LMX P2 : Freeride trials motorcycle frame development
skeetab5780   10 MW
Re: LMX P2 : Freeride trials motorcycle frame development
Post by skeetab5780 » Oct 18 2018 9:48am
brumbrum wrote:
Oct 17 2018 9:00am
Or maaan! I want some stickers on mine.
They do make the bike look really nice! Turns it from a custom fab looking piece of aluminum, to a beautiful machine!
brumbrum   100 kW
Post by brumbrum » Oct 25 2018 8:48am
Adam has ordered in some 14t sprockets for the lmx motor. I will be trying this soon with a 100t rear sprocket from eBay. This will give a slightly lower gearing ratio of approx 7.2:1 instead of the original 7.8:1 With the idea of reducing some noise from the original 12t front sprocket. The lmx161 noise is not too bad as long as the chain is well lubed. I am using chainsaw oil at present which is like treacle but does need constant re-application. Calming the front sprocket noise is the main aim
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
Artur   100 kW
Post by Artur » Oct 25 2018 9:11am
Chainsaw oil :-) that's something new in ebikes world.
maitilupas   100 W
Post by maitilupas » Oct 25 2018 5:59pm
brumbrum wrote:
Oct 25 2018 8:48am
I use to have the previous #520 chain in the LMX , that WAS 10x louder than 219
have you tried a #219 O-ring chain ? there is less friction so might have less noise
brumbrum   100 kW
Post by brumbrum » Oct 26 2018 1:32am
maitilupas wrote:
Oct 25 2018 5:59pm
brumbrum wrote:
Oct 25 2018 8:48am
Yes, An 'O ring' sealed chain is own my list. once i measure up chain length with the new sprockets i can then get correct size. Every little helps.
bzhwindtalker   1 MW
Post by bzhwindtalker » Oct 26 2018 1:52am
We will also test the 14T on the LMX 81 to reduce noise there also, now that we have a solution with more phase amps.
maitilupas   100 W
Post by maitilupas » Oct 26 2018 2:33am
With larger chains Rule of thumb is usually 3 rear teeth’s equals 1 at the front .
Not sure how is it with 219 ,
But 3 more at the front will take maybe 9 at rear , but as Adam says we now have more amps there’s really no need for huge sprockets you can control this nicely with the controller so we can adjust the best chain setting to be as reliable as possible and less noisy as possible too
maitilupas   100 W
Post by maitilupas » Oct 27 2018 12:36pm
woudlnt also make sense now to re use the #520 . if using bigger front sprocket? im more confident with those chains specialy for the lenght we are using ( 200 links or so )
efMX Trials Electric Freeride   100 kW
Post by efMX Trials Electric Freeride » Oct 27 2018 6:27pm
420 pitch (pit bike) chain should be plenty strong .. 520 chain would be heavier and probably overkill IMO..
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
maitilupas   100 W
Post by maitilupas » Oct 27 2018 11:08pm
efMX Trials Electric Freeride wrote:
Oct 27 2018 6:27pm
ouch :D indeed #420 CORRECTION, actually lmx used #415 !
brumbrum   100 kW
Post by brumbrum » Oct 28 2018 2:11am
#219 chain should be plenty strong enough :thumb:
dan974   1 kW
Post by dan974 » Nov 01 2018 8:01am
congrats adam !
DolphLundgren   10 mW
Post by DolphLundgren » Nov 07 2018 11:06am
Adam Raga :)
I like how the bike performs in this terrain.
bzhwindtalker   1 MW
Post by bzhwindtalker » Nov 21 2018 8:34am
Thanks,
I really like trials riding, we will work on some kit to improve trials ergonomics and performance in the future.
Also we have a new video in preparation with Aurelien Fontenoy, 3x MTB trials champion :
Merlin   1 MW
Post by Merlin » Feb 04 2019 8:31am
all pics here are gone :(
can anyone tell me what headset i need for the lmx 161?
straight 1/8 or its it tapered?
bzhwindtalker   1 MW
Post by bzhwindtalker » Feb 04 2019 8:34am
Straight 1" 1/8th ZS44
We have stock if you need spares
Merlin   1 MW
Post by Merlin » Feb 04 2019 8:55am
Thx... Thought you were busy.
Just waiting of my mails answer about "frameset" ;)
I would /want to buy a 2nd but Iam having still throttle issues and want to clear that before.
