bonbond
- Joined
- Sep 5, 2020
- Messages
- 17
Hi all!
I’ve pretty much finished my M620 build, the only thing I need is the battery..
The motor has a 48v sticker on it, it’s the UART version, so I can easily change the low voltage parameters.
I’ve read here that a 48v M620 can easily handle voltage from a 52v battery. I’ve also read that the 48v and 52v units are identical, the difference being in their programming.
Can anybody confirm that I’m safe to run a 52v battery and/or that the motor hardware is the same between 48v and 52v versions?
Cheers
Cheers
