LightningRods mid drive kit
LightningRods   10 MW
Re: LightningRods mid drive kit
Post by LightningRods » May 26 2015 9:03am
Rotems wrote: I don't think that this is the right place to ask for it but you are not responding to my emails.
This is absolutely not the right place. I did respond to this person's e-mail.
"I don’t mind that they stole my idea, I mind that they don’t have any of their own.”
-Nikola Tesla
Lightning Rods Web Site http://www.lightningrodev.com
Lightning Rods Facebook Page https://www.facebook.com/pages/Lightnin ... 4531978401
LightningRods   10 MW
Post by LightningRods » Jun 06 2015 9:29pm
Russ T just sent me this YouTube link of his Motobecane fat bike climbing some pretty steep hills. The amazing part? He had the 3 position power switch on the lowest power setting and never used more than 20% of the available power.
https://www.youtube.com/watch?v=dC_Y7wk ... e=youtu.be
-Nikola Tesla
FluxShifter   10 mW
Post by FluxShifter » Jun 07 2015 3:36pm
Hey Mike can you post a list of your build queue. I cant wait to strap this drive to my Santa Cruz. 18s2p 16ah multistars for speed. 12s3p for range/pedal cadance. I hope there in stock soon so I can finalize the shape of my fiberglass battery enclosure. It's just a Styrofoam block at the moment. I ordered a 12t 15t and 18t #219 drive to play around with the ratios.
Gear down Volt up
1st Build/Ride Schwinn 72v 26ah 1500w Leaf
2nd Build Santa Cruz Blur LT 72v 16ah Lightning Rods Mid Drive
Client Build Iron horse Quantum II 48v 15ah 1500w Leaf
4th Build Motobecane ht450 96v 26ah vented 1500w Leaf in 19" MC rim
E.S Engineered F.S Built
LightningRods   10 MW
Post by LightningRods » Jun 07 2015 3:44pm
I'm shipping orders that are six weeks old right now. You can tell where you are on the build list by when you ordered. If you ordered a month ago, your order should ship within two weeks. By the end of this month I hope to be shipping within 30 days.
-Nikola Tesla
izeman   100 GW
Post by izeman » Jun 08 2015 2:48am
FluxShifter wrote:... 18s2p 16ah multistars for speed. 12s3p for range/pedal cadance. ...
RANGE shouldn't change if you re-arrange your batteries but keep total number of cells the same. the capacity you have stays the same, so does your range. so if you just ride slower with your 18s setup your range will be the same as 12s, with the advantage of sending lower amps to the motor.
FluxShifter   10 mW
Post by FluxShifter » Jun 08 2015 7:42am
Yes but it will be alot easier to pedal along at 48v than 72v wich adds to my range. I could lower the amps at 72v and help run cooler. Either way with 2.3kwh of battery I should be able to get down the trail pretty far.
Gear down Volt up
r3volved   100 kW
Post by r3volved » Jun 08 2015 8:09am
FWIW, I can only peddle at 72V up to about 30kmh. From 30-50 I might as well be peddling backwards. I also have the chainring set up for speed, not cadence.
If I limit to 2.5kW, I can forcefully peddle and feels more like assist...@72V 5kW peak, the acceleration is so fast that I only get about 2-3 peddle rotations before it's past my cadence.
Deanwvu   100 W
Post by Deanwvu » Jun 11 2015 4:09pm
LightningRods wrote:The current kit can be used on a recumbent by mounting it on the crank boom. I'm really interested in building a recumbent with the motor in between the seat and rear wheel. I have a new two jackshaft design that has a lot of advantages. On a bike with a very long chain run, like a cargo bike or recumbent, one advantage is that it separates one long and problematic chain into two more normal length runs.
I'm currently building a mid bike drive for the Lunacycle fat bike. Following that will be a Surley Big Dummy cargo bike that's on my build bench. I'd love to follow that up with a recumbent.
Mike,
One thing at a time, I know :) But, what recumbent model were you looking at? I assume you would do a similar design to your BD/Luna bikes?
The BD will be my commuter and my workhorse. One day I hope to get a LWB recumbent (and sell my SWB recumbent) with fairing and the works for long-distance bikepacking/touring. It's not a priority, perhaps many years away, but I was curious as to which model you were thinking of building on.
http://www.endless-sphere.com/forums/vi ... 28&t=70368 My Big Dummy drive by LightningRods.
LightningRods   10 MW
Post by LightningRods » Jun 11 2015 4:23pm
I haven't found a model of recumbent tadpole that I've latched onto yet. What I have seen are a number of models of recumbents that use ALL of the premium space behind the seat for the rear suspension gubbins.
Having the mid drive between the bottom bracket and rear wheel is definitely the way to go when possible. Two manageable short chain runs instead of one long one, more gearing options, less motor reduction required making it possible to use bigger drivers and smaller drivens, and a stock bottom bracket with no motor wear and tear going through it.
Dean sent me his Surly Big Dummy frame months ago to design the cargo bike mid drive. It's nearly finished and he gets the first one. :D
-Nikola Tesla
Deanwvu   100 W
Post by Deanwvu » Jun 11 2015 6:03pm
Ahh, I was thinking you were looking at 2 wheel recumbents, but you are looking at trikes?
LightningRods   10 MW
Post by LightningRods » Jun 11 2015 6:11pm
Yeah I've been looking at tadpoles so far. The same ideas do apply to the two wheeled recumbents as well.
When I first got interested in building my own EV I was thinking about something in between an electric tadpole recumbent and one of the T-Rex three wheeled motorcycles.
-Nikola Tesla
Deanwvu   100 W
Post by Deanwvu » Jun 11 2015 6:24pm
The Tour Easy LWB recumbent would be a good choice. Plenty of options like fairing, and plenty of space to mount a drive and batteries, etc.
Remus   100 W
Post by Remus » Jun 11 2015 11:33pm
Hi all,
I'm looking at mountain bikes to purchase to fit my ordered 1500 kit onto.
Are there any mounting limitations to the downtube shape I need to be aware off ?
I've noticed that a lot of modern mountain bikes have a curved down tube near the chain ring.
The Specialized Camber For example :
http://cdn.coresites.factorymedia.com/b ... G_1752.jpg
I noticed that the 2nd bike listed on the Customer Rides Page, on LIghting Rods web site here appears to be a Kona Stinky, which has a milder curve in the down tube than the specialized camber. http://www.lightningrodev.com/rides/index.html
Thoughts, Experience, and comments very welcome.
LightningRods   10 MW
Post by LightningRods » Jun 11 2015 11:40pm
Deanwvu wrote:The Tour Easy LWB recumbent would be a good choice. Plenty of options like fairing, and plenty of space to mount a drive and batteries, etc.
I'm sure that the Tour Easy works well but -damn- that girl would need to have one great personality before I'd date her!
-Nikola Tesla
1BFC   10 mW
Post by 1BFC » Jun 12 2015 1:18am
1080p60 video of the BB kit on a Motobecane Sturgis bullet.
https://www.youtube.com/watch?v=EXMmedVzNUA
I have this limited to 3kw right now. No issues in any gear except 10t rear, 10t only handles about 1.5kw before the derailure can't keep enough wrap on it.
Super super happy with this bike and Mike's product. Will post a final video that shows all of the aspects this machine does well now. It rides slow, it rides fast, lifts the front on demand, all in a controllable manner.
Note this is very close to how it actually sounds too. Tires, brakes, rear wheel freewheel are all about the same noise level as the motor. I use an 18fet Lyen so likely this can be made quieter with a sine wave controller if noise is a sticking point.
you NEVER hear a belt or any of the chains....they are all silent. Freewheels make all the noise to be hoenst.
Deanwvu   100 W
Post by Deanwvu » Jun 12 2015 7:11am
Yes, but the problem with the "sexy" 2-wheel recumbents is the general lack of space to mount things like a mid-drive. My Bachetta is literally just a stick with wheels and a crank--no way to reliably mount one of your rigs to it.
LightningRods   10 MW
Post by LightningRods » Jun 12 2015 8:55am
Deanwvu wrote:My Bachetta is literally just a stick with wheels and a crank--no way to reliably mount one of your rigs to it.
If your bike looks like this:
I could definitely mount a mid bike drive reliably to that big frame tube. I'd have most of the drive under the frame. Certainly the drive sprocket. I think it'd be awesome. Maybe once you have your Big Dummy back home. :D
-Nikola Tesla
Deanwvu   100 W
Post by Deanwvu » Jun 12 2015 9:34am
That is my bike, yes, except that I have a 20" front wheel instead of the 26" shown in that photo (mine has a 26" rear wheel and a 20" front).
Where do you think it would be placed? Behind the seat or ahead?
Nice thing about this frame is that it's REALLY easy to ship--it's basically a large baseball bat :)
Deanwvu   100 W
Post by Deanwvu » Jun 12 2015 9:40am
I also have one of these, and I'd like to be able to keep it and use it (be a great way to mount batteries, actually):
LightningRods   10 MW
Post by LightningRods » Jun 12 2015 9:54am
I was thinking about mounting the drive right where the rear mounting bracket for this thingy is. Probably motor and primary reduction above the frame, the second jackshaft with the pedal input and final drive sprocket below the frame. As long as the frame tube is smaller in diameter than the motor is wide it would work sweet. If the frame tube is over 3" in diameter you may have to go for the big block. Oh darn!
-Nikola Tesla
Archer   10 W
Post by Archer » Jun 12 2015 1:43pm
What would be bad ass is a LR kit on any of these 3 or 4 wheel trikes! Pics from Utah Trikes.I'm seriously wanting a trike or quad for winter transportation.And would need electric drive for the snow as I would tire out much to fast trying to pedal thru several inches of snow.
LightningRods   10 MW
Post by LightningRods » Jun 12 2015 2:04pm
:shock:
Ohmygawd, I'm in lust! How much fun would one of these be with a big block on it??
-Nikola Tesla
LightningRods   10 MW
Post by LightningRods » Jun 12 2015 2:17pm
Question: If it has four wheels and power assist are you getting into a weird place with the law? If it has three wheels it can be Chevy V8 powered and it's still a motorcycle. Do the pedals keep this a "cycle" instead of a motorized vehicle?
-Nikola Tesla
spinningmagnets   100 GW
Post by spinningmagnets » Jun 12 2015 2:25pm
That was my first thought...3-wheel tadpoles (of all sizes and power plants) have been a fascination to me for quite some time...
r3volved   100 kW
Post by r3volved » Jun 12 2015 4:21pm
As sweet as it is, it would be illegal in Ontario...even motorless it'd be illegal on public land and roadways. The law is <=3wheel ...silly. Those would be so fun. I always liked the 4wheel hand bikes too
