14kw continuous 94% efficient motor.......
johnrobholmes   1.21 GW
1.21 GW
Re: 14kw continuous 94% efficient motor.......
Post by johnrobholmes » Feb 10 2011 11:26pm
That would mean my KV may be closer to 70... I need to tach my motor and see where it is falling at no load.
crap   100 µW
100 µW
Post by crap » Feb 11 2011 4:13pm
So what was the no load losses at these rpm's?
katou   10 kW
Post by katou » Feb 11 2011 6:28pm
Reveal WHAT project details? I've been following this since it's inception, is there a secret project being built around this motor or something?
So, in sum, what project are you NOT building? I'm confused.
Katou
1.21 GW
Post by johnrobholmes » Feb 11 2011 7:53pm
I don't know much, but I can tell you it is probably some top secret project for a racing circuit.
katou   10 kW
Post by katou » Feb 11 2011 10:30pm
Probably a hovercraft. They are soooooo sick. Racing hovercraft? Even better.
Katou
coleasterling   100 W
Post by coleasterling » Feb 13 2011 8:08am
Yes, there is a secret project. No, I can't reveal the details. I will say that the info is out there. The motor will get the final hall mount (custom machined and etched pcb) soon and will get load tested soon after that.
magudaman   10 kW
Post by magudaman » Feb 15 2011 11:48pm
Any word of availability for us non racing normal folk?
Electric Motoped:
10kw Mars Brushless Etek
16s1p A123 AMP20 Pack
Kelly Ebike Brushless 350a/10kw
recumpence   100 GW
Location: On Earth right now. That can change at any time, though..........
Post by recumpence » Feb 16 2011 2:12pm
Once final testing is done by my Beta testers :wink: , I will look into production!
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
j3tch1u   10 kW
Post by j3tch1u » Feb 16 2011 2:33pm
recumpence wrote:Once final testing is done by my Beta testers :wink: , I will look into production!
Matt
looking forward to it :!: :!: :!:
coleasterling   100 W
Post by coleasterling » Apr 12 2011 9:11am
So we've had A LOT of setbacks, but we're finally ready to do serious load testing. The battery guys just now got the battery ready for us...There will be some fun stuff coming soon!
gogo   10 MW
Post by gogo » Apr 12 2011 1:50pm
coleasterling wrote:So we've had A LOT of setbacks, but we're finally ready to do serious load testing. The battery guys just now got the battery ready for us...There will be some fun stuff coming soon!
Wait, let me guess, the battery is from EEStor? :mrgreen:
"A conclusion is the place where you got tired of thinking." -Steven Wright
coleasterling   100 W
Post by coleasterling » Apr 14 2011 2:36pm
This thing is a BEAST. You guys who are thinking of putting it on a bike are crazy!(in the best way possible...this is coming from a person building a 175hp Amod style car that weighs 450lbs). I still can't share details, but testing has started out really well. With the kind of power we're putting to it, it gets hot quickly, but cools down relatively quickly as well because of the low thermal mass.(compared to something like the Perm 132) It would be pretty much perfect for liquid cooling(the can is perfect for it) and I am considering doing it for our project.
The hall sensor solution works great and even the controller is doing well. We're going to start data-logging soon, so maybe I'll have some graphs of current, voltage, temp, rpm, etc... for you guys.
Lastly, I think 14kW is pretty accurate. I'll have to do some more testing to see just how long it can do it, though. If we're talking continuous as literally non-stop all day, then no, it won't do that. It will get heat soaked and all sorts of bad will happen. For an automotive type project where the duty cycle at full power is relatively low, the first loaded tests have me thinking it will do just fine. We tested at a max of 200A last night and will be doing up to 400A as soon as our batteries get cycled a few times. Bottom line, looks great so far!!
Arlo1   100 GW
Post by Arlo1 » Apr 16 2011 12:06am
Awesome cant wait!!!
My Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
My YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
RC and most types of Lithium batteries you MUST know your individual cell voltages charging and discharging.
Don't keep them were you cant afford smoke or fire!
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
coleasterling   100 W
Post by coleasterling » Apr 24 2011 7:44pm
Well, I've got some really bad news for you guys. We blew the motor. We previously tested at 400A and 120V without issue. While it got HOT(outside can never got over 200F) , it seemed to be just fine. We tore the motor down and there were no indications of problems after that run. I'll have to let the cat out of the bag here and say we were running it on our Formula Hybrid car.
Our overall configuration was this: We coupled the motor to a planetary gearbox and from there it went to the diff. The drivetrain team was having issues sealing the gearbox and it had leaked some oil into the motor. We cleaned it out the best we could by blowing air through it, but the gearbox just leaked into it again. So, we cleaned it out again. Third time, apparently it leaked REALLY badly. We were doing an acceleration run and POOF. Black smoke. We pulled the motor off and on the bottom side, right where the oil would puddle in the motor, was a short in the windings that turned into a huge, 1/8 inch gap of missing windings. I think that the oil degraded the coating on the windings enough to where it finally just shorted and blew.
We ended up putting the Perm 132 and controller from last year on the car overnight...gaining around 15lbs in the process. Accumulator, by some miracle, got the pack reconfigured for the new power specs I gave them in just about 6 hours. Funny when it took 4 months to get it put together before...Anyway, I did some emergency machining and we are now running as a Hybrid again. We're going to be a bit slower and a bit heavier, but at least we'll be able to compete.
I apologize for not being able to get more data to everyone about the motor's performance. Let me tell you though...It really is a fantastic motor. Without the Drivetrain issues and with more testing, it would have been great. It ran REALLY well when it was running. Unfortunately, we also had some Kelly controller issues at high currents. Surprise... :roll:
My advise is this...Absolutely run this motor. Don't run a Kelly. We ran it because Kelly is the only company who had a controller with our specs and who would pay us any attention. Oh, also, while the super shiny motor looks great, it isn't so good for heat transfer. We sandblasted the can and it lowered motor temps several degrees with absolutely no other changes. It is definitely worth it to do this. I'll post pictures up when I can.
-Cole
coleasterling   100 W
Post by coleasterling » Apr 27 2011 12:44am
And this is what it was going on:
wojtek   10 kW
Post by wojtek » May 06 2011 4:06pm
wow that is sooo cool!
Matt- any news on the 14kw motor available for sale yet? :twisted: :mrgreen:
WIRES AND CONNECTORS
http://www.endless-sphere.com/forums/vi ... 31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
KMX Cobra with Xlyte 5403
Go-One Evo with Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Giant CRS Alliance - yes, just pushbike! frock you..
3Element Espire - SOLD
Custom built Specialized BigHit with BBS02 - SOLD
Velokraft e-VK3 SOLD
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
ELECTRICMOTION   1 µW
Post by ELECTRICMOTION » May 08 2011 6:17am
hi
how can i do?
coleasterling   100 W
Post by coleasterling » May 09 2011 1:27am
Here are a few pictures of how it was set up.
And how it ended up when we rebuilt the rear end for the perm:
By the way...We dominated the competition!! 2011 FH World Champs!!
wojtek   10 kW
Post by wojtek » May 09 2011 2:51am
really impressive stuff!
RESPECT!
coleasterling   100 W
Post by coleasterling » May 10 2011 12:30am
Thank you. It is the result of over ten thousand combined hours and over 1000 hours of my personal time. The car isn't perfect(especially without the soup can!!), but I am proud of it.
crap   100 µW
100 µW
Post by crap » Sep 01 2011 1:13pm
any progress on this motor, or has the project died?
recumpence   100 GW
Post by recumpence » Sep 01 2011 1:37pm
crap wrote:any progress on this motor, or has the project died?
We have other things happening right now. But, I can tell you this is not a dead project.....
Arlo1   100 GW
Post by Arlo1 » Sep 01 2011 2:27pm
Hey matt can you share any details on the controller and motor eg. The stator teath and mag polls? Inductance? Resistance? Controller type and resistance.
keetper   1 µW
Post by keetper » Nov 04 2011 2:31am
Yeah, that's particularly what i've been searching for in spy phone other threads. Would be cool, guys..
circuit   100 kW
Post by circuit » Nov 04 2011 11:27am
recumpence wrote:Here are the specs;
Can length--- 4.5 inches
Can diameter--- 3.75 inches
Shaft diameter--- 1/2 inch (keyway shafts will be used)
Expected efficiency--- 94% (more on this later)
Continuous power--- 14kw
Burst power--- 25kw
Weight--- Under 7 pounds (expected)
Oh, I expect the sensorless motor to be $950
Matt
What's the Kv rating and inductivity of this motor?
smart and Tiny BMS solution
Visit my blog. Personal projects: Clean Peugeot conversion | Ultralight enduro
Any and all information, such as texts, specifications, drawings or other material that I post are to be used only as a reference for personal, non-commercial projects ONLY. Any republication for personal or commercial needs must be agreed on individually. Use of any information, that I post, for commercial purposes is strictly prohibited.
