RC throttle interface build tutorial........
AussieJester   100 GW
Re: RC throttle interface build tutorial........
Post by AussieJester » Sep 20 2010 8:06pm
Hillhater wrote:
Jeremy Harris wrote:OK, I've had a go at making a simple Picaxe interface this morning.
...... Here's a quick description of what I did.
Jeremy
Your knowledge and abilities exceed even my capacity to understand WTF you are saying !!! :shock: :lol: :lol: :wink: )
.... but it sure sounds like a good idea !
ROFL...don't worry...Jeremy's words and actions have that effect on alot of people, in fact hahaa, I should probably
be the president of the 'WTF is Jeremy Saying' club :mrgreen:
Keep up the good work Jeremy....i think, your not making weapons of mass destruction are you? :shock: :mrgreen:
You remind me of this chap you have something else in common
too, he was also on a episode of Scrap Heap Challenge, he helped one of the teams build a pulse jet.
KiM
Jeremy Harris   10 GW
Post by Jeremy Harris » Sep 21 2010 1:29am
Thanks for the kind words and sorry for the furrowing of brows I've caused................
In essence, all this chip is doing is reading the value of the voltage from the Hall throttle and directly converting it into the right type of pulsed signal to drive an ESC. It helps not to think about the chip as a microcontroller, but just think of it as a very versatile electronic building block that can convert signals from one form to another, in pretty much any way you want, just by changing a few lines of code, rather than by changing components.
BTW, I know Bruce. As well as being a fellow Scrapheap expert, he's also done some pretty remarkable stuff with pulse jets. I managed to scare the **it out of some folks where I used to work when I showed the anti-terrorist team his 'Build a cruise missile for less than $5000' site a few years ago. Even better are some of his other pulse jet projects, like the pulse jet powered go kart. I bet his neighbours love him as much as the CIA and NZ government (anyone who's heard a pulse jet run will know what I mean.........).
There must be something about Kiwis that makes them even more eccentric than us Brits, this guy: http://www.asciimation.co.nz/ for example, is another Kiwi with way too much time on his hands and some truly brilliant projects (check out the turbojet-powered beer cooler...........).
Jeremy
AussieJester   100 GW
Post by AussieJester » Sep 21 2010 1:41am
^^LOL i spotted the jet beer cooler few years back
such a complete waste of money and time...i so want it hahaha
KiM
full-throttle   10 MW
Post by full-throttle » Oct 06 2010 8:09pm
Looks good Jeremy,
I would right-shift by 7 (essentially divide by 128) instead of
Code: Select all
ppm_output = ppm_output / 130
ie
Code: Select all
ppm_output = ppm_output >> 7
Jeremy Harris   10 GW
Post by Jeremy Harris » Oct 07 2010 2:15am
full-throttle wrote:Looks good Jeremy,
Code: Select all
ie
Code: Select all
Shift right isn't a valid operator on the 08M Picaxe, plus the divisor needs to be 130 to get the correct value of pulse width.
Jeremy
full-throttle   10 MW
Post by full-throttle » Oct 07 2010 11:04pm
You right - had a quick look at the instruction set, my bad.
bandaro   10 kW
Post by bandaro » Oct 14 2010 11:49pm
ok, got my throttle up and running, and i can confirm that for the electrics i got it works. i used the same jumper method in the picture a page or so ago on a turnigy servo tester, and the cheapest hall effect throttle i could find.
throttle i got (10 bucks posted on ebay):
http://cgi.ebay.com/ebaymotors/Razor-El ... 4496wt_939
servo tester (the turnigy one for 6 bucks, jeremy said they may change the electrics, but the ones they were supplying a month ago work):
http://www.hobbycity.com/hobbycity/stor ... oduct=8296
am yet to test the final rpm (need a few more parts as i only have the cycle computer to measure speed, then deduce rpm) but the esc has a little led in it that lights up at about 90% of the twist, so i am taking it this led means that the esc is full throttle. otherwise it seems smooth and consistent with the more twist it gets.
total cost for parts shipped to your door would be less than $20, then you will need a 4-6v power source (ubec) for the servo tester, as you would if using the magura throttle. for any interested i am just using the cheapie k-force 120 esc for now, see how it holds up for my first build.
Hillhater   100 GW
Post by Hillhater » Oct 15 2010 12:38am
Bandaro,
just a tip ...
on the Turnigy servo tester, i "clipped" off the top of the "mode" button (so that it is below the surface of the enclosure),to prevent accidentally engaging "Auto" mode when you are running ! :shock:
bandaro   10 kW
Post by bandaro » Oct 15 2010 1:39am
lol, good to see your on the ball hillhater, but dw, i already trimmed that button off and taped the whole thing up ready to shove into a box :D
Hardcarve1   100 W
Post by Hardcarve1 » Oct 15 2010 2:50pm
If I want to use the turnigy ST on a CC 110 HV using a hall thumb throttle I will need to use a BEC. How would we wire the BEC into the servo tester? would it be similar to how Matt has done his?
I got lost in what Jeremy was saying which I think was about this. If anyone could do give some explanation as I have ordred the turnigy and would like to have a go at wiring it up.
Cheers
When in doubt, REV!! it out.
MTB commuter Black Surley troll 26' 9C HUB Vented & upgraded phase wires, 16s A123 11.5ah
MTB commuter Orange Surley troll 26' 9C HUB Vented & upgraded phase wires, 16s A123 9.2ah
MTB - HXT80-130 direct drive through staton 1:18.75 gerbox, HV160 ecs, Nuvinci hub, 12s A123 9.2ah (retired)
MTB - 9C stock, 12 fet Lyen, 9 speed, 16s A123 20.0ah, 2000lm LED ebike lights.[retired]
Line trimmer - HXT80-130, HV110 ecs 12s A123 2.3ah
bandaro   10 kW
Post by bandaro » Oct 16 2010 2:15am
for mine i simply plugged the bec into one of the 3 servo places, right under where the esc went in.
means the power is being put in "reverse" direction but it is all the same.
Hardcarve1   100 W
Post by Hardcarve1 » Oct 16 2010 4:56am
I see it now, I thought their was just one input & output but I can see the multiple plug points.
Thanks
Wheazel   10 kW
Post by Wheazel » Dec 03 2010 11:16am
This thread is full of awesomeness. Thanks for the tutorial.
Input regarding availability in Europe is appreciated. Only seem to find american sites selling the throttle.
Brushlessboy16   100 mW
Post by Brushlessboy16 » Dec 03 2010 9:38pm
Depending on your input voltage
This unit is good for 10s Lipo input
http://www.hobbyking.com/hobbyking/stor ... duct=10313
Very cheap site and they have many warehouses around the globe :)
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Post by recumpence » Dec 05 2010 2:36pm
Hey Guys,
I wanted to post a quick update..........
I spent the morning building a bunch of throttle interfaces. All pending orders are filled and I have two throttles finished in stock. :)
Sorry for the delay. I had an issue with regulators and a couple other minor details. I am up to speed again, however. :)
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
deVries   1 MW
Post by deVries » Dec 05 2010 4:44pm
bandaro wrote:ok, got my throttle up and running, and i can confirm that for the electrics i got it works. i used the same jumper method in the picture a page or so ago on a turnigy servo tester, and the cheapest hall effect throttle i could find.
Hi Bandaro, just thought I'd check-in to see how the rpm range worked with this setup? You got full range & good control w/throttle you bought? Also, how is that 120 k-force ESC working? Did you add extra caps or mod it?
Thanks! :mrgreen:
HumboldtRc   100 W
Post by HumboldtRc » Dec 05 2010 10:41pm
recumpence wrote:Hey Guys,
Matt
What all do your throttles consist of? What features do they have?
I just finished mine, with a 0-5k sliding pot (in a custom cable throttle box) to a Turnigy servo tester to a servo speed regulator then to the esc's.
Hillhater   100 GW
Post by Hillhater » Dec 05 2010 11:42pm
what does the .."servo speed regulator" ... do for you ??
recumpence   100 GW
Post by recumpence » Dec 06 2010 8:19am
Matt
It is a simple PWM board with 5v regulator to power it in a water resistant heat shrinked package with a Magura twist grip throttle. :)
It is a tried and tested design. All units are hand built and bench tested before shipping.
Matt
LI-ghtcycle   1.21 GW
1.21 GW
Post by LI-ghtcycle » Dec 10 2010 1:27pm
Wow, good stuff in this thread!
I wanted to get some advice on two parts however.
1) I had some real trouble removing the Servo Tester POT even with my 60W iron (I tired it first with my 30W to avoid getting things too hot) and I am still not 100% sure that I didn't damage the PCB in the process, I have been considering getting a "vacuum bulb" designed to suck away the solder, but for now I have been using the heat and tap method, and also tried by heating all three leads at once on the POT, but I REALLY struggled to get it loose even when I had all the leads just sitting on the PCB. Is there something I am missing? I have to work in a pretty cold (about 55 DEG F) garage, maybe that is part of the problem.
2) I am unclear about weather or not I should be fine using the BEC on my ESC to power the Magura Throttle, or if I will still need to add an extra BEC to power things?
Oh, one more thing, I got to wondering since using the extra POT that I removed from the ST, if I understand correctly using it as a "throttle limiter" restricts total voltage, and say if I wanted to run 8S and regulate down the speed, that although it wouldn't regulate amps, would I not be able to have it regulate the voltage down so that it could at as if I were just running 6S while under higher load (climbing hills) and then turn it back up for a long flat stretch. Am I correct in my understanding?
Thanks! :)
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
Back on track E-Bronco! Now with Cro Motor Mid-Drive Goodness!
https://endless-sphere.com/forums/viewt ... 28&t=44997
Vision R40 w/3000w MXUS as mid-drive, NuVinci N171B rear wheel as transmission, Silent yet powerful, running 72v 11.6 ah (20s 18650 Li-Ion) to climb hills, tow trailer with zero pedaling when needed!
https://endless-sphere.com/forums/viewt ... 28&t=75247[/size]
adrian_sm   10 MW
Post by adrian_sm » Dec 10 2010 3:27pm
1) I am a soldering idiot, and couldn't desolder the POT. So I just got got some side cutters and cut each leg on the POT. POT fell off. Job done. :D
2) ESC BEC should be fine.
3) Give it a go. Put a POT on the 5V rail into the magura throttle POT (you can use the one you clipped off).
One thing to note is that your ESC will have a bit of a harder life, running at partial throttle on 8S, rather than full throttle on 6S, since it will be generating more heat by having to PWM more to reduce voltage at the motor.
Good luck.
- Adrian
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
Build #??? ~21kg ~1500w Adrian's Bafang BPM Hardtail MTB Bafang BPM code12, 15s LiPo, ~40kph, ~30kms
recumpence   100 GW
Post by recumpence » Dec 10 2010 3:35pm
LI-ghtcycle wrote:Wow, good stuff in this thread!
Thanks! :)
If your ESC has a BEC that is functional at the voltage you are running, you do not need to add one to your throttle. You just need the PWM board (servo tester) and the throttle in place of the POT.
Oh, BTW, I just clip the POT legs too. Trying to desolder them is a pain..........
Matt
LI-ghtcycle   1.21 GW
1.21 GW
Post by LI-ghtcycle » Dec 10 2010 7:04pm
Ahhh, that makes sense! Unfortunately my particular brand of ST wouldn't have made it any easier to clip the legs of the POT. Not enough room in there. I'll have to try again with one of the Turngy ST's like Hillhater bought from HK (assuming his one wire mod would work the same for a POT throttle?) if mine is too fried.
LI-ghtcycle   1.21 GW
1.21 GW
Post by LI-ghtcycle » Dec 11 2010 1:19am
IT LIVES!!!! :D :D :D
I guess my solder torture wasn't too bad, I fired it up with the throttle and got a satisfying "turbine whine" from my new motor!
Thanks again everyone! 8)
LI-ghtcycle   1.21 GW
1.21 GW
Post by LI-ghtcycle » Dec 12 2010 12:13am
Ok, now I'm puzzled, I have the ESC and motor wired properly, but the motor is going backwards. Could I have 2 leads reversed in the throttle interface? I guess I could always swap the neg and positive leads from ESC to motor, but I'd rather figure out what is causing this and fix it properly.
Any ideas?
Thanks!
