Commuter Booster - <1kg Friction Drive
adrian_sm   10 MW
Re: Commuter Booster - <1kg Friction Drive
Post by adrian_sm » Jan 11 2011 7:28pm
You are absolutely right. The two biggest mounting problems are:
1) Motor Size
As Kepler just mentioned in another thread, the 50mm motors just don't have the thermal mass of the 63mm motors. So they are inherently less robust.
2) Frame Space
A lot of modern road frames just don't have the space.
Add these two competing issues together and it will definitely restrict who can use the drive on their bike. Actually I might make a 2D template that can be printed to make it easy to see if it will fit a frame. Hmmm.
And finally the shifter cable problem. I hadn't mentioned that before in this thread, but some bikes do have the shifter cbales running down the back of the seat tube, rather than up from the bottom bracket. These cables are exactly where I clamp my drive. There are ways around it. But I need to have a look at a few more frames before I decide which solution I would chase.
- Adrian
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive
Build #??? ~21kg ~1500w Adrian's Bafang BPM Hardtail MTB Bafang BPM code12, 15s LiPo, ~40kph, ~30kms
LI-ghtcycle   1.21 GW
1.21 GW
Post by LI-ghtcycle » Jan 12 2011 12:26am
Good stuff! I love it when we get more improvements to design by sharing here!
I have to ask, though, what with the limited space in the placement of the CB, isn't it going to mean you have to choose to have more motor slip due to the angle at which the drive engages? If you tried to draw a straight line from the pivot, motor and rear hub, wouldn't the motor still be considerably under that line (meaning forward towards the front of the bike)?
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
Back on track E-Bronco! Now with Cro Motor Mid-Drive Goodness!
https://endless-sphere.com/forums/viewt ... 28&t=44997
Vision R40 w/3000w MXUS as mid-drive, NuVinci N171B rear wheel as transmission, Silent yet powerful, running 72v 11.6 ah (20s 18650 Li-Ion) to climb hills, tow trailer with zero pedaling when needed!
https://endless-sphere.com/forums/viewt ... 28&t=75247[/size]
adrian_sm   10 MW
Post by adrian_sm » Jan 12 2011 1:38am
Not sure. I think it was Kepler that said this is the optimum engagement, to be able to draw the straight line between motor pivot, contact patch, and wheel hub. I don't quite agree and have been setting up my drives to limit the travel before that point with success.
I think I outlined my reasoning in this earlier post. But I have not totally convinced myself so take it with a grain of salt.
I can still have the same amount of engagement with the tyre but at an angle. The allowable angle is dictated by the coefficient of friction between motor and tyre. Come to think of it this will be the worst when the motor is first coming in contact with the tyre when you will have the largest angle. This could be improved by increasing the radius at whcih the motor pivots. :shock:
Damn. That is a good argument for a longer pivot arm.
:D Funnily enough now that I have a single pivot arm, I could fairly easily do this by placing my pivot point infront of the seat tube, and having a longer pivot arm. Hmmm. It would increase weight, but may help avoid slip during initial pick up. But it would also require the drive to pivot further to have the same engagement into the tyre. So it wouldn't help trying to get it on smaller framed bikes. Damn.
From my understanding of the geometry, the most critical time it will slip is during initial engagement for the pivoting designs like mine and Keplers. Once it gets over that point the geometry will only be able to apply more contact force until it is limitted by a force balance, or deadstop. If you slip at the fully engaged position you would need to adjust the drive such that you acheive more engagement, ie. lower the drive, or adjust the deadstop.
To directly answer your question. Yes the geometry of the frame does limit the travel of the CB, and could restrict engagement. But you don't need to aim to have a fully straight line between motor pivot, contact point, and rear wheel hub. You can stop short of this and have just as much tyre engagement.
- Adrian
P.S. One of the other reasons I don't let the drive pivot that far, is that you see a drop off in the torque required to maintain the drive in that position as you get closer to the straight line. This means the drive suddenly accelerates its rotation towards the deadstop, and hit is with a bit of a clunk. I was previously just adding a dampening material to my deadstop, but by adjusting the geometry I effectively used the compliance of the tyre to do the job instead.
adrian_sm   10 MW
Post by adrian_sm » Jan 12 2011 7:59am
Update: Installation Tempalte
For those interested if this style of drive is even close to fitting your frame, I made a very rough template you can cut out and try.
I used the "Kepler" approach of engagement (every thing in a straight line), as this appears to require more travel then my approach, so the templates should be pessimistic.
Anyway if you do try it, please let me know if it worked or not. I am beginning to suspect a lot of frame will have issues with space or cables, and that I have just been lucky with mine.
- Adrian
Commuter Booster v2 - The “Will it fit my frame” Template - rev A.pdf
(691.14 KiB) Downloaded 499 times
hillzofvalp   1 MW
Post by hillzofvalp » Jan 12 2011 1:52pm
I have been working on the battery packs more recently, but I did get four ~7/4x1/8x4"arms made which have terribly drilled holes. Even when I used the whole punch it went off a little.
The club I'm participating in is new at Purdue University, and you can check it out at electricvehicleclub.org, which was only put up couple of months ago. Many of the senior members are affliated with Purdue's evGP electric go-cart racing, so I suspect my future prototypes will come together well after having gaining access to machinery and guidance in the engineering building.
Actually, the brand new machinery rooms at purdue are very sophisticated, and they even have job openings. I plan on applying soon so I can learn to use their cnc and maybe even their water jet machines someday. Pretty cool oppurtunity, and, if I major in Mechanical Engineering, it will look really good on resume ;).
LUCKILY, my frame is pretty big at 59cm, not to mention they're 1" 1/8" tubes, also giving me extra room. I will try out the template today and get back to you, but I still haven't ordered a motor or esc yet. Waiting to see what club thinks. Btw, could/did you experiment with different tire widths?
adrian_sm   10 MW
Post by adrian_sm » Jan 12 2011 3:37pm
hillzofvalp wrote: I did get four ~7/4x1/8x4"arms made which have terribly drilled holes. Even when I used the whole punch it went off a little.
Did you use a drill press, or hand drill? The motor mounts holes can be off a little, but you defintely want the pivot axle hole a very close fit for the pivot shaft, if you want to go for a single arm design.
Defintely get as much hands on experience at Purdue as you can. It will pay off. And you can get your own jobs done :D
Before you decide on your major, think long and hard about the type of job you would ultimately like. For what I am doing now, a mechatronics degree would have been better suited, than the Mech Eng/Bach Commerce I did.
As for the motor, the 6374 seems like a good cheap option. If you go smaller you will be restricting the power that it can reliably handle. So I would recommend the large 63mm motor, in as lwoer a kv as you can get, with the best bearings, and preferably a skirt bearing to internally support the motor can.
Tires. No other that switching between my mountain bike, and road bike. Both have worked. Thye both have a pretty smooth centre section for contact. I don't think I am getting close to enough torque to shear the rubber so a narrow road tyre doesn't appear to limit things too much.
- Adrian
hillzofvalp   1 MW
Post by hillzofvalp » Jan 12 2011 4:11pm
Ugh, I hate dealing with hobbyking. I wish I could get a cheap 63-74 in the US.
My question about tires is more along the lines of: Will a 28mm, wider tire, work better? Maybe ideal tires or tire pressures could be investigated. how much surface area contact is ideal?
I've got 20mm on my bike now (hehe a little small) but I've got some 23s as well.
adrian_sm   10 MW
Post by adrian_sm » Jan 12 2011 4:34pm
I have 23s on my bike. Worked fine.
As for ideal. I haven't spent much thought on it. I would prefer it to work on whatever is one the bike already.
One thing to note is that a wider tire is usually taller, which will restrict space for the drive.
- Adrian
Hillhater   100 GW
Post by Hillhater » Jan 12 2011 4:45pm
hillzofvalp wrote: My question about tires is more along the lines of: Will a 28mm, wider tire, work better? Maybe ideal tires or tire pressures could be investigated. how much surface area contact is ideal? .
I think that is referred to as... "sweating on the details" ... whilst ignoring the real issues. ! :lol:
build the drive onto a bike first ..then refine the details like tire size etc once you have a working test bed.
Unless you plan on a multi kW drive, friction onto the tire wont be one of your biggest problems.
kevo   100 W
Post by kevo » Jan 12 2011 4:49pm
Adrian,
Love your bike build and writeup! Do you have a link for the triangular bag on your white road bike?
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
Kepler   1 GW
1 GW
Post by Kepler » Jan 12 2011 5:32pm
adrian_sm wrote:Not sure. I think it was Kepler that said this is the optimum engagement, to be able to draw the straight line between motor pivot, contact patch, and wheel hub. I don't quite agree and have been setting up my drives to limit the travel before that point with success.
- Adrian
One of the good things about this type of design is that the geometry is quite flexible. I think the "straight line" geometry is still the optimum setup, at least for my drive but I can also see that with a shorter swing arm, you can stop short of this and still have good pick up at first start.
Having the pivot on the opposite side will certainly open up some bike frame options. Be careful not to step on some "hidden" patents though :)
Current Rides
Lightest true ebike on the planet: ON ROAD viewtopic.php?f=6&t=74269
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
spinningmagnets   100 GW
Post by spinningmagnets » Jan 12 2011 5:39pm
Motors: the 63mm Turnigy with a skirt bearing and a 200-kV is proving to be popular, but keep in mind that before rushing into that one, Kepler is testing the similar 63mm Aeolian motor with a 170-kV, results to be posted soon.
adrian_sm   10 MW
Post by adrian_sm » Jan 12 2011 6:25pm
kevo wrote:Adrian,
Thanks. It was from Aldi. I think it is one of those items they only occasionaly stock. At least in Oz.
Kepler wrote:Having the pivot on the opposite side will certainly open up some bike frame options.
Probably only in avoiding shifter cables.
Kepler wrote: Be careful not to step on some "hidden" patents though :)
gtadmin   10 kW
Post by gtadmin » Jan 13 2011 6:06am
Kepler wrote: ... Be careful not to step on some "hidden" patents though :)
That's what I was thinking too (although you are using the can as the roller so it IS different)
adrian_sm   10 MW
Post by adrian_sm » Jan 13 2011 7:08am
I think I am more worried about infringing on John's (Kepler's) design.
There are heaps of differences between mine and the other "hidden" design
Theirs has a one way bearing, mine mechanically disengages
Theirs has an in-runner motor mounted infront of the tube, mine an out-runner behind
Theirs has belt drive with reduction, mine direct contact.
Mine uses rotational inertia reaction to engage the tyre, theirs remains in contact via spring.
The main common ground is the pivot mounted to the seat-tube, but I can't see that being an individual claim in the patent.
I think I am clear.
gtadmin   10 kW
Post by gtadmin » Jan 13 2011 7:17am
adrian_sm wrote:I think I am more worried about infringing on John's (Kepler's) design.
Theirs has a one way bearing, mine mechanical disengages
Theirs has an in-runner motor mounted infront of the tube, mine an out runner behind
I think I am clear.
I think I needed more of these ... :P or these ... :lol: Pity we don't have a sh!t stirring icon
adrian_sm   10 MW
Post by adrian_sm » Jan 13 2011 7:26am
Perhaps you were looking for one of these Image
gtadmin   10 kW
Post by gtadmin » Jan 13 2011 7:29am
adrian_sm wrote:Perhaps you were looking for one of these Image
:lol:
Now I need one showing me rolling around the floor ...
adrian_sm   10 MW
Post by adrian_sm » Jan 13 2011 7:31am
gtadmin   10 kW
Post by gtadmin » Jan 13 2011 7:34am
adrian_sm wrote:Image
Ripper ... saved ...
So how do you do it?
adrian_sm   10 MW
Post by adrian_sm » Jan 13 2011 7:37am
Google my friend google. :D
Quick google image search, right click, "copy image location", then paste inbetween the [ i m g ] [ / i m g ] things.
Done.
gtadmin   10 kW
Post by gtadmin » Jan 13 2011 8:12am
:oops:
TylerDurden   100 GW
Post by TylerDurden » Jan 13 2011 10:34am
Code: Select all
[img]http://endless-sphere.com/forums/download/file.php?id=52016[/img]
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
gtadmin   10 kW
Post by gtadmin » Jan 13 2011 3:35pm
TylerDurden wrote:Image
Code: Select all
TD, thanks
Kepler   1 GW
1 GW
Post by Kepler » Jan 13 2011 3:49pm
spinningmagnets wrote:Motors: the 63mm Turnigy with a skirt bearing and a 200-kV is proving to be popular, but keep in mind that before rushing into that one, Kepler is testing the similar 63mm Aeolian motor with a 170-kV, results to be posted soon.
Should have this motor in a few days. I hope its as good as the Hobby City version. Its about $10.00 less landed then the Hobby City 63-74 so thats a bonus too. I think the 170kv will suit 6S very nicely with the 63mm diam. I plan to package it up with a single Turnigy 6S 5800 mah pack. This will give about 30% better range then a 5S 5000mah pack.
Current Rides
