Warren's 350 MAC mid-drive (finally) recumbent
mi7d1   100 W
Re: Crystalyte mid-drive questions
Post by mi7d1 » Dec 06 2010 11:21pm
I'm a little late to the thread but wanted to say that I use a C'lyte 408 with a 36v 20Ah LiFePO4 Headway battery pack driving my bottom bracket. Speed wise it'll do just under 30mph at under 14Wh/mile with a 44 mile range running wide open. A friend of mine who has a Stokemonkey gets better than 7Wh/mile. We haven't figured out why I use twice the watt-hours when we ride at the same speed. It might be the terrain. He's in flat land Florida and I'm in hilly Portland, Oregon. It might also be the differences in a Stokemonkey motor and controller and my stock C'lyte motor and controller. The Stokemonkey is made here in Portland at Clever Cycles http://clevercycles.com/products/stokemonkey/
Prior to installing the bottom bracket drive I was running a C'lyte 406 in a 26" rear wheel with a 48v SLA 18Ah battery pack. It would do ~31mph at 18Wh/mile. Range was a little over 26 miles.
Using the bottom bracket drive and 36v 20Ah Headway pack saved me 28lbs in weight and allows me to climb any hill in my area. Whereas with the hub motor mounted in the wheel I avoided hills like the plague. I used the 408 motor for a while mounted in the 26" wheel but sacrificed torque for more top end speed. The motor was geared to spin the cranks at my preferred cadence while running in it's optimum efficiency rpm. One of the things I like about this system (most of the time) is that while using the motor I have to pedal just ahead of the motor. There is no free ride. If I don't then the motor will pull my feet around in circles and that's not fun.
Here are a few photos. The first one show the custom motor mount with torque plates. The second and third show the motor installed with a view from both sides
Bill
http://www.flickr.com/photos/wmbates/sets
http://www.vimeo.com/mi7d1
velomobile: WAW-042
Zox inspired clone tilting trike conversion
Nevco Gizmo #19
jbond   100 W
Post by jbond » Dec 07 2010 3:10am
This is just unacceptable to me. I think it's avoidable with enough freewheels in the system.
How free running are the DD hub motors? Is it acceptable to spin the DD hub with no power using pedals only? If it is then I'd look at the same approach I was suggesting for a geared hub. Mount the DD Hub in the middle of the frame with two sprockets, one fixed, one freewheel. The fixed drives the rear gear cluster, the freewheel is driven by the front crankset. With no power, the crankset drives the motor round, which then drives the rear gearset. Under power, the crankset freewheels, the motor drives the rear gearset.
Is your setup in that velomobile? Have you got any pictures of the naked velo chassis?
mi7d1   100 W
Post by mi7d1 » Dec 07 2010 3:47am
While pedaling only without the motor running it (the motor) doesn't spin due to the single speed freewheel mounted on the motor. With the C'lyte motors I have there is considerable drag IMO when mounted in a wheel and pedaling only without assist.
This is the setup I have in my velomobile currently. I'm getting ready to try something similar to your suggestion using a smaller geared hubmotor and a free wheel bottom bracket for my winter bike project and get my disk brakes installed. I do think your idea may be a better approach than my idea and would save the $180 for a freewheel bottom bracket. Think I'll give it a try first. Thanks :D
Bill
velomobile: WAW-042
Nevco Gizmo #19
Warren   100 kW
Post by Warren » Dec 07 2010 6:25pm
mi7d1,
You must be running a internal gear hub in the rear, correct? I can't see how you could spin at 30 mph for 44 miles with that tiny chainring, and a normal 11 tooth cassette high gear in back.
I suspect your buddy's Stokemonkey wouldn't do any better than your rig. Hills take a huge amount of power.
jbond,
Your mid-drive idea, with a geared hub motor has me sold. I will contact cell_man about a motor...maybe this one.
http://www.emissions-free.com/catalog/i3.html
mi7d1,
What is the highest amps you are pulling? Sounds like this motor is limited to about 15 amps.
Thanks, warren
Warren   100 kW
Post by Warren » Dec 07 2010 7:04pm
mi7d1,
Looks like your reduction is 16/48. According to their spec page, a C408 runs 356.4 rpm on 36 volts, no load. That means your cadence is 95 rpm at 80% of no-load. Am I figuring correctly?
Warren
mi7d1   100 W
Post by mi7d1 » Dec 07 2010 7:11pm
Warren wrote:mi7d1,
jbond,
mi7d1,
Thanks, warren
No internal geared rear hub. Just an 11-34 cassette. My bottom bracket is a Schlumpf high speed drive. http://www.schlumpf.ch/hp/hsd/hsd_engl_ ... rungen.htm It's an internal geared two speed bottom bracket with a 2.5 overdrive. The chain ring is 27t and in overdrive is equivalent to a 67.5t chain ring. That gives me a gear inch range of 20.6"-159.5 with a 26" rear wheel. A pedaling cadence of 80 RPM will get me ~32mph and 100 RPM would net me 40 mph.
My e-assist is not a mid-drive but a bottom bracket drive. The motor see all the gears and not just the back set. My motor controller is/was 20amp. The Mac geared motor you linked to looks close to the specs of my Crystlyte direct drive motor but less weight. With the right setup, I think you'd be happy with it.
Here's the E-S link from May 2008 http://endless-sphere.com/forums/viewto ... f=3&t=4426
Bill
velomobile: WAW-042
Nevco Gizmo #19
mi7d1   100 W
Post by mi7d1 » Dec 07 2010 7:26pm
Warren wrote:mi7d1,
Warren
With my bottom bracket drive I'm using a C'lyte 408 motor with an 18t freewheel and a 46t chain ring giving me a 2.55:1 ratio. I'm trying to run the motor at peak efficiency. I believe that would be ~260 RPM for the motor. All that was new to me back on 08. Perhaps the 3:1 of a 16/48 combo would get closer efficiency to my friends Stokemonkey.
According to my friend in an archived email, the (His) Stokemonkey uses a 407/409 two speed motor and runs a 16/48 combo.
Bill
Bill
velomobile: WAW-042
Nevco Gizmo #19
mi7d1   100 W
Post by mi7d1 » Dec 07 2010 8:03pm
It just dawned on me that the 2008 E-S link I posted about the e-Power Challenge was or could be misleading. That link was about when I was running a C'lyte 406 hub motor in my rear wheel with a 48v 18Ah SLA pack. In April of 2009 I was building my bottom bracket drive for the May 2009 race date. With the bottom bracket drive at the 2009 e-Power Challenge I used a C'lyte 408 motor and a 36v 20Ah pack of Headway cells. Speed wise the bottom bracket drive was slightly slower but had many benefits most of all torque and the ability to climb hills.
I won my category but wasn't the fastest one there. That honor goes to Bill Bushnell who had a socked long wheel base recumbent with a mid-drive. Bill did ten laps in 36min 1 sec
My race results from the 2009 e-Power Challenge were;
20 miles (ten laps)
43min 42sec time
I cropped a photo of my race results, hope it isn't hard to see
Bill
velomobile: WAW-042
Nevco Gizmo #19
Warren   100 kW
Post by Warren » Dec 07 2010 9:14pm
Bill,
Now I am confused. Let us say your friend is using the 409 wind of his motor. The 36 volt no-load speed is 317.9 rpm, so the 80% (most efficient?) speed is 254.3 rpm. With his 16/48 reduction, he would have a cadence of 84.8 rpm...pretty comfortable.
For you, 408 wind, 356.4 rpm no-load, 80% is 285.1 rpm. With your 18/46 reduction, your cadence would be a very fast 111.8 rpm. If you are pedaling at 80 rpm, then the motor is turning 204 rpm, 57.25% of no-load. That is closer to maximum power rpm than maximum efficiency. Perhaps that explains the difference in Wh/mile? But you should be able to beat him in a drag race! At a cadence of 80, you want a 16/57 for maximum motor efficiency.
Warren
mi7d1   100 W
Post by mi7d1 » Dec 07 2010 9:54pm
Warren wrote:Bill,
For you, 408 wind, 356.4 rpm no-load, 80% is 285.1 rpm. With your 18/46 reduction, your cadence would be a very fast 111.8 rpm. If you are pedaling at 80 rpm, then the motor is turning 204 rpm, 57.25% of no-load. That is closer to maximum power rpm than maximum efficiency. Perhaps that explains the difference in Wh/mile? But you should be able to beat him in a drag race! You want a 16/57 for efficiency.
Warren
I'm interested to know where you're getting the no-load 356.4 rpm for a 408 motor. It could be that I'm not understanding but according to the ebikes.ca simulator http://www.ebikes.ca/simulator/ the 408 motor has a no-load rpm of ~290rpm. If that's the correct number than I should be targeting a 232 motor rpm and a 100 rpm cadence (that being my cadence goal)
This is all still new to me. With me about to try a new motor, it's important that I get it correct.
Bill
Bill
velomobile: WAW-042
Nevco Gizmo #19
Warren   100 kW
Post by Warren » Dec 07 2010 10:12pm
Bill,
"I'm interested to know where you're getting the no-load 356.4 rpm for a 408 motor."
From their website.
http://www.crystalyte.com/Mspecs.htm
I haven't checked that simulator yet. I would assume the company is using actual measurements, not simulations? But then, I don't understand the amps, and watts given in each row either. For instance, for the 408 on 36 volts, at 15 amps, wouldn't the watts be 540 instead of 332.524? Or maybe that is measured power out...61.57% efficiency?
"This is all still new to me. With me about to try a new motor, it's important that I get it correct."
I know there are some real wizards on this list. I wish they would speak up. :-)
Warren
Sturdly   10 W
Post by Sturdly » Dec 07 2010 10:28pm
Dom Harvey had a 48 volt 408 in his BB drive, built about 4 years or so ago now. I think he also used one of the dual wound two speed versions an a later incarnation. http://www.evalbum.com/769 a pic of an early version.
Warren   100 kW
Post by Warren » Dec 07 2010 10:48pm
Sturdly,
"Dom Harvey had a 48 volt 408 in his BB drive, built about 4 years or so ago now."
Wow! He did just what I had suggested. He made a left hand threaded adapter, for a southpaw freewheel.
http://www.flickr.com/photos/89372267@N ... 115596918/
Man, I wish I still had access to a machine shop. :-(
Warren
mi7d1   100 W
Post by mi7d1 » Dec 07 2010 11:08pm
Warren wrote:Bill,
From their website.
Warren
Very interesting between the two I put my faith with Justin Lemire-Elmore of http://www.ebikes.ca
The parameter values that are choosen for the motor model are based on directly measured data that we have compiled from tests using a custom built dynamometer made for the task.
Bill
velomobile: WAW-042
Nevco Gizmo #19
mi7d1   100 W
Post by mi7d1 » Dec 07 2010 11:20pm
Warren wrote:Sturdly,
Warren
Thanks for posting the flickr set link Warren. I see he was also using a 13/44 combo for a 3.38:1 ratio. Perhaps I should have used a smaller freewheel like you mentioned :D
Bill
Bill
velomobile: WAW-042
Nevco Gizmo #19
Warren   100 kW
Post by Warren » Dec 07 2010 11:59pm
Bill,
"I see he was also using a 13/44 combo for a 3.38:1 ratio.
Which, if you use the company numbers for no-load rpm, gives him 84.2 rpm at 80%. Right where I would want to be.
"Perhaps I should have used a smaller freewheel like you mentioned"
Actually, I suggested a bigger chainring, because you can no longer buy a freewheel smaller than 16 teeth for a standard 1.375 inch diameter thread. AC Racing made a 15 tooth briefly. Dom made an adapter for the smaller M30x1 size freewheels.
Warren
mi7d1   100 W
Post by mi7d1 » Dec 08 2010 1:06am
Warren wrote:Bill,
Warren
I just checked my parts inventory and I have an 18t freewheel and a 60t chain ring. That will get me a 3.33:1 ratio. I'll have to get the e-assist reassembled in the velomobile and give it a try.
Bill
Bill
velomobile: WAW-042
Nevco Gizmo #19
Warren   100 kW
Post by Warren » Dec 08 2010 8:49am
Bill,
"I just checked my parts inventory and I have an 18t freewheel and a 60t chain ring. That will get me a 3.33:1 ratio. I'll have to get the e-assist reassembled in the velomobile and give it a try."
Sweet! I will be anxious to hear how it goes. It must be nice living where it is not in the 20's right now. :-)
Warren
MitchJi   1 GW
1 GW
Post by MitchJi » Dec 08 2010 5:58pm
Hi Warren,
I'm jumping in after only reading your first post so please forgive me if what I say is something that has already been mentioned or rejected.
Marcus (http://www.pimobility.com/) used to use a drive design similar to the Hanebrink (mid-mounted hub motor). In that application he really preferred geared hub motors. Because the use the bike's gears they were running pretty close to a perfect RPM with pretty good efficiency and were much lighter than comparable DD hub motors.
Best Wishes!
Mitch
The best quality batteries and lowest priced batteries for DIY EV's are tier 1 OEM Quality Cells from salvaged (wrecked) EV packs. Three examples are Chevy Volt and Nissan Leaf and Tesla Model 3 packs.
Nissan Leaf Module specs are here
Chevy Volt Pack Info - Salvage 16kwh Packs Under $2k here
Warren   100 kW
Post by Warren » Dec 08 2010 10:43pm
Mitch,
"Marcus (http://www.pimobility.com/) used to use a drive design similar to the Hanebrink (mid-mounted hub motor). In that application he really preferred geared hub motors."
Yes. I read that he dropped the mid-drive to get the price down. Too bad, other than the styling now, it is just like all the other hub drive bikes.
Warren
Warren   100 kW
mid-drive questions
Post by Warren » Dec 21 2010 9:44am
Folks,
I have been in correspondence with cell_man about a 350 watt, geared, rear, MAC hub motor. It sounds perfect, except for an aluminum threaded freewheel mount. He is checking into availability of the newer version with a steel freewheel mount.
This week, I had the "opportunity" to bring home a pedelec, front geared hub, comfort bike, from work to trouble-shoot. It has a loose connection somewhere. The thing is a nightmare of possible loose connections.
It has wires running from the battery pack/controller on the rear rack, to the brake levers, to the cheap left paddle throttle, and to the pedelec sensor on the bottom bracket. Switches which may have poor contact include the two plunger type switches in the brake levers, the incredibly cheap rocker switch in the paddle throttle, and the sloppy key switch in the controller!
Also, the battery is connected to the controller by two spring loaded plungers sticking out the back of the controller! The electrical stuff on this bike are way too complicated, and way too cheap.
This experience has led me to decide to go with only a left hand, half twist throttle. Hopefully I am smart enough to figure out when to turn the power on and off. :-)
There is no manual for this thing. It only has three fairly large wires to the motor. Does this mean it doesn't use hall sensors?
Warren
Warren   100 kW
Post by Warren » Dec 23 2010 3:42am
Not much interest in my fairly weak mid-drive I guess. But I did sort out than pedelec. One of the power wires from the key switch to the spring loaded contact plunger. The nyloc nut wasn't tight. Resistance was high enough to melt the nylon out of the nut, darken the nut, connector eyelet, and melt insulation on the end of the wire. Sanded up all surfaces, and replaced nyloc nut.
gtadmin   10 kW
Post by gtadmin » Dec 23 2010 4:38am
Warren wrote:Not much interest in my fairly weak mid-drive I guess.....
Hi Warren, don't get discouraged, not everyone who read the posts feel qualified to add to the topic (like me)
Cheers mate,
GT
TylerDurden   100 GW
Post by TylerDurden » Dec 23 2010 9:15am
Likewise here. Lots of looking, eventually an enlightened member will chime in.
As for the PAS motor, if it only has three heavy wires it is sensorless... PAS motors are typically moving before power is applied, so they don't need sensors to determine the direction of rotation.
It may be helpful to edit the title of the original post to "mid drive questions"... some folks in Europe are using the smaller hubbies for mid drives (bafang, etc.). Many are cyclists, well versed in gearing for minimal assist:
http://endless-sphere.com/forums/viewto ... t=0&hilit=
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
Warren   100 kW
Re: mid-drive questions
Post by Warren » Dec 24 2010 6:36pm
GT and TD,
Thanks for the encouragement. I am pretty psyched by this project. Not very exciting for a motorhead. But for a bicyclist to have a stoker as strong as Lance Armstrong, who only weighs 50 pounds, is great!
TD,
How does the motor manage to keep in sync without hall sensors? I thought that required a fancy controller. This thing has a controller the size of a pack of cigarettes.
And thanks for the great link.
Warren
