Electra-punk
rodgah
Re: Electra-punk
Post by rodgah » Sep 12, 2011 4:32 am
got some headstem bearings into it and took a small vid to show the relative size of the frame.
Common Sense isn't so common........
Specialized BigHit
Electrapunk
Stinky
Thud
Re: Electra-punk
Post by Thud » Sep 12, 2011 6:27 am
this video is private.
get some......
emoped
Re: Electra-punk
Post by emoped » Sep 12, 2011 11:32 pm
Nice work ... On my recent trip across the USA to pick up a Meyers Towdster ... I stopped to visit the evtv.me guys .... He let me drive the Electric Porsche 550 Spyder ..... IT was AWESOME ! Have a look see. Harley aka emoped
Kurt
Re: Electra-punk
Post by Kurt » Sep 13, 2011 1:38 am
Just keep in lookout for cracks forming on that SS frame. It doesn't tend to lend its self well as frame building material. You might get away with it for a while. That's why you don't see to many ss frame bikes around other than the weight.
Kurt
rodgah
Re: Electra-punk
Post by rodgah » Sep 13, 2011 6:10 pm
sorry vid now works.....
Kurt wrote:Just keep in lookout for cracks forming on that SS frame. It doesn't tend to lend its self well as frame building material. You might get away with it for a while. That's why you don't see to many ss frame bikes around other than the weight.
Kurt
I would be more worried about it if there was an ICE in it(vibration), or if it were to be used off road. Unless some serious hefty rider got on it and found some decent pot holes to run through I think its well and truely overbuilt for its application. Ti suffers from heat effected brittle zones just as much as 300's grade stainless, so I think the primary reason not many frames are made of SS is the weight/cost compared to chromo. Time will tell anyway, I might be eating my words in a few weeks time.....if that is the case it will be remade completely from aluminium, and the box welded to the frame.
I have not had alot of time to work on it this week.....I did change a friends bike over to some sweet Bus bar inspired by AJs bike.
and heres a pic to give an idea on the bars that I will use....
Im at the end of my days off now, hopefully next week I will get the crankset on and make the bike push pedal'able. Box mounted, and cover made for its window (once cut). And most of the electics mounted inside of the box. Maybe even the forks if I'm not too busy.
Cheers
Specialized BigHit
Electrapunk
Stinky
sn0wchyld
Re: Electra-punk
Post by sn0wchyld » Sep 13, 2011 8:14 pm
rodgah wrote: Image
Cheers
WOW
that looks tidy! makes my wiring look like a loom of S#!T. Cant wait to get the time to put together a new bat case, so I can make mine look like that.
Do you need to reconfig for charging?
rodgah
Re: Electra-punk
Post by rodgah » Sep 13, 2011 10:10 pm
sn0wchyld wrote:Do you need to reconfig for charging?
nope....the db25 connector at the bottom has all 12s cells or 14 pins for balancing and the remaining pins share (-) and (+)....5 each. This is not a new technique, I am copying what alot of people have already done, and it is a neat solution to balance charging lipo.
dont worry, i think everyones first attempt looks terrible, mine looked like abortions thats for sure, but the more times you do it, the more you get a feel for how to make it neater and simpler.
cheers
Specialized BigHit
Electrapunk
Stinky
sn0wchyld
Re: Electra-punk
Post by sn0wchyld » Sep 14, 2011 3:42 am
cheers
I think I might be doing something similar already, only I still use the discharge leads for charging too, rather than through the db25. I still have to reconfig as my charger only manages 8s charging, and im running 20s. Using the spare pins for the main leads is a good idea, but how many amps can the pins take? Im charging at 30-40A, so not sure they'll take that...
flyinmonkie
Re: Electra-punk
Post by flyinmonkie » Sep 16, 2011 6:06 pm
rodgah
The bike looks amazing. I like the battery box. Looks very similar to what I am doing. I'm looking forward to seeing how it all fits together.
Clay
rodgah
Re: Electra-punk
Post by rodgah » Oct 13, 2011 2:06 am
Ok time for an update.....
-I have mounted the box and cut the window
-had the BB welded to the brackets
-received the order from Matt.S
-made the battery mount.
Things i have left to do....
-go and pick up the box lid/cover and mount it using m6 nutserts
-buy chains
-modify rear brake caliper mount to allow the caliper to move over and slot over the disc
-pick up the new front fork stanchions
-assemble and mount drive
-wire everything up
The sprocket adaptor that Matt machined fits perfectly....has enough space for the caliper to sit in beside the sprocket. Unfortunately choppersUS hubs are a little oversize, so I threw the adapter on the lathe and opened it up a fraction to accept the hub.
spacing....
The rest of the pictures are at the start of the thread as usual.
Cheers
Specialized BigHit
Electrapunk
Stinky
recumpence
Location: On Earth right now. That can change at any time, though..........
Re: Electra-punk
Post by recumpence » Oct 13, 2011 7:07 am
I am amazed at the continual improvement I see in project bikes coming out of this forum as time goes on.
Amazing......
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
kfong
Re: Electra-punk
Post by kfong » Oct 13, 2011 7:16 am
Another cool build!
rodgah
Re: Electra-punk
Post by rodgah » Oct 22, 2011 7:57 pm
thanks guys,
anyone interested in weight,
I just weighed all the parts on the bike, only missing the chain for the drive to backwheel and it came in at 36.5KG's, alot lighter than I first thought it would be.
more updates next week.....
Cheers
Specialized BigHit
Electrapunk
Stinky
SamTexas
1 GW
1 GW
Re: Electra-punk
Post by SamTexas » Oct 22, 2011 9:08 pm
Subscribed. I'm amazed at the skill and effort you put into this build. Is this a common trait among downunder's members? More pictures please.
One question: Since you were building from scratch, why didn't you make the battery box part of the frame?
rodgah
Re: Electra-punk
Post by rodgah » Oct 30, 2011 12:08 am
SamTexas wrote:Subscribed. I'm amazed at the skill and effort you put into this build. Is this a common trait among downunder's members? More pictures please.
thanks, I think its just because we are all anal f**ks and like to be perfect
weight/design.....
assuming it were made out of 0.9mm ally like originally planned it would of been lighter(though in retrospect it would of been easier to have it laser cut in SS and welded to the frame). And besides I love the contrast between stainless steel and machined/polished aluminum(it is going to be polished, just waiting to be finished handling it before I go finishing it). And trying to replicate / redesign a vintage ICE bike to some degree requires something that looks similar to a fuel tank.
I have not had alot of progress this week, still waiting on chains, new drive mounts (the originals were too short). I am having a crack at the wiring....probably 50% done, and hobbyking have held an order of mine containing cable sheath that I want to use to complete this bike because it went into backorder as I ordered it :x . Might be going before Christmas lol .
I did shave the brake caliper mount though so I have functional rear brakes :wink:
Cheers
Specialized BigHit
Electrapunk
Stinky
rodgah
Re: Electra-punk
Post by rodgah » Oct 30, 2011 3:25 am
added more pics in the first pages
few of the bike and one showing the rebate on the disc brake caliper mount in order to get it to line up with the disc.
Specialized BigHit
Electrapunk
Stinky
rodgah
Re: Electra-punk
Post by rodgah » Nov 01, 2011 2:59 am
Wired everything today not a lot left to do now.....
Final pictures of the bus bars and balance setup added.
Cheers
Specialized BigHit
Electrapunk
Stinky
Whiplash
1 GW
1 GW
Re: Electra-punk
Post by Whiplash » Nov 01, 2011 2:44 pm
Absolute work of art, one of the very best builds on the Sphere in my opinion! I love the detail work and the simplicity of the look! You are one hell of a craftsman! :shock:
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
rodgah
Re: Electra-punk
Post by rodgah » Nov 03, 2011 1:35 am
Whiplash wrote:Absolute work of art, one of the very best builds on the Sphere in my opinion! I love the detail work and the simplicity of the look! You are one hell of a craftsman! :shock:
Thanks whip.....sometimes I stand back looking at it an go 'wow' myself lol
Specialized BigHit
Electrapunk
Stinky
doc007
Re: Electra-punk
Post by doc007 » Nov 03, 2011 2:23 am
that is a sweet build! it looks like you are running a floating disc brake. when you get a chance can you show some more pics of it?
Build log: Kona DH Stab Primo, 20s2p, 9C 8x7, Greentime 15fet 4410 50A
https://endless-sphere.com/forums/viewto ... =6&t=41331
rodgah
Re: Electra-punk
Post by rodgah » Nov 08, 2011 10:20 pm
doc007 wrote:that is a sweet build! it looks like you are running a floating disc brake. when you get a chance can you show some more pics of it?
its a hope mono floating disc. Plenty of members on this forum use them....
http://www.chainreactioncycles.com/Mode ... elID=16457
Bike is now running, I got the forks, new motor plates, chains, mounted everything up. Goes like a dream, so smooth and stable. If I really nail it, the hv160 hits its current limiting, I may adjust the clutch so this doesnt happen or up the current limit. No wheelies but it takes off like a rocket, pulls some weird looks while I'm riding along with traffic thats for sure :lol: .
Few pics added, one of the finished forkleg and one of the new mounts for the drive. Im still waiting on the lid for the box and also some quick release screws from pro-bolt ......
And I still have to disassemble it and finish off all the parts removing all the sweaty hand prints and weld splatter......adding some loops to the frame and fork too to tie the cables to.
Ill post some final pictures and videos once this is all sorted.
Cheers
Specialized BigHit
Electrapunk
Stinky
rodgah
Re: Electra-punk
Post by rodgah » Dec 07, 2011 5:37 am
pics added of the box lid and the cable tie points on the frame. I have cleaned/refinished all of the frame and box for final assembly, even painted the BB tube since rust doesnt really suit it :wink: .
Waiting on some goodies from Matt/Recumpence and she will be finished :D :D
On a side note, my welder friend is making a duplicate of this frame only a fraction heavier. He wants BIG power.....biggest you would seriously throw in it. I said OK AGNI 95R it is :lol: :lol: . He wants to use speedway solo bike wheels (nice and light) and no pedals just pegs. Throw in a butt load of lipo and I'm sure it will have some poke.
Rodger
Specialized BigHit
Electrapunk
Stinky
recumpence
Re: Electra-punk
Post by recumpence » Dec 07, 2011 9:24 am
Cool!
Your box shipped out yesterday "Express Mail". It is guaranteed to be there next Tuesday. :)
Make sure you get a build thread started on that Agni bike. I am interested in seeing that too!
Matt
etard
Re: Electra-punk
Post by etard » Dec 07, 2011 9:40 am
Amazing work Rodgah! Is the slipper clutch engaging at all as far as you can tell? Have you tried "locking it out" to see the difference? I would like to see a pic with you on it just to get a size comparison.
+1 on Agni bike pics!
grindz145
1 GW
1 GW
Re: Electra-punk
Post by grindz145 » Dec 07, 2011 10:09 am
Omg, that thing is gorgeous. I'm really interested in people who are bringing art together with ebike technology. We're lacking design. Fantastic work.
