I install the bbs02, and while it technically fits it doesn't not really fit. The crank arms are way offset. I even put on a 18 mm offset left arm crank and the left is still 15mm closer to the chain stay then the right side.
15mm is quite a bit offset when you arre clipped in and riding. I searched the internet and don't really see much discussion about this. People talk about lekkie bars but that is only 18mm offset and would still leave an imbalance of 15mm. I really think its not even great for the 68mm. Even with an offset bar on a 68mm bb you still would be left with around 6mm difference left to right.
Any thoughts on this?
