1) Torsion Spring
I have increased the spring stiffness. The last one was too light to take the torque of the motor weight.
This new one is better, still not right, and I might be able to make it adjustable with a screw rather than the current bend the spring to the right shape method.
I now have the drive tuned such that the motor just touchs the tyre. I might back it off a bit later, but it works for now.
Note: This was the method Kepler appears to use when setting up one of his eboostdrives.
- When the tyre spin forward it just drags on the motor but not enough to spin it.
- When you spin the tyre backwards the motor actually engages and spins.
3) My new back tyre is not round.
3) No Load Power Test
Now that I have the Cycle Analyst on the friction drive bike, I thought it was time to get some data.
So here is the no load power the drive requires just to spin the wheel.
Note 1: The no load power consumption of the motor alone at full throttle is ~52W.
So only about 12W for the light engagement friction drive loses, and to keep the wheel spinning.
Note 2: There is no load on the tyre, so the drive is only lightly engaging with the tyre.
When fully engaged the power required is a lot more. ie. 160W total at 66kph.
So about 100W more than minimal engagement. That is like ten times the losses. Yikes.
I think I might need to spend some time optimising the engagement.
Note 3: The ambient temperature was 22 deg-C, and the motor temperature stablise to about 49 deg-C after 10mins a full thottle.
This means a 27 deg-C temperature rise for about 50-60W of waste heat.
Will be interesting to compare this figure to other motors, as the motors ability to dispense heat is key to survival for light drives like this.
That's it for now.
- Adrian
