DENGFU E10 blue
patdam   1 W
1 W
DENGFU E10 blue
Post by patdam » Dec 26 2020 4:08am
Hi
I show you my E10 with some modifications done
I have reduced yoke width to install 215X60 rear schock, with fork in 160, i have 360mm BB height
to avoid a pebble gets stuck in swing arms
I have also increase length of remote and power supply wire, perform 2 holes on lower battery support to evacuate water infiltration, stalled the battery in its housing and add alloly plate to avoid to lose it. I do not see other potential problem who necessitate modifications ?
Alfie   1 W
1 W
Re: DENGFU E10 blue
Post by Alfie » Dec 26 2020 4:06pm
That looks great. Love the colour. Did you buy it in the blue or get it painted?
Whyte T129 TSDZ2
patdam   1 W
1 W
Re: DENGFU E10 blue
Post by patdam » Dec 27 2020 12:57am
ordered in this color, custom color cost few tens USD more and it is done at quality "dengfu"
Grantmac   10 kW
Re: DENGFU E10 blue
Post by Grantmac » Dec 27 2020 11:47am
What is your finished weight?
patdam   1 W
1 W
Re: DENGFU E10 blue
Post by patdam » Dec 27 2020 2:53pm
tested at beginning, 23.5 with air shock before some modifications (protections tape, etc..), now with spring shock, i think more near 24 kg. it is not a problem for me
DaDo.Bzz   100 W
Re: DENGFU E10 blue
Post by DaDo.Bzz » Dec 29 2020 3:36pm
Nice job. Is that frame rigid enough?
LMX 81, 16S6P 60A
Dengfu E10, M600, 840Wh, 48V
CTM Scroll, BBSHD, 700Wh, 52V
Slovakia, Bratislava
patdam   1 W
1 W
Re: DENGFU E10 blue
Post by patdam » Dec 30 2020 2:09am
Normaly carbon is mostly rigid than alloy, but i do not find it have execive rigidity. The most notable point i have feel at first ride it is his great tolerance, lose of grip occur progrsivally and it is more easy to control.
I find it a lot of more easy to drive than my spectral on, The biggest defect is consequencies of is stability and great reach. it is an XL and with 160 travel i have 1310 of empattement. hairpin bend is more complicate. But it is the only point where i feel lack of maniability, in all other case i have not problem with maniability
waynebergman   100 kW
Re: DENGFU E10 blue
Post by waynebergman » Jan 10 2021 8:00pm
Nice going Patdam, the new frame looks nice. The BB area ground clearance looks nice as well. I hope your bike works well for you. ........wayne
patdam   1 W
1 W
Re: DENGFU E10 blue
Post by patdam » Jan 11 2021 6:55am
Hi.
Only one day of ride in moutain since assembly, Now i am under snow and very cold weather. i need to wait a few before continue testing and suspension adjust. But i am confiant, i have appreciate a lot the functioning on first ride.
I have seen that dengfu have update her frame to correcting water infiltration from battery cover, i do not know if they have done other modification
flarvb   1 µW
Re: DENGFU E10 blue
Post by flarvb » Jan 22 2021 10:44am
Hi Patdam,
Thank you for sharing your experience in this and other topcis with the E10 frame and building it.
I am about to order a frame, battery and motor set.
Any suggestions for the order?
Would you have the frame painted by DengFu again if you were to order one again? I am thinking of only car-wrapping some parts of the frame instead of painting.
Many thanks in advance!
patdam   1 W
1 W
Re: DENGFU E10 blue
Post by patdam » Jan 22 2021 12:56pm
Hi
for sure if I ordering new one, i will take with paint, the paint is a great quality and i love the color.
no special reco for ordering, purchase additional derailleur hangers for spare part, Seat clamp (34.9) and steerer bearing are not at quality level of frame (but cheaper), you can purchase other from other manufacturer. It seem that they have modified the frame to prevent water infiltration.
Only one recomendation, be patient after ordering, fast shipping (+- 15 days to france) but they take several week to sent.
flarvb   1 µW
Re: DENGFU E10 blue
Post by flarvb » Jan 24 2021 7:10am
Merci pour le message!
I agree, the color is superb. Can you share the name of the color or color-code?
Latest indication is that they are able to ship in March
patdam   1 W
1 W
Re: DENGFU E10 blue
Post by patdam » Jan 24 2021 9:56am
The dengfu color is "PT306C glossy finish". I have asked clear blue and they have proposed it with an picture of sample. Do not hesitate to ask her your personal wish.
Sunburntwilly   10 µW
10 µW
Re: DENGFU E10 blue
Post by Sunburntwilly » Jan 27 2021 8:24am
Looks great. Wish I had ordered paint. Never mind. Love to know what forks your useing? I am still sorceing parts to finish the build when it arrives in March. No real idea what I am doing if I'm honest. I just like to have everything I need to finish the build before it gets here. Any advice would be much appreciated.
Awsome looking bike. Can't wait to get mine. Cheers bob.
Waynemarlow   10 kW
Re: DENGFU E10 blue
Post by Waynemarlow » Jan 27 2021 10:56am
Sunburntwilly wrote:
Jan 27 2021 8:24am
Type in Cheeb and emtb into google and you may find what you are looking for. :wink:
For some reason I can't get into the www.emtbforums.com/ website at the moment ( I've probably been flicked again for asking questions of the annointed son ), but there's a pretty big build log of the E10 in the DIY build section.
Waynemarlow   10 kW
Re: DENGFU E10 blue
Post by Waynemarlow » Jan 27 2021 10:58am
Well worth just getting the frame in clear gloss.
NoFanBoiz   100 W
Re: DENGFU E10 blue
Post by NoFanBoiz » Jan 27 2021 5:16pm
Hi
Do the Bafang M500 and M600 cranks take 9/16" pedals or some other size?
Is it Merida cranks that can be swapped out with the Bafang cranks if you want shorter cranks?
patdam   1 W
1 W
Re: DENGFU E10 blue
Post by patdam » Jan 27 2021 5:43pm
merida or miranda ?
At the moment I do not found other arms than OEM in 170 (possibility to reduce to +- 150), they are not in classic ISIS (specific bafang). Miranda or lekkie have sayed "in study". But In fact not necessary with 160 travel and 29" (360 of BB height)
NoFanBoiz   100 W
Re: DENGFU E10 blue
Post by NoFanBoiz » Jan 27 2021 6:58pm
patdam wrote:
Jan 27 2021 5:43pm
merida or miranda ?
Ah, miranda it is!
Thought I had seen discussion about Bafang compatible crank arms before:
viewtopic.php?f=28&t=105148&p=1537782&h ... s#p1537782
NoFanBoiz   100 W
Re: DENGFU E10 blue
Post by NoFanBoiz » Jan 27 2021 7:04pm
Do the Bafang M500 and M600 crank arms take 9/16" pedals or some other size?
DaDo.Bzz   100 W
Re: DENGFU E10 blue
Post by DaDo.Bzz » Jan 30 2021 11:48am
E10 really good frame
LMX 81, 16S6P 60A
patdam   1 W
1 W
Re: DENGFU E10 blue
Post by patdam » Jan 30 2021 4:54pm
I think so. even if I does not use it much for the moment, but it will well finally stop to rain at one moment when i do not work.
M500 or M600 ? your advise about rigidity ?
Fric   1 µW
Re: DENGFU E10 blue
Post by Fric » Feb 15 2021 7:11am
Hello!
Does anyone know where can I buy this frame? I'm looking on Dengfu website but the E10 model is not available :/
Thank you!
patdam   1 W
1 W
Re: DENGFU E10 blue
Post by patdam » Feb 15 2021 1:00pm
The best way is to send a mail to the contact available on the site
waynebergman   100 kW
Re: DENGFU E10 blue
Post by waynebergman » Feb 15 2021 1:17pm
Also Dengfu may not get back to you for a while as its their New Years and I think they are shut down for the celebrations. I want to order a battery myself and I have written on my Calender to wait till Jan 18 to inquire.
