RC throttle interface build tutorial........
adrian_sm   10 MW
Re: RC throttle interface build tutorial........
Post by adrian_sm » Oct 10 2011 3:30pm
Hi,
Is it possible that it is all working perfectly, but the CC ESC just needs to be taught the new throttle range. I haven't used CC ESC but for my ESC's you have to:
hold full throttle, turning on the ESC, waiting for some beeps, then adjusting to minimum throttle, more beeps, then it is done.
Hope it is this simple.
Otherwise it sounds like the servot tester is getting 5v in the right spot if the LEDs light up. Do you have a multi meter to check voltages? If so check that you are still getting GND & 5V through to where you plug in the throttle. Then check the signal voltage as you adjust the hall throttle.
Good luck.
- Adrian
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive
Build #??? ~21kg ~1500w Adrian's Bafang BPM Hardtail MTB Bafang BPM code12, 15s LiPo, ~40kph, ~30kms
AussieJester   100 GW
Post by AussieJester » Oct 10 2011 5:23pm
Hall throttles without modification don't seem to work with this setup, hyena tried it at my place all it was successful at doing was smoking the servo tester and making the motor run WOT.. Magura throttles are pot throttles, also 10000 times better built than the cheap crappy hall throttles ack, can't understand people using them tbh
KiM
Hillhater   100 GW
Post by Hillhater » Oct 10 2011 5:45pm
several people and myself , have used hall throttles without any issues, using the simple mod to the servo tester.
AussieJester   100 GW
Post by AussieJester » Oct 10 2011 5:53pm
Didn't work when Jay did it, I still have the remains
Of a servo tester as a result. It worked for like 5 seconds, we cheered
Then our joy turned to despair when it popped..same servo tester had been in use with
A magura throttle previously, rather than ripping the magura wiring apart to use it again (was wired to the infinion at the time) we used one of the crappy hall throttles I had laying about...any ideas what would cause it? Didn't just stop either, it went pop Blew a cap on the tester...was Astro servo tester to, not one of the hk cheapies.
KiM
P.s smoked the hvbec to! Also still have that if pics help?
Hillhater   100 GW
Post by Hillhater » Oct 10 2011 6:31pm
sorry Kim, but i am no sparky geek type..... More of a hammer and hacksaw type guy ! :lol:
I just tinker with a soldering iron for fun, and got lucky with the servo tester mod..but it is still working !
AussieJester   100 GW
Post by AussieJester » Oct 10 2011 6:38pm
Haha yup, sort of the same boat, cept i'm a angle grinder/Welder type I must admit I enjoy a good hammering though :mrgreen:
KiM
adrian_sm   10 MW
Post by adrian_sm » Oct 10 2011 8:05pm
I have done this mod with hall throttles too, worked a treat. Only issue was if the throttle was disconnected, current leakage would slowly cause the throttle to creep up. Not an issue if it is hardwired in, but definitely an issue if you have a connector that could come loose.
AussieJester wrote:any ideas what would cause it? Didn't just stop either, it went pop Blew a cap on the tester...was Astro servo tester to, not one of the hk cheapies.
KiM
If it was blowing things up it sounds like it may have been wired up wrong. Those pics might help.
- Adrian
jawshnitzel   1 mW
Post by jawshnitzel » Oct 10 2011 9:44pm
well, i ordered the new parts, and decided to leave it for a while..... then cleaning my shop up i came across the unassembled servo tester and put it back together... then embarassingly noticed i hadnt cut the tail off the jumper wire from under the board and it was JUST long enough to short to the case... ha ha ha... embarassing....
soooooo, i just tried it again, and it seems my throttle is working now. running the signal wire through about .4v - 4.6v... or thereabouts...
buuuuuuut, now my motor just jumps WILDLY back and forth when i touch the throttle. just like it did when i attempted to try the "auto" setting on the servo tester. jumped wild.
i havnt changed ANY wiring since it all worked on my porch, same motor leads still soldered to the CC160 leads.
closer... ha ha ha.... im going to do some more research on the matter. just thought id touch base on my progress.
shnitz
hotschott   10 µW
10 µW
Post by hotschott » May 06 2012 6:53am
Up!
I need your help because I want to use a servo tester with a hall effect thumb throttle on my new project.
The thumb throttle I bought has a led battery gauge, so is it possible to make this gauge work while using a servo tester?
This is the throttle: http://www.alibaba.com/product-gs/24146 ... kable.html
Sorry for my bad english ;)
Dauntless   100 GW
Post by Dauntless » May 27 2012 8:22pm
So this is one of favorite threads up here, for all the work being done and for the technical extremes of Sir Jeremy's exotic work and Hillhater keeping it simple. So I'm assuming this is the Magura Twistgrip in question. http://holmeshobbies.com/product.php?productid=280 And this is as cheap as I know a Hall Effect Throttle to come. http://holmeshobbies.com/product.php?pr ... =32&page=1
Here's where I figure I can put this to work. The motor and controller, with shipping, I think was just over $30. And just powerful enough for the 7 year old nephews' bike. Gotta build a little more powerful one for the Dad, at least a 24 v.
http://www.leaderhobby.com/product.asp?ID=9394001224131 Yep, 12v.
http://www.leaderhobby.com/product.asp?ID=9394001070004 I'm thinking you have to overkill with the controller size or it'll kill you.
eBay has the cheap servo tester, $2.93 with free shipping. http://www.ebay.com/itm/3-CH-4-8-6V-Mul ... 46022f4348 (Item number: 300684362568 if the link doesn't work.)
They're in another state, they gotta find their own bikes, but I pointed them in the direction of one of these for $50 on Craiglist. Great dirtbike, eh? Maybe they can find one for the not so tall Dad.
Less than $200 to build a dirtbike with a fairly light drive. Let's see you do that with a brushed motor. (Seriously. put it up there and I'll look.)
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
Hillhater   100 GW
Post by Hillhater » May 27 2012 8:51pm
I think you may be more than a little disappointed with the performance of that 35mm motor on an Ebike.
Even on 12 v , its 1250kV will need an enormous reduction to get it to a useable rpm, and that reduction will consume most of its available power. Not to mention hooking up a drive to its 4mm shaft !
Go with a low kV 63 mm motor at least.
And good luck with those cheap aero ESC's !!
Dauntless   100 GW
Post by Dauntless » May 28 2012 1:09am
Oops. I think you missed where I said it's for a 7 year old. Disappointing performance is good for the moment. We can upgrade a few years from now. Or maybe his sister gets big enough to ride and he gets something else. I'm thinking 6364 lined up for his Dad. Yeah, I'd like a bigger shaft, but a small enough motor for a little kid means small everything. But it's an outrunner so there's screw holes on the revolving housing.
Ah, 1933. A time when a kid that age could have a motorcycle that went 40mph, even before the feet reached the shifter or the foot brake. As the article says, 'Keen Thrills.'
- Arthur C. Clarke
Hillhater   100 GW
Post by Hillhater » May 28 2012 4:53am
I just dont see that motor even moving the bike ......even with no rider. !
Why not just use a proven low kV, motor and restrict the power ?
That way you avoid the rpm reduction problem and get a durable motor.
Dauntless   100 GW
Post by Dauntless » May 29 2012 1:56am
Hillhater wrote:I just dont see that motor even moving the bike ......even with no rider. !
Well, I'm easily convinced. How do you restrict the power without creating a heating problem in the motor? And I read so much about the controller fried when it output less than the motor wanted to draw.
- Arthur C. Clarke
Hillhater   100 GW
Post by Hillhater » May 29 2012 5:55am
Most modern RC ESC's & Ebike controllers have programmable current limits .
roblenderman   1 mW
Post by roblenderman » Jul 13 2012 10:38pm
Small issue I cannot figure out. I have the turnigy ST and I jumpered the signal pin on the input(throttle side) to the input on the ST POT(lead opposite the LED's when looking from top). This essentially means the throttle controls the speed but I can control the top speed via the ST pot since it is second in line after the throttle. This is a new build so I want to be able to control the top end if needed. You do have to clip the lead from the board to the POT so that the normal + voltage is not the input but rather the voltage from the throttle is the input. The issue is that if I turn the ST POT all the way up the motor spins at a very slow speed even though the throttle is not touched. The only way to get it to stop is to turn the ST POT down about 1/4. Then the throttle works fine BUT the measured watts on the motor at max with no load is 43 watts vs 53 watts when I just use the ST alone and jumper the throttle side + with the signal line as though it were full throttle and no resistence beign added. So why would the throttle being in place cause a slow turn on the motor of a few hundred RPM?
At first we thought the throttle was just not providing a low enough voltage to the ESC to stop the motor but it output roughly 0.93 volts at idle and the ST POT when used along outputs 0.89 which seems to be so close that it would not make a difference? Any idea how to stop the low end spin and still keep the high end speed? Obviously I could just turn down the max but who wants to do that?
Rob
adrian_sm   10 MW
Post by adrian_sm » Jul 14 2012 9:04am
Sounds to me like you need to teach your ESC the throttle range.
Usually this is done by holding the throttle @ 100%, then powering up your ESC. It should make a few beeps, then turn the throttle down to 0%, more beeps. Now the throttle range should be set.
Hope it is just that.
Good luck, Adrian.
mrderekcu   1 mW
Post by mrderekcu » Jul 15 2012 1:51pm
Don't mean to post my problem multiple times, but this is the most relevant thread to my issues.
I bought this servo tester
http://www.hobbyking.com/hobbyking/stor ... duct=11780
Did the mod with the hall throttle, but it's actually backwards. Pulses seem to go from 2.0ms to 1.5ms. I put a servo on and forward with the hall throttle is actually backwards with a regular servo tester
I got a universal hall throttle from tnc scooters. I'm assuming I just need to go find a different servo tester? Only reason why I bought this different one was due to stock.
roblenderman   1 mW
Post by roblenderman » Jul 15 2012 11:11pm
You nailed it. I put the St between the throttle so I could control the toop and and in testing I was starting everything with it turned all the way down. That threw off the range. If you just start with it turned all the way up or where ever you want to set the max it all works fine.
Rob
roblenderman   1 mW
Post by roblenderman » Jul 19 2012 10:51am
Ramping question now with this setup.
I have everything working perfectly but the startup is brutal with the 6s and 6374 on an 11T to 90T setup. I am able to slowly turn the throttle and get going almsot every time but I have to be careful. I built the throttle ramp found here http://www.instructables.com/id/The-New ... ignalling/
In sumulation it works perfectly but in real life it does not work. With the 100K the thrittle never works. With a 50K the throttl ramps but the max watts unloaded is 12 watts and normally it is 50 watts. The output throttle voltage is 4.7V but after it goes through this ramp circuit it is barely 1V with the 50K resistor and more like 0.5V with the 100K. Any ideas why this circuit would not work? I can always keep ging down on the resistor but the advice on the post and the simulations say that is not the right thing to do.
Rob
adrian_sm   10 MW
Post by adrian_sm » Jul 19 2012 7:15pm
I don't know about that circuit, but I do now one of these works well. It will allow you to adjust the ramp up, and ramp down. Just place it between your servo tester and ESC.
http://www.hobbyking.com/hobbyking/stor ... oduct=8863
roblenderman   1 mW
Post by roblenderman » Jul 20 2012 12:24pm
Already orderd that just in case. Turns out the load is higher than expected and I need to drop the resistor to a much smaller number. I will test it today. Total cost to build is $0 if you have the parts and $1 if you don't.
Rob
roblenderman   1 mW
Post by roblenderman » Aug 30 2012 7:21pm
So I got the turnigy ramping circuit. Seems to work with no load on the motor just fine but when I stand on the scooter and try to go it stutters. It starts to ramp and then seems to shut off for 1/2 second and then starts to ramp again for 1/2 second. Does this over and over until I release the throttle. System works fine without the circuit and have been riding for a month. I have to control the ramp manually but everything works. Even slightly turning the throttle with this circuit causes the stutter. Any ideas?
Rob
adrian_sm   10 MW
Post by adrian_sm » Aug 31 2012 1:52am
Don't know never seen that happen, and I don't use them anymore so not sure if I can help.
It sounds a bit like the motor is loosing sync, which can happen when you accelerate too hard. If you think that might be true, then adjust the ramp up speed to slow things down. Also check that the throttle limits are still correct on your ESC, you know how you teach the ESC what max and min throttle is.Not sure if this will cause issues, but always good to get it done properly.
roblenderman   1 mW
Post by roblenderman » Sep 05 2012 10:08pm
Not 100% sure how to set the throttle limits. I did try slowing it down but it didn't help. What is strange is that without the circuit things are fine. In fact it accelerates so quickly I will fall off the back if I stand up straight and don't hold on. It seems to only happen with the circuit and when weight is on it other than the scooter weight itself.
Rob
