Bullfrog,
The ESC (motor controller) will actually take 72V Nominal (~90VDC) and up to 90A, but we have never tested the system that high due to our preference for commercially-available battery packs. Most likely the motor will burn out at those power levels anyway
50A is about what our pack BMS's max out at, I think we may have access to 25Ah packs with higher amperage headroom soon though.
Phase amps, you'd have to ask my team-mates... I don't usually dabble with ESC programming myself (mechanical, mfg, production are my jam)
Motor torque at the output sprocket is around 200 Nm, there are two fixed-ratio reduction stages between motor core and rear wheel (no gears to change, not necessary).
The motor installs into the same frame-bracket as Ultra motors, it cannot be installed into a pedal-bikes bottom-bracket. The system is designed for PAS, but can be operated throttle-only (we commonly do, with twist throttles, for off-road use)
