Giant Reign 2 Completed
Thecopterdr   100 mW
Post by Thecopterdr » Nov 10 2012 1:48am
This is my second build, My first was a Giant XTC 29er which I fitted out with a Cyclone 1200w motor kit and LiFePo 16Ahr battery.
Having researched intensively I decided that mid drive would suit what I wanted to do which was off road and bush trail riding.
I've seen a lot of Ebikes online and so many of them just look downright hideous, So I set out to try and put together a bike that is a little more discreet and appealing to the eye while possessing all the qualities of a good full suspension mountain bike.
I learnt a lot from the first bike including what would go better on the next one.
The first thing was to reduce the size of the speed controller so I purchased a Grin Tech Infineon 18 FET 35Amp controller that was nearly half the size of the stock standard Cyclone one.
The second was to run Lipos in a pack as per the EGO Kit, This wasn't a problem as I have 6 12s 5000 MAh Packs for my RC Mikado Logo 600 Helicopter with a charger that can crank out 40 amps all day long. I do currently charge 3 of these packs from 20% to full in about 40 mins flat.
I'm running 3 of these in my pack to get 15AH @ 48 volts weighing in at 3.95 kgs. This weight i hardly notice in my really supportive Camelback pack with a fibreglass Lipo liner.
One of the things I've noticed with off road bike mods is that the motor is always below the frame which to me not only looks awkward but would serve to hook logs etc and take a fair bit of abuse from whatever the front wheel throws up at it. I've utilized the space between the rear shock and down tube in the hope that the whole arrangement also looks a little more discreet.
The motor mounts will be powder coated the same Metallic grey as the Bike frame.
So far I have had a blast on this thing, Top speed is 55 Km/hr - a bit slower than the XTC 29er at 65 Km/Hr but it also climbs like a mountain goat. All up weight ready to go is 19.3 kgs. Everything seems to be holding up and I'm glad I went with the BMX drive chain - It hasn't stretched anywhere as much as the original cheapy chain that came with the kit.
flyinmonkie   10 kW
Re: Giant Reign 2 Completed
Post by flyinmonkie » Nov 10 2012 7:08pm
Nice work, looks fantastic. I love all the custom cyclone mounts people are doing.
Clay
litespeed   100 kW
Post by litespeed » Nov 10 2012 7:41pm
That does look excellent. So that is a Cyclone motor?
Tom
Thecopterdr   100 mW
Post by Thecopterdr » Nov 10 2012 10:35pm
Thanks guys, Yes Tom that is a 1200w Cyclone motor.
Tommy L   100 kW
Post by Tommy L » Nov 11 2012 8:04am
Totally Awesome build! Nice work here!
Tommy L sends.... \\m//
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
http://endless-sphere.com/forums/viewto ... =4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
kfong   1 MW
Post by kfong » Nov 11 2012 9:22am
Nice to see more mid drives. Great build. Makes me want to redo my cyclone setup.
o00scorpion00o   100 kW
Post by o00scorpion00o » Nov 11 2012 9:39am
I Like it !
I'm beginning to think I should abandon hub motors, they are too hungry and waste a lot of power.
Look really good, well done ! :D
Haibike EQ Trekking, powered by Bosch.
epack   1 mW
Post by epack » Nov 27 2012 7:26pm
How about posting some video. What are your thoughts on sound levels for the 1200 w motor?
Noobie: nuff said.
wildharemtbkr   100 W
Post by wildharemtbkr » Nov 27 2012 10:12pm
Very nice! That is a great looking setup!
Thecopterdr   100 mW
Post by Thecopterdr » Nov 30 2012 3:59am
Thanks guys, I think the 1200watt motor is pretty noisy with the included idler wheel in the kit.
This doesn't even have a ball bearing in it and is energy sapping junk. I purchased the roller from a local shop and when set to the right tension i've found that it is considerably quieter than the original setup. I've also repacked the gearbox with newer grease but still think that oil filled would be the best but am a little reluctant as the seal around the output shaft might not hold up to pressurized oil forcing its way into the motor housing.
I have just fitted a Kelly controller which is half the size again and much smoother on the throttle, I will post pics soon. Gopro is o order so will have footage to go with it.
Spicerack   10 kW
Post by Spicerack » Nov 30 2012 4:27am
Looking good!
Norco Shore2
Was Cellman MAC rear oil cooled then 8x8 9C vented and temp probed now 9x7 9C vented and temp probed!
12 FET controller
62V 18650 home made battery pack
50 km/h
http://endless-sphere.com/forums/viewto ... =6&t=32769
MAC Repair thread http://endless-sphere.com/forums/viewto ... =2&t=34806
Oil cooling the MAC hubbie http://endless-sphere.com/forums/viewto ... =2&t=37972
Architectonic   1 kW
Post by Architectonic » Nov 30 2012 10:37pm
Looks good, how much does this weigh all up? (Guessing it is a 2013 Reign).
wildharemtbkr   100 W
Post by wildharemtbkr » Nov 30 2012 10:56pm
First post "all up weight is 19.3kg" obviously that doesn't include the battery. 3.95kg in his camelback. For us in the new world that's 42.5 lbs, for the bike, and 8.7lbs for the battery. I have no idea what system you Brits use. :D something like 3 stone :lol:
Architectonic   1 kW
Post by Architectonic » Dec 01 2012 3:02am
Thanks man, I must have missed that.
Spicerack   10 kW
Post by Spicerack » Dec 01 2012 4:54am
wildharemtbkr wrote:First post "all up weight is 19.3kg" obviously that doesn't include the battery. 3.95kg in his camelback. For us in the new world that's 42.5 lbs, for the bike, and 8.7lbs for the battery. I have no idea what system you Brits use. :D something like 3 stone :lol:
I think it'd be something like 3/32ths of a cwt (hundredweight)? Those poms have got some really fvcked up weights & measures!
Norco Shore2
12 FET controller
50 km/h
DeepSouth   1 mW
Post by DeepSouth » Dec 02 2012 8:51am
Love the Bike You have done a great job, The mounting bracket is a work of art. Very cool.
I have built a bike using the GNG 48v 1000W kit. I have done the same thing as you and put My Lipo in a back pack 4x 6s 5 Amp hour Zippy's. Finnished it today worked great but I have a suspicion that I'm losing capacity at High Amps because I have under rated the wire harness. 1700 - 1800mm there abouts from lipo to controller with 30Amp andersons at each end and 75Amp Anderson at about seat level to connect and disconnect. When I was climbing step banks in first gear it was struggling abit compared to other people have written on this forum. I was wondering how you made your battery harness. and what rating of cable you used.
Thecopterdr   100 mW
Post by Thecopterdr » Dec 05 2012 4:32am
Here are some pics of the Kelly Controller.
So far so good and it seems to have much smoother acceleration than the Infineon.
Its a KBS48101L which is programmable, As you can see its way smaller than the infineon controller.
I've been putting the 3D printer to good use by manufacturing some custom controller mounts.
The top mount locks into the seatpost clamp to stop it spinning on the tube while the bottom one just clamps.
Sirbevalot   10 mW
Post by Sirbevalot » Dec 05 2012 5:17am
hey nice build,
I'm also very interested in seeing a detailed run down of your battery backpack. Also video would be great. I am keen on doing a battery back pack to save bike weight and keep it Stealth!
"No, no i'm not a real Knight"
BLUE TEAM ALWAYS WINS!!!
DeepSouth   1 mW
Post by DeepSouth » Dec 05 2012 8:42am
I was looking at the your controller mounts with interest, the bottom one you could cut out, the top one had me puzzled how you had done it. 3D printer explains it. :D
I made up a back pack harness. went and checked the specks on the cable I used, only a 20Amp rating. I suppose I could shorten the harness my putting it out the bottom side of the pack. Terrible thing to do to a nice pack. And still need to shorten the motor leads and a better rated cable. what are you using?
Been to busy riding it, It's been a blast. Not climbing as well as I hopped, but it ain't to bad either. If I get another controller I can push more amps through it. The standard GNG is 20Amps. The Kelly sounds attractive from what you say about even power delivery. I got kicked off a couple of times doing climbs and not being careful with the throttle. It did prove the 75Amp Anderson Powerpoles where breaking cleanly, perhaps to easily through. I looked like you are using 50 Amp Anderson plugs.
Still considering the Infineon Controller because it comes with a Cycle Annalist connecter.
Sirbevalot will put some photos of the harness I have made up tomorrow night if I have time. They may help even if its only how not to do it. :)
Sirbevalot   10 mW
Post by Sirbevalot » Dec 05 2012 5:03pm
Thanks Deepsouth.
The more i think about a Battery backpack the better it sounds. :D
DeepSouth   1 mW
Post by DeepSouth » Dec 06 2012 9:22am
Hi Sirbevalot
Photo I promised.
I just wrap it in a towel into my back pack and of I go, not very elegant. When I tipped over backwards climbing a rock face and me, bike and back pack went flying back down the face to end up in a heap at the bottom, I'm thinking that the towel did a pretty good job of protecting the lippo when I rolled over it a couple of times.
I'm thinking of making up a Poly-carbonate holder instead of taped cardboard.
The pack is two parallel packs of two which are put into series by the four 30Amp Anderson connectors. Those Connectors are also used to break the pack in half for parallel charging. the Big 75Amp Anderson's are my connect disconnect.
Thecopterdr   100 mW
Post by Thecopterdr » Dec 07 2012 2:30am
My pack is pretty much the same, I've used 2 pairs of Turnigy 6S 8000Mah to give me 48 Volts at 16Ah.
My 3D printer is currently printing out parts to make a lightweight but strong enclosure which will have clips for all wiring to keep things tidy.
I use 10 AWG wire throughout which is what the batteries have and EC5 plugs. I'm not sure what amp rating the plugs are but my RC 10S Helicopter has them on 10S packs pulling up to 120 amps.
No photos yet as the battery housing is a work in progress.
litespeed   100 kW
Post by litespeed » Dec 07 2012 6:43am
Generally speaking EC5's have a 120 amp rating although I have used Deans ultras at over 150 amps non stop for years. Lot of hype on the web and it appears Deans, EC5's and 45 and up Anderson Power Poles have enough to hang with 99% of the bike builds out there.
Tom
DeepSouth   1 mW
Post by DeepSouth » Dec 07 2012 10:12am
Can't wait to see the finished product. Which 3D printer are you using?
After my tumble down the rock face. I am convinced that if you are using a backpack lipo. Protection for the lipo is an important consideration. I had wrapped the lippo in a towel to stop it rattling around, the fact it did a good job of protecting the lipo was a happy bi-product. From every thing I have read on lipo says that these days the stuff is very stable compared to even two or three years ago, but physical damage is still a good way to get a lipo fire. And having that happen in my back pack while I'm wearing it is not a pretty thought. :) Using a lipo charge sack is a good idea I have one on the way from Hobbyking.
Thecopterdr   100 mW
Post by Thecopterdr » Dec 07 2012 6:31pm
I'm sure a good tumble would be a nervous one with lipos on your back unprotected.
I've been running them in Helis for years and the only issues I have encountered are when you discharge them below 15-20%, They swell up and don't like charging to well afterwards - a lesson learnt years ago when one when pop while flying. And yes it stank badly.
I plan to integrate some high density foam into the case and have a small handle to help with hauling it out of the slimline pack.
I charge using a Revolectrix PL8 charger with an E fuel 60 amp 1200 watt PS and a FMA balance board. With this setup I can charge about 24000 Mah in 40 mins while monitoring the detailed health of each cell.
The 3D printer I use is the Makerbot Replicator 2, Its pretty awesome to watch your design unfold in front of you.
