BBSHD mod firmware
password
Hi,
Managed to flash 52V firmware.
Otherwise original firmware only amperage and low voltage cutoff modified..
The firmware bafang pushes with 28A limit is useless if 52V battery, no decent power gain to justify the rarer voltage.
Why is 48V version of firmware prioritizing throttle while pedaling and using handthrottle to give boost and 52V version makes decides to prioritize pedaling and if at same time full hand throttle it gives hits to drivetrain?
Does someone have newest 52V or is the older 48V version better?
Hi,
Will flash 48V firmware and use it instead, battery bar may be wrong but voltage is enough.
Overall i think initial settings on BBSHD were very dangerous for forest drive and nothing has changed troughout the years from my last build with same motor.
Since hills require high power but tap on pedal will give max on max pas.
+ throttle is only full power on max pas if bafang tool is not used to configure better...
Does someone know 52V version of firmware that prioritizes throttle over pedal?
