drewdiller
- Joined
- Nov 5, 2009
- Messages
- 172
I ride on a single speed Cute 128 rear hub with an Infineon controller. It tops out at 16 mph and I worry about driving it hard up hills (and, I wish it had more torque for more serious hill climbing ability).
I want to build another e-bike. This will be a snow e-bike, I want it trail worthy in November. Here is the bike I plan on buying, a TommiSea Terrain Destroyer. It's like a less expensive, less complicated version of a Surly Pugsley:
http://forums.mtbr.com/showpost.php?p=7054694&postcount=10 (I hope you are able to see it, I am logged in at the mtbr forums.)
Look at that huge space in between the rear tire, chain stays, and seat tube.
WHAT TO DO WITH ALL THAT WASTED SPACE**?
** sarcasm
Things that have occurred to me (keeping in mind that this is already a heavy bike, there is a lot of rim and rubber going on there, I believe 35 lbs as a single speed):
A) Run a cyclone kit through a NuVinci N360 hub.
Thoughts?
** sarcasm
- Pro: Power through gear ratios.
- Con: Noisy, I think. Haven't heard one in person.
- Con: Heavy (5.5 lb hub, 6 lb motor, plus battery).
- Pro: Conservation-minded.
- Pro: Not silent, but acceptably quiet, can't be heard 20 feet away.
- Con: Heavy, same as (A).
- Con: Uncharted territory, would have to make a custom mount.
- Con: How the heck to solve problem of driving two chains? Can get a freewheeling crank, but wouldn't a fixed cog just unscrew itself under load?
- Pro: Light!
- Con: Uncharted territory, never done RC before.
- Con: Noisy? Haven't heard it.
Thoughts?
