BIG BLOCK alternative Motor
maitilupas   100 W
Re: BIG BLOCK alternative Motor
Post by maitilupas » Jun 19 2018 12:16pm
wait, try what Adam recommended me this morning , hall sensors capable of higher gauss point , i think he means that can be capable of high vdc , he suggested like 466
i will try and see i think this makes sense
eee291   10 kW
Post by eee291 » Jun 19 2018 12:20pm
Sorry, but I'm not replacing the sensors again.
Update: Ran the Motor with the Sunwin Controller with awesome results. The bearing is toast though, so I'll have to replace it but otherwise it runs fine.
Good enough for me
trazor   100 W
Post by trazor » Sep 19 2018 7:30pm
I don't know if this is news but looks like something similar to the original BHT is back in stock: https://www.e-bike-diffusion.com/index. ... _num%253D2
Altair   100 W
Post by Altair » Sep 20 2018 7:14pm
Yep!
But I'm not sure that this small shaft of 10mm will be able to withstand the pull of the chain with 3000W... :(
skeetab5780   10 MW
Post by skeetab5780 » Sep 20 2018 8:25pm
Altair wrote:
Sep 20 2018 7:14pm
Yep!
Odd the original BHT motor had a 18mm shaft at its fat point, i cut off the smaller portion that held the stock 8t sprocket
trazor   100 W
Post by trazor » Sep 20 2018 8:47pm
Altair wrote:
Sep 20 2018 7:14pm
Yep!
I never had this or the original BHT motor in my hands. I really don't know if it can withstand the torque. What I've here and is holding well is a LightningRod's Big Block and the output shaft (not the internal) is 12mm and can withstand a lot of abuse. Never had a problem.
I hope somebody purchase this motor and do a review. I've just purchased a Denzel D4500 and I bet it is probably the best big block alternative at the moment.
Altair   100 W
Post by Altair » Sep 20 2018 9:21pm
It's not the torque that is going to be a problem, but rather the bending force of a chain pull of many hundreds of pounds, acting about 1 inch from the bearing.
The shaft material will fatigue and eventually will break off right at the bearing.
maitilupas   100 W
Post by maitilupas » Sep 22 2018 2:45am
i broke 1x 520 sprocket and 3x #219 kart sprockets in these 15mm shafts, shafts still intact!
(front sprockets)
Altair   100 W
Post by Altair » Sep 22 2018 9:11am
A 15mm shaft is about 3.3 times stronger than a 10mm shaft.
A18mm shaft is 5.7 times stronger than the 10mm one.
Altair   100 W
Post by Altair » Sep 22 2018 9:13am
This "new" BHT motor looks like it was made to be matched to a gearbox, with this small 10mm shaft.
maitilupas   100 W
Post by maitilupas » Sep 22 2018 1:34pm
good for me! thanks for sharing will maybe be interesting if it has low weight to a mtb frame or so
