13T Drive Sprocket - Currie, eZip, iZip
DrkAngel   100 GW
Post by DrkAngel » Feb 27 2013 10:23am
Great simple upgrade for eZip - iZip external non-hub motor.
13T Sprocket Upgrade - $18 includes shipping
Plug-n-Play - except you will need longer chain
click on picture - Updated Link
Good fit, good alignment, just lengthen chain and all set to go!
OEM eZip top speed @24V w/9T sprocket = 15mph.
15mph / 9T x 13T = 21.66mph (20mph USA "legal" - reasonable expectation)
I emailed "Jon", "Contact us", requesting a quantity purchase with shipping discount.
Was sent PayPal Invoice.
Very good shipping discount on quantity = 4.
$50 for 4 = $12.50 each shipping included!
Index - Homemade Battery Packs - Updated - December 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
EvoBikeShop   100 W
Re: 13T Drive Sprocket - Currie, eZip, iZip
Post by EvoBikeShop » Feb 27 2013 6:06pm
Just an fyi. I had one installed on my bike with a 16t wheel sprocket on a 20in wheel. In this configuration the motor will get very hot in stop and go riding.
EBS
My bike (a work in progress) 30mph club on 20's! Sold and missed.........
http://endless-sphere.com/forums/viewto ... 28&t=46977
EvoBikeShop wrote:This ebike thing is an addiction.
DrkAngel   100 GW
Post by DrkAngel » Feb 27 2013 6:37pm
EvoBikeShop wrote:Just an fyi. I had one installed on my bike with a 16t wheel sprocket on a 20in wheel. In this configuration the motor will get very hot in stop and go riding.
EBS
Yeah ... 16T + 13T ... not recommended ... unless you intend on cruising at 20-25mph, or with substantial pedal assist getting up to speed.
16T ? see - Re-Gearing the eZips -Simple Mods
EvoBikeShop   100 W
Post by EvoBikeShop » Feb 27 2013 7:32pm
Dont forget im also running it on a 20in rim. Going to try again with the new setup when i get it.
Gab   100 W
Post by Gab » Feb 28 2013 11:19pm
Hi Dark Angel
I just noticed on the bottom of the AFT website they have a new mid drive conversion kit for the currie EZIP ebikes:
http://www.af-tech.com.au/Products_Ebikes.html
Seems to be a bolt on kit to convert and they say no wirieng changes needed.
Does anyone know how to cut and paste the pictures and text to here ?
DrkAngel   100 GW
Post by DrkAngel » Mar 01 2013 12:01am
eZip Mid-drive pics.jpg (64.97 KiB) Viewed 9254 times
Parts list:
Chain for motor to freewheel
14T DICTA motor Freewheel and custom sprocket adaptor
Motor Mounting Bracket with all spacers, nuts & Bolts
Left and right crank arms and bolts
2 X Low friction chain guides
44T&44T&24T Tooth DICTA Freewheeling front Chainwheel
Cartridge Bottom Bracket
Detailed colour step by step installation instructions
Add $349,
Would be nice ... but cost more than any of my complete eZips ...
Cliff5119   100 µW
100 µW
Post by Cliff5119 » Mar 25 2013 6:43pm
Now you guys have confused me. Should I go with the 13T or the 16T. I can peddle no problem from the get go. I'm in shape. I bought this because it just looked like I could have some fun with it. I have a brand new Skyline, and am can do roughly 17mph as it stands. I'm a lightweinght, and this is the Florida flatlands. I want more top end without burning burning the motor out prematurely.
DrkAngel   100 GW
Post by DrkAngel » Apr 07 2013 7:23pm
Finally got around to trying the 13T mod on an eZip.
13T motor sprocket replaces the 9T oem sprocket.
A partial disassembly was necessary ... only because I wanted to use an intact chain rather than using a repair link.
(Repair link usage would merely require loosening adjustments, but repair link degrades chain consistency! durability? )
Required a chain length of 15 - 2 T links - 30 tooth holes.
9T - 20T requires 14 - 2T links (OEM)
9T - 16T requires 13 - 2T links (16T mod)
13T - 20T requires 15 - 2T links (13T mod)
(16T combined with 13T might use OEM chain?)
Results ...
Sprocket alignment is excellent!
21-22mph motor only w/25.9V Li-ion battery, 24mph with moderate pedaling.
Acceleration seems improved 15 - 20mph.
16T mod leaves eZips in the <20mph "legal" range, while the 13T mod provide a motor only >20mph speed and assist past 25mph!
DrkAngel   100 GW
Post by DrkAngel » Apr 08 2013 9:22am
Comparative Speed vs Torque - OEM vs 20T vs 13T
24V - 20T vs 16T vs 13T.jpg (32.45 KiB) Viewed 8867 times
So 16T for a "legal" 20mph, 13T for a cheaper, simpler, easier faster mod.
Might be able to pass a 20mph speed limit test with a 1/2 empty battery or low tire pressure?
Any speed increase mod would greatly benefit from enhanced pedal speed assist.
14T is winding out at 20 mph.
13T high end on the 7 speed would help but 11T is recommended for higher speeds and a higher pedal assist function.
DrkAngel   100 GW
Post by DrkAngel » Apr 08 2013 12:38pm
Simple and elegant 13T mod.
13T mod.JPG (61.82 KiB) Viewed 8848 times
ChiefGeek   1 mW
Post by ChiefGeek » Apr 10 2013 1:52am
Newb to board, hello all. I've just ordered a new Trailz (on Woot.com for $399). I'd like to mod it to the 13T for the higher end speed increase. Where do I purchase it? Do I still need the SPA-1 tool? I'm pretty handy, but am a computer guy, not a bike guy. Is all this pretty straightforward? Any other special tools? Youtube video maybe showing start to finish of mod. Sounds like if you know what you're doing it could be accomplished in about an hour? Thanks...
ChiefGeek   1 mW
Post by ChiefGeek » Apr 10 2013 2:00am
So this is a sprocket for the motor, NOT a freewheel that fits on the wheel hub? Still learning the bike lingo so pardon moi if I sound like a newb...cause I AM! :shock:
Does the sprocket fit on the motor without any mods? Just remove the stock one, and replace with this one? Thanks again...
EvoBikeShop   100 W
Post by EvoBikeShop » Apr 10 2013 10:48am
Welcome to ES. Yes the 13t is a motor sprocket. You just need regular tools to get it off. If my memory serves me right its either a 10mm or 12mm bolt that holds on the sprocket. You can get the sprocket at gngebike.com under the parts section.
EBS
ChiefGeek   1 mW
Post by ChiefGeek » Apr 11 2013 2:03pm
So I just received my new Trailz today, waiting on the sprocket to arrive from China.
What is the actual tested speed with this new sprocket after installing on a stock Trailz?
(side note: man. date is from August of 2012, is that bad that the battery has set in the box 8 months?)
wayover13   100 W
Post by wayover13 » Apr 11 2013 2:41pm
I'm looking into various options for upgrading my current electric assist (DD hub motor) and bumped into this thread. This looks like it might be an option for me. Do these motors freewheel when not under power, or is this an always-on setup? Also, is it possible to buy just the motor with associated electronics, and add your own wheel and battery?
Minimalist-assist advocate. Minimal assist means only enough to ease some of the physical strain the rider must output to propel the bike at or near more typical unassisted cycling speed. Such assist usually plays no role in increasing the bike's top speed, being brought into play mostly when facing challenging terrain (steep uphill grades) or weather conditions (strong headwinds). Assist may remain completely disengaged for large segments of any given ride.
DrkAngel   100 GW
Post by DrkAngel » Apr 11 2013 6:10pm
wayover13 wrote:I'm looking into various options for upgrading my current electric assist (DD hub motor) and bumped into this thread. This looks like it might be an option for me. Do these motors freewheel when not under power, or is this an always-on setup? Also, is it possible to buy just the motor with associated electronics, and add your own wheel and battery?
Freewheel on motor side so no drag for pedal only.
Requires a wheel-hub with a LHS (Left Hand Screw) threaded left side.
Kit available - Currie - IZip ebike Kit-I-Continuous Price Tracking
Strangely ... sometimes the complete eBike is cheaper than the kit!
eZip Trailz - Continuous Price Tracking
"Kit" is IZip - better quality components than EZip.
ChiefGeek   1 mW
Post by ChiefGeek » Apr 15 2013 10:47am
Drkangel,
Is it even necessary to remove the motor mount, just eyeballing it looks like the motor sprocket could be removed without loosening anything? Not much space between sprocket and spokes, but enough? Thanks. (still waiting on part from China)
matt912836   10 W
Post by matt912836 » Apr 19 2013 10:04am
ChiefGeek wrote:Drkangel,
You also have to lengthen the chain so I think you would still have to take it off
skeltonh   10 mW
Re: 13T Drive Sprocket - Noob chain question
Post by skeltonh » Apr 23 2013 7:31pm
DISCLAIMER: I'm real new to biking, particularly on my new eZip Trailz. So please bear with me....
I have received my 13T sprocket and wanted to know what size chain I need to get to support it. Do I use a normal bike chain? A 1/8 industrial for the drive motor? I do I get a length of chain, count x spots and use a chain breaker and a new master link to put it on?
My thoughts on this are to go to Walmart and get a length of chain, a chain breaker, and a master link (if not already in the bag with the length of chain). Try to wrap this around the new gear and the other one, and figure out what link I need to punch to put the master on and get me running.
Or should I just take the bike to a local shop and have them put the new chain on the motor, et al?
Thanks.
DrkAngel   100 GW
Post by DrkAngel » Apr 23 2013 8:13pm
DrkAngel wrote:Finally got around to trying the 13T mod on an eZip.
Results ...
1/2" x 1/8" - single speed (410) chain
"15 - 2 T links - 30 tooth holes" ... ?
The existence of the "half link" has me being tentative about calling a 1 tooth segment a "link".
I used a Walmart "chainbreaker" to build proper length chain.
Chainbreaker will put chain back together without using master link-repair link.
As mentioned previously, this requires some disassembly, but produces a "better job".
Bell chain, from Walmart includes repair-link-master link, if you want to go that way.
Plenty of chain left if you want to try a single "solid" chain later ...
ChiefGeek   1 mW
Post by ChiefGeek » May 05 2013 9:05pm
Finally getting this sprocket swapped out. Uses a 10mm wrench, but what do you use to keep the sprocket from spinning when trying to remove the nut? Thanks. :)
DrkAngel   100 GW
Post by DrkAngel » May 07 2013 8:01pm
ChiefGeek wrote:Finally getting this sprocket swapped out. Uses a 10mm wrench, but what do you use to keep the sprocket from spinning when trying to remove the nut? Thanks. :)
You could purchase a chain whip ...
Much cheaper to back a small block of wood between chain and sprocket.
If chain already removed, a pair of pliers, in "wide" position, should hold sprocket.
Since this will be your 1st eZip rear wheel work ... as you are disassembling and reassembling, consider the advisability of installing a quick motor disconnect!
XYD-16 Bracket.JPG (74.92 KiB) Viewed 8186 times
ChiefGeek   1 mW
Post by ChiefGeek » May 07 2013 8:35pm
Got the nut off, now the sprocket still will not come loose. Does this require some special tool? Thanks. :?:
DrkAngel   100 GW
Post by DrkAngel » May 07 2013 10:21pm
ChiefGeek wrote:Got the nut off, now the sprocket still will not come loose. Does this require some special tool? Thanks. :?:
You could purchase a gear puller ...
Much cheaper to pry with block of wood, under one side of gear then the other ... rocking from one side to another.
or
Partially loosen nut,
lift and hold by fingers under sprocket,
tap gently on nut with block of wood, screwdriver handle etc.
ChiefGeek   1 mW
Post by ChiefGeek » May 08 2013 6:47pm
Oh golly, got the old sprocket off, new sprocket has two sides (obviously), one side has a taller lip than the other. Which side goes down! :roll:
