new handmade e-bike from Italy
fk100extreme   1 µW
Post by fk100extreme » Jun 03 2014 11:22am
Hi everybody.
My name is Nik and I live in Italy.
Here you can find my new handmade e-mtb.
Ciao
ENGINE
I put a BBS1 350W 18Ah on my new bike. In In the original version it is too weak for an off road bike, so I removed the original software and put a new one without any restrictions, so I can reach also the max power ( 640 watt).
The original software is crazy for the off road use.
On my display I have 9 level : I set a specific power for any level .
BATTERY
36 V 14.5 Ah made with 50 rechargeable cells Li-Ion Samsung INR18650-29E 3.7V 2900 mAh / 3C
FRONT CHAINRING /COGSET
42T CNC chainring. Especially CNC machined to better cope with very steep tracks,
weigh 100 gr. less than than the original 46/48T and gives you higher cadence and better chain line.
Black Anodized Aluminium 7075 (Ergal).
I changed also the last cog of the gocset. I fixed a 42T.
FRAME
Handmade on my garage
r3volved   100 kW
Re: new handmade e-bike from Italy
Post by r3volved » Jun 03 2014 11:25am
Beauty job!
I really like the inverted motor mounting! Real nice looking frame too
spinningmagnets   100 GW
Post by spinningmagnets » Jun 03 2014 12:17pm
Nik...benvenuto a ES, la bicicletta è meraviglioso!
ferret   1 kW
Post by ferret » Jun 03 2014 12:19pm
Great stuff!
Don't believe everything you think.
Cove GNG-Spot build thread
Astral Rune build thread
Kepler   1 GW
1 GW
Post by Kepler » Jun 03 2014 11:58pm
Fantastic work. Well done.
Current Rides
Lightest true ebike on the planet: ON ROAD viewtopic.php?f=6&t=74269
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
panurge   10 kW
Post by panurge » Jun 04 2014 2:57am
Bravo Bravo!!!!
E benvenuto, Ormai potremmo formare un bel gruppo ES Italiano...
Proprio un bel telaio, il montaggio rovesciato è perfetto!!!!
We're all waiting for videos....
JulesL.
Forsan et haec olim meminisse iuvabit
Onion MP6 - recumpence drives - CAV3 - CC HV160ESC - Astro 32204t
fk100extreme   1 µW
Post by fk100extreme » Jun 04 2014 7:17am
Hi, thank you to everybody.
Here you can see my first e-bike . I calls it the “Spider Bike” and it is powered by a 500W Cyclone motor. With 500 watts you can easily use this bike as “an electric chair lift” .This bike does not use derailleurs, but instead uses in IGH (internal geared hub) transmission, the German made Rohloff.
The Spider E-bike has an electronic dashboard mounted on the handlebars and is throttled automatically via the highest quality torque sensor available which is built into the bottom bracket (THUN sensory BB-cartridges X-cell RT)
The bike has a 36 volt, 12-Ah, 432-WH, LiFePO4 Headway battery pack with a BMS. As you can see I took the time to elegantly package his cells and BMS.
I managed to mount both the battery and motor into the triangle. The bike uses freewheel crank arms, so that the bike freewheels like a regular bike when the motor is not engaged:
The controller is up top above the battery. Because the controller is only running 36V at 15A it is fairly small and should be ultra reliable even when climbing.
To finish off the look the battery box is cut in a web pattern.
I decide to make another bike for 2 reasons
1) reduce the noise ( cyclone is very noisy)
2) reduce the weigth . Spider 27 Kg, X-bike 22 kg
spider am.JPG (116.23 KiB) Viewed 1113 times
Lebowski   1 GW
1 GW
Post by Lebowski » Jun 04 2014 7:19am
are you sure the cyclone is making the noise and it's not due to a crappy controller ?
fk100extreme   1 µW
Post by fk100extreme » Jun 04 2014 8:33am
Lebowski wrote:are you sure the cyclone is making the noise and it's not due to a crappy controller ?
Hi Lebowski, ......I am not sure if tthe noise depends from the cyclone (gear reduction) or the controller. can you help me about it. can i perform a test to solve this doubt?
1KW   1 kW
Post by 1KW » Jul 05 2014 10:18pm
sick bike! whats the power band like with that crazy cassette? ride it on street and off road? been reliable for you?
Post by spinningmagnets » Jul 06 2014 5:51am
I am surprised that to this day, Cyclone/headway hasn't developed a helical-geared reduction, and a sine-wave controller. I remember 5 years ago, there were builders who said that they hate the noise, but they live where the hills are extremely steep, and the cyclone was the only drive that would survive it, since it was a mid drive. (there are many more choices now, of course)
Post by spinningmagnets » Jul 06 2014 5:55am
Here's the story on Nik's Spider bike from August 2012:
http://www.electricbike.com/cyclone-mountain-e-bike/
free-trade   10 mW
Post by free-trade » Jul 06 2014 6:00am
Fantastic work. I like the engineering, looks very clean.
Do you know the weight of the bike?(Ready to Race :mrgreen: )
kentlim26   10 kW
Post by kentlim26 » Jul 06 2014 6:16am
I like the frame very much, it was a very nicely work. my friend you could do a production for the frame and sell them here. if he drop out can be adjusted to 149mm or 150mm , or choose 135mm will be good product people will look for you. hopefully you can ship through out the world . so this frame can accept chromo motor or a cyclone motor, huge or a small one.
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
skeetab5780   10 MW
Post by skeetab5780 » Jul 06 2014 7:40am
superb job, this bike is a pleasure to look at. It seems that you used the same swing arm for both bikes?
Keep up the great inspirational work!
jateureka   10 kW
Post by jateureka » Aug 01 2014 8:23pm
Nik, that is a lovely custom BBS01 MTB you have made there!
Can you please post some more photos of it?
Some nice pics of the Spider here too http://www.extreme-mobility.it
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Aprilia 7s LiPo; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, Kilovac EV-200 contactor
E-mower: EGO 56V mower & line trimmer
Bikengineer   10 mW
Post by Bikengineer » Jan 10 2015 10:58pm
Nice frame, looks light, puts BBS clear of damage, nice low/centre battery weight distribution.
I've ordered a BBS01 350w for a carbon fibre frame 29er MTB I already own. Am concerned mounting a frame battery to only 2 water bottle bolts in carbon fibre might be risky off road?
Can you give more info on software programming? I'd like max power for trails but legal for road. (200/250Pedelec). If it says BBS01 250W on motor I'm sure it won't be a problem on road.
LI-ghtcycle   1.21 GW
1.21 GW
Post by LI-ghtcycle » Aug 07 2016 12:52am
Great Job!
I will enjoy seeing more of your handiwork, that is one of the better designs I have seen yet, even better that it was hand made! 8)
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
Back on track E-Bronco! Now with Cro Motor Mid-Drive Goodness!
https://endless-sphere.com/forums/viewt ... 28&t=44997
Vision R40 w/3000w MXUS as mid-drive, NuVinci N171B rear wheel as transmission, Silent yet powerful, running 72v 11.6 ah (20s 18650 Li-Ion) to climb hills, tow trailer with zero pedaling when needed!
https://endless-sphere.com/forums/viewt ... 28&t=75247[/size]
waynebergman   10 kW
Post by waynebergman » Aug 07 2016 11:21am
Super nice bike, way to go FK. How do you compare the IGH experience on your first bike to the setup you have now on the newer bike?
macribs   1.21 GW
1.21 GW
Post by macribs » Aug 09 2016 4:52pm
Don't think you will be getting any answers. Seems like a year and 6 months since he last time was logged on. And only has 3 posts.
Too bad really, as he did some banging work on both his bikes.
