbikeparts.com/front-freewheel-heavy-duty/
12-C   100 W
Post by 12-C » Sep 03 2020 11:33pm
Skaiwerd wrote:
Sep 03 2020 10:45am
I have that one too. THere seems to be somethign wrong with it. There is a ton of play, with finger pressure it's almost like I can displace the bearings and make it "click" one side to the other....
I ended up ordering the UHD one... we'll see!
