New thumb throttle makes a big difference in useability. It softened the engagement purely due to the time required to move the throttle. Also much easier to tweak the throttle to the amount of assist you want.
Managed to pull 80-100 amps according to the watt-meter. So 1600-2000 watts
After burning off about 3Ah from the battery, playing around on local streets the motor was warm to touch, controller had no obvious heat.
I think long term I would want to be able to restrict the max current, to make sure I don't overheat the motor lugging up a hill, in the lower inefficient range of motor speeds. Top speed seemed low, but this may due to me being used to my 80v hub motor ebike, that I usually cruise at 50kph on.
On a negative note, this is not a stealth bike, it has the typically RC scream. Not enough to scare pedestrians, but enough to turn heads. Guess I am spoiled with my direct drive hub motor, which has no really sound at all when cruising along. Also going over bumps causes the motor to bounce and touch the tyre, not a big deal but thought it worth of mentioning.
Really need to go for a decent length ride, and give it a proper shake down.
Getting pretty excited, this is definetely maturing into a really useable system. Meeting all the objectives I had. Light weight, cheap, good performance, minimal parts, easy to make, simple to use.
I also jsut weighed the bikes.
The road bike with the first prototype weighed in at 11.8kg (26lbs), and my heavier hardtail MTB, with prototype 2, with the heavier motor, weighed in at 15.8kg, or 35lbs. It is such a different experience riding a light efficient bike again, but still being able to get that 1000+w push.
- Adrian
