Project: Home made velomobile design with crank or mid motor
tahustvedt   10 kW
Re: Project: Home made velomobile design with crank or mid m
Post by tahustvedt » Aug 14 2016 6:41am
Ideally I'd like to use a non-contact derailleur at the cassette and a large tensioner sprocket to reduce drag to an absolute minimum. The drawing shows a 76 tooth chainwheel. EDIT: Also it shows the chain line when in forst and in tenth gear to see if the tensioner would be able to span the full range.
nerdalert   10 W
Post by nerdalert » Aug 14 2016 7:39pm
Confused by the chain paths. Double sprocket/Double chain?
tahustvedt   10 kW
Post by tahustvedt » Aug 15 2016 2:45pm
No. It just shows both first and tenth gear so that I could see if the chain tensioner would work. :) However, it would be possible to make a two speed system with double chains that shifts up when the cadence gets high enough, using a centrifugal clutch. Would probably be really hard without assist to pedal through the shift though, and quite lossy with an extra chain system to drive.
nerdalert   10 W
Post by nerdalert » Aug 15 2016 8:23pm
Put a nuvinci n380 inline with a sprocket bolted onto the disc brake 6 hole bolts for power output to the differential? That's what I'd do :) No gears, no variable chain paths. Just 4 sprockets of the same size. They even have a "harmony" system that matches the gear ratio to your pedaling cadence and speed for CVT action. After I finish my prototype, that's what I'm doing.
Edit: second thought: it's also a flywheel :)
--freeride--   100 W
Post by --freeride-- » Aug 23 2016 4:27am
The nuvinci is nice but I would not want the loss of efficency cvt has in an efficient Velomobil.
As the chain does not see any dirt, it is going to be good for 20tkm so the Chaindrive is a real option in a Velomobil where it runs completely inside.
nerdalert   10 W
Post by nerdalert » Aug 27 2016 1:03am
I looked it up and you are right. 80%~ efficiency. How goes your project tahustvedt?
tahustvedt   10 kW
Post by tahustvedt » Aug 27 2016 8:49am
I have decided to take a break. I'll continue on the project at a later time.
orange streak   100 W
Post by orange streak » Dec 19 2016 2:24am
I absolutely love your velomobile! Just the way it's designed is perfect for my desires. Your spacious & flat floor would allow a person like myself to install 10kwh worth of Panasonic 18650 batteries. A nuvinci internal geared hub, & even better a mid drive hub motor driving the left side wheel via disk brake sprocket. I can imagine the milage I'd put on such a beauty, though solor would only contribute a little to range.
Windows, door, carry groceries, sunroof! I want one for such a purpose to replace any car. Consider even a hitch for a trailer to pull. I'm far from getting ahold of such a cool ride to implement what I know for now. Its 1,000 watts, & 30mph in Oklahoma. I'll keep working on my 7kwh ebike in the mean time. Happy riding.
Gotta Start somewhere
amberwolf   100 GW
Post by amberwolf » Dec 19 2016 2:33am
orange streak wrote:Windows, door, carry groceries, sunroof! I want one for such a purpose to replace any car. Consider even a hitch for a trailer to pull. I'm far from getting ahold of such a cool ride to implement what I know for now.
I don't have windows or doors (too hot here for a full enclosure), but have you looked at my SB Cruiser trike, and hte Mk III and IV trailers? (see my signature for links)
orange streak   100 W
Post by orange streak » Dec 19 2016 1:55pm
Nice, but actually wish to go out on a a limb & carry my battery capacity in a sweet enclosed velomobile. I already know how to build trailers, walls, ramps & I have a 8ft long key lime green trailer for my e-bike. I will be the guy others think is crazy, even my dad thinks I'm stupid!, & I want a velomobile instead of a car. Two seater is nice & debatable for a passenger or a daring girl friend.
I love this design, becuase it looks so such easier to start building with flat sides, avoiding & struggling with aerodynamic cone shapes. I'd use aluminum composite sheeting comes in multiple colors. I'm obsessed with obtaining such a velomobile bike to use for eveyday, & travel long distance. On the edge at 35mph. Want to pick up my tools, revit gun & build it now! What's the perfect trike to start with?
ScooterMan101   1 MW
Post by ScooterMan101 » Dec 20 2016 12:02am
What is the perfect trike to start with ? ... Yea that is the Million Dollar Question, I still have not found the answer, I think that because for you want to do, ( and I as well in the future ) there is no good non enclosed bicycle trike being made commercially at this time.
When visiting Florida some 7-8 years ago, I went to the Trike Mfg, there in the Middle of the State, forgot the name of the Mfg. , and I asked ... " Why do you make your trikes with such short wheel bases and such narrow width's "
His answer, because the way they / and the other Mfg's. make them , they can send them to the consumer for less than $ 75 for shipping ,
But
To make them more stable/usable / better as a velomobile they would be of a size that would require Freight Shipping, Several Hundred Dollars ... $$$ ,
A good Idea ( for a Tadpole Trike/velomobile ) would be to take a 250cc/500cc Quad that someone has blown the motor and is now not worth much, Cut off one of the rear wheels, widen the front end, ( you will now have to make a whole new center frame/ or just the rear if you want the front to be the same width )
Here are three examples of the concept of what I am talking about , only with thinner wheels / tires, lighter weight components all around , etc.
https://www.alibaba.com/product-detail/ ... 48200.html
https://www.alibaba.com/product-detail/ ... 62834.html
https://www.alibaba.com/product-detail/ ... 17778.html
Then
Take off Wheels/tires and find the Thinnest/Lightest Car Rims/Tires that will bolt onto the axles, or Small Light Weight Motorcycle Rims and Tires , and have an adapter plate machined for you to be able use such Wheels/Tires on the frame.,
Then build the body .
There are many pages to this thread, where is a link to the design you speak of that has flat sides ?
I am also of the Opinion that Flat Sides / with angles , will work and be easier to build, an example is the Facet V1 Velomobile .
http://www.instructables.com/id/Facet-V1-Velomobile/
Here is something interesting, can make a trike like this, without the Paragliding aspect.
http://inhabitat.com/zvezdan-nedeljkovi ... otorcycle/
orange streak wrote: I love this design, becuase it looks so such easier to start building with flat sides, avoiding & struggling with aerodynamic cone shapes. I'd use aluminum composite sheeting comes in multiple colors. I'm obsessed with obtaining such a velomobile bike to use for eveyday, & travel long distance. On the edge at 35mph. Want to pick up my tools, revit gun & build it now! What's the perfect trike to start with?
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
anotherkiwi   1 mW
Post by anotherkiwi » Jan 27 2017 6:31am
I liked your original velomobile and the new one is even better!
My project is to have a removable body for a trike (AZUB, HPVelotechnik...) because the summer is too warm here for an enclosed body. As you have run the design through aerodynamic tests it would be really great to have some drawings with dimensions to use as inspiration.
My construction method will be nautical: a mix of ply composite and skin on frame.
anotherkiwi   1 mW
Post by anotherkiwi » Mar 30 2017 7:04am
OK I have advanced some in my thought process. It is hotter than Norway where I live, and quite warm about 9 months of the year, so the canopy was not going to work all year round. I have redrawn so that the roof section can be removed (and stored in the nose). The canopy hinges further up the screen.
No, aerodynamics will not be perfect with the roof removed. I hope they will be better than a naked trike, the head rest section will be filled in. The second choice is to have a warm weather canopy and a cold weather canopy and swap them over. At the moment the wheel arches are off my list too: I would like to run 24" rims, I have issues with the under-seat steering fitting. So external wheels it will be. I am not going racing and any slight improvement in aerodynamics over a naked trike is fine with me.
Building method: skin (aircraft fabric) on a frame of ply and spruce
Chassis: AZUB T-TRIS 26
Power: Mxus 250 W hub in 26" or 24" rim, 12S 44.4 V LiPo, 17 Amp controller to begin with because it is what I have in stock. A 250 W 25 Amp Bafang BBS02 with a couple of 13 Ah Li-Ion batteries wired in parallel is my preferred upgrade.
Comments?
Wheazel   10 kW
Post by Wheazel » Mar 30 2017 7:41am
My only comment is super cool!
And I think you are on the right track with a removable cover for better comfort.
Also like the idea about putting it in the front like koenigsegg does with their cars.
