meelis11
Hi,
something happened to my freewheel - if motor turns, its center part turns with shaft but sprocket is not turning under load. It turns when rear wheel is lifted from ground.
Has anyone had similar problem? It started to slip when started from stop (did not give much throttle, was gentle start)
Is it fixable or where I can get replacement?
Meelis
Meelis
