Mongoose CX 450 Builds
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 15 2013 4:29am
Hello all.
New to ebiking and to endless sphere. Just wanted to introduce myself and my first build a mongoose cx 450.
EBS
Then.
CX SIDE.jpg (214.83 KiB) Viewed 7319 times
Current top speed with pedaling
Now!
My bike (a work in progress) 30mph club on 20's! Sold and missed.........
http://endless-sphere.com/forums/viewto ... 28&t=46977
EvoBikeShop wrote:This ebike thing is an addiction.
NeilP   10 GW
Re: Newbie with cx 450
Post by NeilP » Jan 15 2013 4:07pm
how much did you pay for the forks?
:) Only Irish coffee provides in a glass all four essential food groups: alcohol, caffeine, sugar, and fat :)
e-biker   100 W
Post by e-biker » Jan 15 2013 7:23pm
Hello and welcome to the ebike grin :D I think your bike might have a currie motor if so you might try to search or or p/m drk angle for details on how to mod, I also started out with a currie motor and managed to get 30 mph out of it with a 16 tooth gear and a 48 v sla battery setup, I still have the gear if you ever need one.
24 s 4P, lyen 18 fet,QS 205V3, double crown monster ft forks large steel currie mongoose 24 450 (- the currie ) frame dual hyd disc daily commuter.
24s 20" M/P 2 casted wheelie machine, everybody should have one!!
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 15 2013 7:47pm
NeilP wrote:how much did you pay for the forks?
Order fell through.
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 15 2013 7:50pm
e-biker wrote:Hello and welcome to the ebike grin :D I think your bike might have a currie motor if so you might try to search or or p/m drk angle for details on how to mod, I also started out with a currie motor and managed to get 30 mph out of it with a 16 tooth gear and a 48 v sla battery setup, I still have the gear if you ever need one.
Already ahead of ya. Got the 16t on the way and bout to order the 48v controller from tnc and going to have to wait until next month for the batteries. Thanks for the warm welcome!
EvoBikeShop   100 W
Newbie cx 450 build
Post by EvoBikeShop » Jan 16 2013 4:26am
I decided to start a build thread, so here i go. Just picked up a mogoose cx 450, it was pretty ragged when I got it. So i tore it down and greased all the bearings, installed some cheapo forks and rear shock from a doner genesis v2100. The v2100 stuff will have to do for now. It was missing most of the plastics when delivered, but its ok cause i was going to ditch em anyway. I was going to go 48v but decided to go 36v instead because i want to intergrate a 36v led headlight to the battery system. Next month I will be setting it up for right side drive only using cyclone components but will be sticking with a currie motor and controller.
EvoBikeShop   100 W
Re: Newbie cx 450 build
Post by EvoBikeShop » Jan 16 2013 4:31am
It just sucks that i will have to buy another motor cause this one spins the wrong way lol! Not sure if im going to go sla 36v first or just jump right into lipos. Well i guess that all depends how much money i will have to spend next month. I will also be adding a shimano nexus 3 speed internal hub. Well thats all for now. Will post more as the build moves forward. Oh and also will be adding a 16t southpaw lefty sprocket for now when it comes in.
EBS
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 16 2013 4:38am
Here are some pics after the initial mods. More to come.
EBS
CX SIDE.jpg (214.83 KiB) Viewed 7698 times
CX FRONT 1.jpg (220.65 KiB) Viewed 7698 times
CX REAR 2.jpg (224.63 KiB) Viewed 7698 times
CX REAR 1.jpg (219.89 KiB) Viewed 7698 times
NeilP   10 GW
Post by NeilP » Jan 16 2013 4:00pm
EvoBikeShop wrote: cause this one spins the wrong way lol!
I have been totally lazy here..not read any more of the thread..but you say it spins the wrong way..I see it is a mid mount..is it a brushless motor ? with halls ?
If so , if it spins the wrong way then it is just a matter of swapping a few wires around to get it spinning the other way.
Won't go into detail just yet..but I am guessing that this could be the solution
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 16 2013 5:22pm
Oh? Good to know. I didnt know that. Its a currie electro drive. Can it be done?
NeilP   10 GW
Post by NeilP » Jan 16 2013 5:27pm
how many wires coming out the motor?
lbz5mc12   10 kW
Post by lbz5mc12 » Jan 17 2013 4:09am
All you have to do is reverse the red and black power wires coming out of the motor. Be careful what kind of controller you use. The Currie controllers have a current limiting feature which will keep you from burning up the motor. Stick to 36V. 48V is too much and will burn up the motor at full throttle. Actually just use Currie parts, controller, throttle etc. You can get them on tncscooters.com for a good price. I say all this because I've killed my only 2 motors in the last 2 weeks and am now penniless and Ev-less. I was using a universal 24-60V scooter controller which didn't restrict the current and it killed both motors. I went with the 5 pin Currie controller and throttle and they worked fine. Does your bike have a 24 or 36V motor? If you are going to run 36V to a 24V motor, it will significantly increase your rpm and top speed and adding the south paw will take you up to 30+ mph. However it might not be as quick because I think you have a smaller wheel base so it might be closer to 25+ mph. But you'll have better acceleration. Have fun.
flyinmonkie   10 kW
Post by flyinmonkie » Jan 17 2013 4:32am
Yup, just reverse the wires and it will run the other way. Definitely watch your amps. I have burned up 2 or 3 of these by feeding them too many amps. With the right gearing they can be very fun and are a pretty robust motor. I was amazed at how long mine lasted with 100 amps and 50v running into the 1000w version, but in the end it was too much for it.
Clay
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 17 2013 12:20pm
Wow what a great response. I wish the other forums I'm on would be like this lol! Well its two wires to the motor. It is a brushed motor and I have the 24v system. I am only going to run 36v because of the led headlight im going to be running. But 25mph is pleanty for me, anything more the cops will start harrasing me. The police where I live have nothing else better to do then to harass you for stupid crap.
Can i run 36v on a 24v currie controller? I read somwhere else that i can. But I'd like to ask you guys first.
EBS
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 17 2013 12:22pm
Also im more concerned with distance rather then high speed. Any battery suggestions? Would like to keep the factory battery case.
lbz5mc12   10 kW
Post by lbz5mc12 » Jan 18 2013 4:05am
I've never been able to get any of 24V currie controllers to work at 36V. I plug the battery in and nothing happens. Your best bet would be to buy the 36V controller and throttle.
flyinmonkie   10 kW
Post by flyinmonkie » Jan 18 2013 5:05am
Yup, I'm pretty sure the 24v controller won't want to play with 36v. For the cost of the Currie controllers, it is easy enough to get a 36v controller and throttle so you know it will work.
As for batteries, cram as many as you can in the stock holder as see how far it gets you. Your best power to weight is lipo, but you may not want to take that jump yet. It is up to you.
Clay
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 18 2013 10:35pm
Bad news. Battery pack shorted out bad today. Got new batteries and rewired the pack. Could only get sla batteries on such short notice. Hopefully 7.5ah will get me 4 miles so i can still get to work. Should be installing 16t sprocket by monday. Does anybody know what tool is needed to remove the factory lefty freewheel on the rim?
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 18 2013 10:37pm
Thanks for the info on the controller. Where is the cheapest place to get lipos?
lbz5mc12   10 kW
Post by lbz5mc12 » Jan 19 2013 3:59am
If you take the wheel to your local bike shop they may take it off for free. If you do it yourself, a single speed freewheel tool will work but then you have to buy the tool. The new freewheel will just thread on. You may have a small chain alignment issue because the 16 tooth is a little wider than the stock one. It should work fine tough. It might click a little as the chain goes over the teeth but it won't hurt anything wear and tear wise. You might want to try an already assembled pack. You might check out bmsbattery.com. Their prices aren't too steep and they have a shrink tube pack that should fit where the original batteries were placed. The one I bought and am currently using is the 36V 20Ah lithium ion shrink tube for $289.00 with charger. It cost me $390.00 total with shipping and I was using it on a similar set up just a different bike frame. You have to choose the DHL option for shipping because no one else will ship lithium.
NeilP   10 GW
Post by NeilP » Jan 19 2013 4:20am
EvoBikeShop wrote:Thanks for the info on the controller. Where is the cheapest place to get lipos?
Hobby King
http://www.hobbyking.com/hobbyking/stor ... ands_.html
You often get cheaper prices if you create an account and log in. Often if comes up with a cheaper price the first time yo look at a battery, as long as you leave the page open enough..You get a message like this: " We notice you have been looking at this article for a while, a one time offer if you buy now of..." and they quote a reduced price
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 20 2013 10:20pm
Well i got the 16t on myself. It was a b!"#$ to get it off. Also got my LED headlight installed. It is just as bright as a motorcycle LOL. Funds are now tapped for the month. So won't be able to get the battery pack done until next month. Not sure if i want to build a battery pack or order one already built. But ive been throwing an idea back and forth with installing the batteries under the seat and putting a gas engine down where the battery pack is. In other words turn it into a hybrid. The only real issue i see is that having two throttles is going to be a PITA. Unless there is someway to do a combine a throttle.
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 20 2013 10:28pm
More pics
EvoBikeShop   100 W
Post by EvoBikeShop » Jan 20 2013 11:43pm
So i looked at hobbyking. It looks like going with 2 10s long packs would work. And upgrade to 4 packs within a month. Whats up with the bms/charging setup being so expensive? Is there a cheaper way to balance charge these packs? Also what does the c rating mean?
These are the packs im looking at.
http://www.hobbyking.com/hobbyking/stor ... ouse_.html
Thanks for all the input guys. I really appriciate it!
wildharemtbkr   100 W
Post by wildharemtbkr » Jan 21 2013 12:49am
C rate stands for capacity (c)(4.5) times the number(30). Capacity on the battery you showed is 4500 mah, which is 4.5ah. So 30x4.5=135amps that the battery can be discharged at. There is also a c rate for charging, on your battery that is 2c or 2x4.5=9 amps. If you use 2 battery's in parallel that will double the capacity and therefore the current.
