KONA Entourage Build Thread - middrive (pic heavy)
izeman   10 GW
Re: KONA Entourage Build Thread - middrive (pic heavy)
Post by izeman » Jul 21 2016 1:14pm
next step was installing the big central bearing. this is more or less a conversion of the "new style mac stator" to the old version. the new version looks like the bafang motors and have two bearings in the yoke. the old version has one big bearing installed in the stator.
the bearing needs to be held in place. so i built a little disc. the disc is 70mm diameter an 2.5mm thick. to install it i had to mill a circular groove.
then i made the disc, and i didn't do as my father said: measure twice cut once. so i drilled the holes in the wrong place. :) so i made a second disc. funny thing is, that making the second part always takes only about a third of the time?!
the disc is held down by 3x m4 screws. looks good :)
Foto 19.07.16, 19 34 32.jpg (97.36 KiB) Viewed 2199 times
Foto 19.07.16, 19 43 28 (1).jpg (99 KiB) Viewed 2199 times
Foto 21.07.16, 17 55 21.jpg (103.09 KiB) Viewed 2199 times
Foto 21.07.16, 19 56 16.jpg (104.83 KiB) Viewed 2199 times
John Bozi   1 MW
Post by John Bozi » Aug 17 2016 3:06pm
Subscribed... didn't see all the complexity involved till now so much work and modding so jealous of your skills!
well done
izeman   10 GW
Post by izeman » Aug 18 2016 2:31am
John Bozi wrote:Subscribed... didn't see all the complexity involved till now so much work and modding so jealous of your skills!
well done
thank you. further work has come to a stall a bit. there are so many things to do, and so little time left.
crossbreak   100 MW
Post by crossbreak » Aug 18 2016 3:56pm
nice to see u managed to get those two MAC versions merged. Yep doing more than one part speeds things up a lot....
I try to run mine sensorless ATM (old version with single big bearing), that seems to be not so easy though. Looks like a sensored Kelly isnt the worst thing at the end of the day. Maybe i should have given my old version 6T to you :D
izeman   10 GW
Post by izeman » Sep 04 2016 1:18pm
today i wanted to clean up the wiring and make it a bit less complex. well, a REALLY bad idea. at least if you forget to double check the polarity of your xt60 connectors. i installed the second one in my shunt setup reversed. connected it to the bike, and a lot happened :) fuse blew, contactor melted and the inrush limiters FETs exploded.
i didn't realize what the problem was, and checked AGAIN on my desk with my 12s lipo. hmmm. guess what: the 2nd inrush limiter went up in flames as well. not funny.
good news: v2.81 of lebowskis is a BIG improvement for the MAC. i runs quite well. some issues to sort out, but it's really nice already.
Foto 04.09.16, 20 05 17.jpg (113.91 KiB) Viewed 2019 times
Foto 04.09.16, 20 06 01.jpg (111.06 KiB) Viewed 2019 times
John Bozi   1 MW
Post by John Bozi » Sep 05 2016 3:30am
sounds similar to the flame thrower my mate experienced a few days ago with the same connectors.
glad you are ok
izeman   10 GW
Post by izeman » Sep 05 2016 4:05am
John Bozi wrote:sounds similar to the flame thrower my mate experienced a few days ago with the same connectors.
glad you are ok
thanks man! even if i put some smileys after my words it was quite frightning to see the switch go up in flames. the flames where coming from the heatshrink, but still ... smells really bad in the basement now. had to open all windows before the wife came down ;). i also observed the lipo very well. measured all cells, looked for swelling, heat etc. but i'm 100% it didn't take any harm. this was only a millisecond short.
and in the meantime i build a new inrush limiter.
Foto 05.09.16, 10 56 26.jpg (68.61 KiB) Viewed 1962 times
izeman   10 GW
Post by izeman » Sep 05 2016 4:08am
btw: did i ever mention, that soldering with soldering paste and a hot air station is really fun?! soldering smd components with the iron is ok, but putting on the paste which is not solder alone, but also keep the components in place, then adding heat and watch it melt. perfect soldering joints. i also added paste under the FETs to fix them on the pcb. much better for heat dissipation as well.
madin88   100 MW
Post by madin88 » Sep 05 2016 9:56am
glad you are ok
OMG! same thing happened in my case. the result was a dead controller and of course the connectors too (XT with antispark are not cheap).
looks like a curse rests on those connectors haha
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
izeman   10 GW
Post by izeman » Sep 05 2016 11:39am
i hope i didn't burn the controller. so far all seems fine. i had a FUSE in the battery line, and the inrush limiter's FETs blew right away. so i guess there was no voltage going to the controller "behind" this circuit. i HOPE.
i now integrated 3x 5mOhm shunt in parallel directly into the GND wire. no way i can connect anything wrong now.
izeman   10 GW
Post by izeman » Sep 06 2016 3:14am
the inrush limiter for my bench 12s pack is revived again. brushed off all the burn residues and installed new FETs. like new again :)
Foto 06.09.16, 10 08 46.jpg (146.47 KiB) Viewed 1929 times
izeman   10 GW
Post by izeman » Sep 07 2016 11:46am
first test run of the new motor. not the most silent ever :) there is some alignement needed. the freewheel inside is not in it's correct place it seems *ggg*
izeman   10 GW
Post by izeman » Sep 08 2016 5:24am
i swapped the yoke and the freewheel and now everything runs nice. noise is higher in the video than it's in real life.
in the bike it's dead silent. there needs to be some tuning in the controller be done, these are the funny sounds your can hear.
izeman   10 GW
Post by izeman » Sep 09 2016 7:09am
here are some pics of the side cover, nice and shiny, and the controller case. i made the two side covers. it still needs a heat sink on top, atm i'm looking to find a suitable one.
Foto 07.09.16, 15 54 55.jpg (132.71 KiB) Viewed 1843 times
Foto 09.09.16, 14 01 44.jpg (107.52 KiB) Viewed 1843 times
aCeMadMod   100 W
Post by aCeMadMod » Sep 09 2016 7:14am
hi if your bike Ever has babyies . can i hug one , great work 8)
http://mentalfloss.com/article/79196/25 ... out-babies
izeman   10 GW
Post by izeman » Sep 09 2016 7:33am
aCeMadMod wrote:hi if your bike Ever has babyies . can i hug one , great work 8)
lol. thanks. i'd invite to come over for a ride, but you're around 15tkm away. too far for a short trip. :(
izeman   10 GW
Post by izeman » Apr 20 2017 1:50am
the new controller case came from powder coating. it now has an external push button for "setup", and a waterproof 5pin serial connector. LEDs for drive mode.
both side covers where custom made from 2mm aluminium. the fins where shortened at the edges for a "better" look. controller stays super cool at 120A phase. not even warm at the touch.
2017-04-08 at 09.37.48.JPG (66.02 KiB) Viewed 1443 times
2017-04-07 at 18.18.36.JPG (100.19 KiB) Viewed 1443 times
Animalector   10 kW
Post by Animalector » Apr 20 2017 4:17am
Nice work .. 120A phase hey. Nice...
izeman   10 GW
Post by izeman » Apr 20 2017 8:51am
Animalector wrote:Nice work .. 120A phase hey. Nice...
i'll up that to 150A as soon as lebowskis firmware reaches it's next level :)
the mac is REALLY as MOTOR FROM HELL. very difficult for a controller to drive it seems.
150A is the limit of the current sensors, the IRFB4468 handles 190A. and as cooling is fine, and peak current is only needed for some seconds, it should be fine. total power limit is 2.000W, so it's 50A battery. something the FETs don't even may notice *ggg*
and phase current is REALLY needed for getting the bike to move. i see a difference between 100A and 120A. 150A may be even more noticeable.
due to the sine wave torque throttle characteristics the power delivery is VERY smooth. nice to handle, but on the other hand, not really "snappy".
it's impossible to lift the front wheel by throttle only. something that should work in the first gear with 2kW with ease.
the other lightning rod-style mid drive i have, that is driven by a 12FET infineon is wheely prone as hell. it's limited to 2.5kW and block time is set to zero. don't want to know what this bike does when a block time of 1-2s. ;)
izeman   10 GW
Post by izeman » Apr 05 2018 12:55am
short update: the rc lipo was replaced by 18650 lion cells. 150 of them. the pack is divided in two 15s5p packs. one on each side, and it's a perfect fit. capacity has grown from around 890Wh to 1620Wh. so a real range of 50km is doable.
here is the thread for the battery build: https://endless-sphere.com/forums/viewt ... 1#p1354420
and here are some teaser pics:
2018-02-12 at 08.11.07.JPG (86.08 KiB) Viewed 723 times
2018-02-17 at 13.08.16.resized.jpg (162.46 KiB) Viewed 723 times
2018-02-17 at 16.36.59.resized.jpg (150.69 KiB) Viewed 723 times
