LightningRods mid drive, spinningmagnets' build
Postby spinningmagnets » Wed Jun 25, 2014 8:47 am
For info on the history of the development of this drive, here is the original thread:
"LightningRods mid drive kit"
http://endless-sphere.com/forums/viewtopic.php?f=28&t=57720
I write for electricbike.com, and when I explained to the senior editor why this new drive was so great (IMHO), he bought me the first production unit. It was partially so we could test review it, but since I don't get a paycheck for writing, this is also an occasional perk (Thanks, Eric!).
The package was well-packed, so the parts arrived without any being bent, scratched, dinged, or broken.
LR1 002.JPG (90.21 KiB) Viewed 18729 times
The first order of business is to start the search for a local bike that is worthy of this drive, so I am using a common 8 X 11 manila folder as the template.
LR3 001.JPG (95.37 KiB) Viewed 18729 times
This particular fork only has about 4 inches of travel, but it still looks like I'll be fine to do some experiments with this one while I search for the "perfect" frame. I'll post dimensions for a template for those who want to see if it will fit their favorite frame before committing to buying the kit.
LR4 001.JPG (76.24 KiB) Viewed 18714 times
I'll add the dimensions tomorrow (*yawn...)
I think the easiest way to make this template is to start with drawing the green triangle. The three points of the triangle are the centers of the BB, the motor, and the jackshaft. The horizontal line is 5-3/4 inches (146 mm), the short vertical line on the right is 4-3/4 inches (121 mm), and the long line is 9-3/8 inches (238 mm).
Next draw the four black circles. The motor and jackshaft pulley are both 5-3/4 diameter. Half the diameter is the radius, 2-7/8 inches. (diameter 146 mm, radius 73 mm). The two circles for the BB are the inside diameter of the hole and the outside diameter of the bracket. the ID is 1-5/8 inches (41mm), and the OD is 2-1/4 inches (58 mm).
Now to draw the red lines. I laid the long edge of an envelope on the vertical green line on the right, in order to make a 90-degree angle. Then I drew the short red line pointing to 10:00 O'Clock from the center of the jackshaft. Draw it out a length of 1-3/8 inch long (35 mm).
Get a straight-edge at least a foot long and draw the long red line by connecting the edge of the circle that defines the BB ID, and that mark you made on the red line that makes it.
Draw the two red lines near the bottom that connect the big circles, and the short red line that is above the BB is parallel with the red line below it. Cut out the outer shape, and then cut the template BB in half so you can hold the template up to the front half of a bikes BB
Last edited by spinningmagnets on Thu Jun 26, 2014 9:54 am, edited 6 times in total. View post history.
spinningmagnets
Re: LightningRods mid drive, spinningmagnets' build
reserved for final results and pics
Last edited by spinningmagnets on Wed Jun 25, 2014 8:47 am, edited 1 time in total. View post history.
spinningmagnets
Postby t0me » Wed Jun 25, 2014 10:08 am
love the template idea, gonna be stealing that :-)
Kona Stink-E - GNG based mid-drive - viewtopic.php?f=28&t=56357&p=839416#p839416
Giant Anthem - LightningRods mid-drive viewtopic.php?f=28&t=67014&p=1008007#p1008007
t0me
Postby LightningRods » Wed Jun 25, 2014 10:11 am
Yep, that's a good idea. It's also a good way to deal with custom bracket designs. Well done sir!
"It is possible to fly without motors, but not without knowledge and skill." -Wilbur Wright
Lightning Rods Web Site http://www.lightningrodev.com
Lightning Rods Facebook Page https://www.facebook.com/pages/Lightning-Rods/613804531978401
LightningRods
Postby teslanv » Wed Jun 25, 2014 10:21 am
Subscribed.
First Build: "Craigslist Hardtail"
Signature Build: "Assault & Battery"
Fastest Drag Bike: "Vector/QS205/Sabvoton"
Current favorite: "Super Deluxe IGH BBS02"
Spoiling my Children with an E-BMX
teslanv
Postby scorpionice » Wed Jun 25, 2014 10:37 am
subscribed... :lol:
scorpionice
Postby r3volved » Wed Jun 25, 2014 11:27 am
Nice!
Clearly it would fit my Chucker :D
Subscribed...
r3volved
Postby m4s73r » Wed Jun 25, 2014 3:36 pm
Im on board.
m4s73r
Postby waynebergman » Wed Jun 25, 2014 6:52 pm
Screen Shot 2014-06-20 at 5.11.11 PM.jpg (187.04 KiB) Viewed 18545 times
Go get em Ron! It will be great to follow all the build threads now with this new kit up and running. I look forward to hearing about your progress and enjoyment of your new project. Thanks so much for collecting all the info regarding this kit and doing your bit to promote it. Awesome!
I know you are a big fan of the 18650 packs and also Cellman packs so I would like to recommend the good old Giant DH in your quest to find the right frame. I love this old frame and it lets you fit in one of Pauls 14.3 ah packs in the main triangle shown in the photo above.
This Kit and the Motoped stuff I what I am directing any people to look into that may inquire about the pedal assist world.
Last edited by waynebergman on Wed Jun 25, 2014 7:32 pm, edited 1 time in total. View post history.
waynebergman
Postby t0me » Sat Jun 28, 2014 3:03 am
Hi Magnets, in your template, the scale is cm or in?
Cheers,
Tom
t0me
Postby izeman » Sat Jun 28, 2014 7:18 am
how could that be cm? if it was the whole kit would fit in your palm. also there are 4/8 dividers in decimal world it would be 5/10.
izeman
Postby spinningmagnets » Sat Jun 28, 2014 7:42 am
It's in inches, but I just drew that scale to make sure the drawing was proportionally close to having the correct "look". Please don't use that scale to try to print out a template. If you follow the written instructions, you can draw a perfectly accurate template.
chain guide pic: viewtopic.php?f=28&t=42785&start=1425#p704856
Last edited by spinningmagnets on Thu Jul 24, 2014 10:05 am, edited 3 times in total. View post history.
spinningmagnets
Postby gwhy! » Sat Jun 28, 2014 8:21 am
I really wish you people across the pond will use a metric system instead of lbs and inches :mrgreen: it make things so mush easier to follow ..
Looking forward to your review !
gwhy!
Postby izeman » Sat Jun 28, 2014 9:05 am
spinningmagnets wrote:It's in inches, but I just drew that scale to make sure the drawing was proportionally close to having the correct "look". Please don't use that scale to try to print out a template.
i guess you could make a template with paint/photoshop and print it as .pdf. that should make it possible to print it out in the correct size?!
izeman
Postby m4s73r » Sat Jun 28, 2014 9:38 am
gwhy! wrote:I really wish you people across the pond will use a metric system instead of lbs and inches :mrgreen: it make things so mush easier to follow ..
You know being on this forum does force this to happen. That and you book mark the unit converter. What really gets old is when people start mixing the two.
m4s73r
Postby ebike11 » Sat Jun 28, 2014 10:22 am
Don't British people use stones or something for weight?? just as confusing
ebike11
Postby gwhy! » Sat Jun 28, 2014 11:52 am
lbs, stone, gallons , miles and inches ( but not as much ) wish it was all metric... :mrgreen:
gwhy!
Postby recumpence » Sat Jun 28, 2014 2:08 pm
How about the Cubit? :mrgreen:
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
Location: On Earth right now. That can change at any time, though..........
Postby t0me » Sat Jun 28, 2014 7:45 pm
I asked as it didn't look 100% right in cm OR inches.
A pdf would probably be the easiest way to get it to print to the right scale.
Cheers,
Tom
t0me
Postby gwhy! » Sun Jun 29, 2014 5:46 am
recumpence wrote:How about the Cubit? :mrgreen:
Matt
:mrgreen: don't even suggest it, because you know what will happen, people WILL start using it :lol:
gwhy!
Postby Megsy73 » Mon Jun 30, 2014 5:17 pm
Can you please do an unbiased review of this kit ? Or is it because LightningRods is a long time friend of yours that you will not point out the negative aspects of the kit ?
Megsy73
Postby spinningmagnets » Mon Jun 30, 2014 5:38 pm
Yes, I can review it in a completely unbiased way. Of course, It's possible I might be very biased and i'm just covering that up right now, so...I'll just trust that I have had a consistent reputation in my comments from when I started here in March 2009.
One thing I can say...based on my experience at being an avid reader who prides himself in identifying trends, the LightningRods kit should do just fine with or without me, no matter what I say.
BTW, I only corresponded with Mike after he first posted in the GNG thread (Nov 2012 viewtopic.php?f=28&t=42785&p=667278#p667278). We did not know each other back in Los Angeles when we both were young, but that fact was something that we found we had in common (he lives in Oregon now, I live in Kansas). We've never met, I only know him through ES...
Bikes I'm considering
http://www.walmart.com/ip/29-Iron-Horse ... e/26999361
http://www.electricbike.com/motor-tech- ... ms-part-1/
7-sp steel frame, Feet-Forward http://www.beachbikes.net/products/Firm ... e-230.html
Last edited by spinningmagnets on Sun Aug 03, 2014 11:46 am, edited 3 times in total. View post history.
spinningmagnets
Postby r3volved » Mon Jun 30, 2014 6:01 pm
It's still too early for a 100% review anyway. Other than the guys who've built up the gng with all the LR upgrades, no one has put any m/km on the 'kit' yet
r3volved
Postby teklektik » Mon Jun 30, 2014 6:53 pm
Seriously SM - stop wasting time answering rude 17-post twits and get building!
Your contributions have the respect of all - I for one am really looking forward to this build and review.
:D
Last edited by teklektik on Mon Jun 30, 2014 7:45 pm, edited 1 time in total. View post history.
teklektik
1 GW
1 GW
Postby Wishes » Fri Jul 04, 2014 10:19 pm
Looking forward to seeing what you turn out :)
Subscribed!
Wishes
Equality is about providing everyone with equal opportunities, it is not about guaranteeing equal results.
1st Build GNG Mid-Drive Kona http://endless-sphere.com/forums/viewtopic.php?f=28&t=52029
2nd Build, Stong GT-S210 modified with 5kw hub motor http://endless-sphere.com/forums/viewtopic.php?f=7&t=58056
Wishes
Next
Who is online
Users browsing this forum: scrambler and 14 guests
