full-throttle
Most if not all freewheeling cranksets at the moment require an exra wide bottom bracket. Usually square taper. While that's ok for riding on pavement, there's a need for something stronger for off-road use.
Ideally the crankset should have:
1) Splined crank interface
2) Provision for the inboard bearing
3) 73/68mm shell width
4) Low Q-factor
If you come across something that ticks all of the above, please let me know and I'll update this post with a link.
Here's what I came up with
Bottom bracket - Truvativ HammerSmidt AM 73/68mm. Did not come with M15 bolts.
Crank arms - Any ISIS will do. Picked a set of TryAll ISIS 175mm from tartybikes.co.uk
Freewheel - Any 1.37"x24tpi. Picked WI ENO from sickbikes.com
Chainring adapter plate - DIY
Inboard bearing support plate - DIY
Inboard bearing reducer - DIY
Chainrings - TBD
Chainring bolts - extra long or DIY
Now, a small problem. Truvativ BB is not actually ISIS compatible, however the difference is small. Forcing the cranks on might work. This what it looks like after starting to force them
BB compared with 150mm square taper
Crank arms compared
Once the crankset is assembled there should be ~16mm of room left
WI ENO leaves ~10mm for the inboard bearing
BB is 140mm wide with 13~15mm crank engagement.
Axle is 21.2mm dia where the inboard bearing goes, so needs a reducer/spacer. Metric size is 25mm id. Imperial is 7/8".
..to be continued..
4) Low Q-factor
Chainrings - TBD
Crank arms compared
..to be continued..
