bbs02 installation question
izeman   100 GW
Post by izeman » Aug 30 2014 9:36am
got a bbs02 kit from paul/cellman. as always WONDERFUL service, and MOON as a great support!! everything came packed very well and in perfect condition.
i started installing it on a friend's bike (who needs to be electrified ;)) and the bike seems to be the perfect candidate for the bottle mount battery.
installing the motor is easy, but the lower frame is very wide, so i can't move the motor flush to the frame. the contact point is the case where it's screwed to the bottom bracket's bracket. *ggg*
i thought i could file it off a bit (the white circle in the second picture) as it should still be strong enough afterwards. what do you guys think?
nice bike:
and this is where the motor touches the frame:
maxwell92036   100 W
Re: bbs02 installation question
Post by maxwell92036 » Aug 30 2014 10:30am
Use a thicker rubber shim?
Wattwagon sales *E-bike kit sales and service
http://www.julianactive.com/Electric%20 ... mepage.htm
izeman   100 GW
Post by izeman » Aug 30 2014 10:32am
how would that help? i want the motor to move upward more closer to the frame and the screw mount is in the way - well a part of it.
tahustvedt   10 kW
Post by tahustvedt » Aug 30 2014 10:34am
The same thing happens on my fatbike. I'm just going to file off some of the motor tab. No problem other than possibly voiding the warranty.
maxwell92036   100 W
Post by maxwell92036 » Aug 30 2014 11:01am
izeman wrote:how would that help? i want the motor to move upward more closer to the frame and the screw mount is in the way - well a part of it.
the motor is meant to butt up against the down tube. There is a thin piece of rubber on the motor at this point. Just add a shim there so the metal doesn't hit against the frame.
izeman   100 GW
Post by izeman » Aug 30 2014 11:08am
i got a mail saying that it may be unclear as the pictures don't show any details, so i made a few more:
Russell   10 MW
Post by Russell » Aug 30 2014 1:31pm
Is the bottom bracket shell on that bike a standard 68 mm? It looks wider.
-R
Jeep Comanche Trekking Bike w/YOUE geared motor, 42 lbs + 15 lb rear trunk bag w/12S 16Ah LiPo battery, tools, etc., 21A controller, 700 x 40C tires. 27 MPH.
My other E-Bikes: Nashbar Steel Flatbar
izeman   100 GW
Post by izeman » Aug 30 2014 3:00pm
73mm unfortunately. i may make the bb narrower with a grinder.
maxwell92036   100 W
Post by maxwell92036 » Aug 30 2014 3:14pm
izeman wrote:73mm unfortunately. i may make the bb narrower with a grinder.
why do that?
I installed one on my Ti framed bike with a 73 mm BB she'll. It worked fine. Plus I don't think it will solve your main issue. And I wouldn't start grinding away on the motor either.
izeman   100 GW
Post by izeman » Aug 30 2014 3:57pm
i heard that the chain line is quite bad as the chain ring is moved far to the right. so grinding away 5mm from the right side would solve three problems:
.) chain line
.) motor mount not touching the frame
.) i can install both rings on the bb
if i ever need to remove the kit i can install a 68mm bb or use a 73mm and a 5mm spacer.
izeman   100 GW
Post by izeman » Aug 30 2014 3:58pm
why do that?
do you have close up pictures of the installed motor?
samsavvas   100 W
Post by samsavvas » Aug 30 2014 6:12pm
izeman wrote:i heard that the chain line is quite bad as the chain ring is moved far to the right. so grinding away 5mm from the right side would solve three problems:
.) chain line
No need to grind anything. It's not really clear from your pictures but you seem to face 2 problems arising from your use of a frame that the BBSxx is not designed for.
That is:
1. your down-tube seems to be an irregular shape and is pressing against one of the motor casing flange bolt mounts on the left side.
2. Your BB appears to be too wide (wider than 68mm anyway).
If you want to persist with this installation I'd suggest 2 simple solutions.
For problem #1, as someone has already suggested, just get a solid spacer that will go in between the curved motor casing and an appropriate contact point on the front surface of the down tube. I have found that a small section cut from a 14mm diameter hull 'bung' (extremely dense rubber) from a yachting supply shop was ideal for this purpose. Just shape a bit to fit the curved tube and glue on with contact cement.
For problem#2, use solid SS washers (or make some spacers from alu tubing) to put into the gap between left-side mounting flange and the threaded motor casing mounts. Trial tighten the BB ring first so you get a reliable measurement of the gap involved and select the number of washers or the spacer required. Do not use the original screws that some with the kit - they will be too short and you'll end up stripping threads in the motor casing (please don't ask me how I discovered this elementary point!) From memory, I think one of the 2 casing threads is 'blind' (that is, not open at it's end). With the flange secured by the BB ring, use a small rod or similar to measure the depth of the blind thread in the casing then add the 'gap' between casing and flange and then the thickness of the flange. This total - minus 1 or 2 mm for end clearance - is the maximum length of the 2 new M6 bolts you need to go out and buy (or cut from longer bolts).
This is a much easier strategy that grinding or cutting anything at the BB and is perfectly secure! Don't forget to use Loctite on the BB ring. Don't worry too much about chain line issues. IMHO it's an overly emphasised 'problem' and can be improved a bit by simply using less cogs at the rear - for everyday road use with the BBSxx you only need 3-5 gears anyway. Just set the derailleur stops to use the highest few gears on the cassette or freewheel (starting with the smallest) or - if you need your low gears for hills - just reconfigure your cassette with fewer 'smaller' or 'in between' cogs using appropriate free hub spacers to move the combination you end up with further to the right side of the wheel and set the stops on your derailleur as needed. I've used both these approaches quite satisfactorily.
Savvas.
Ps; I'd add - and I know it sounds a bit 'school-teacherish' - that the installation of the BBSxx kits will obviously be much simpler of the frame chosen is one the kit is designed for. There must be millions of such frames and bikes available - new and used - on the planet. Apart from an old Moulton APB, the kit will fit every one of the dozen or so bikes in and around my bike shed. All road or older MTBs to be sure, but all suitable candidates! Just a thought...
maxwell92036   100 W
Post by maxwell92036 » Aug 30 2014 7:12pm
I got extra washers and longer bolts on one of my kits specifically for a 73 mm BB. Nothing you can't get at most hardware stores. Just take in your shorter bolts to compare.
I solved my chain jumping off issues just by keeping the front derailluer on.
rolls   10 mW
Post by rolls » Aug 30 2014 7:51pm
I have just intalled a BBS02 on a Giant Trance. Same problem with the lug for the bolt. I filed the metal down on an angle just enough to get the motor flush with the down tube.
I also had to take off 1mm of the top of the lower RH swingarm bolt. May only be specific to the Trance, but something else to look out for if you're thinking of grinding the BB.
Totally agree about the service from Paul and Moon at em3ev. Top stuff!
I only installed the kit yesterday, and after a 20km ride I can see why everybody is raving about these fantastic kits.
izeman   100 GW
Post by izeman » Aug 31 2014 3:16am
thank you all for your input. sure i can add some rubber spacer and can make some aluminium or stainless steel spacers on the lathe for the gap between the motor on the bracket and use longer screws.
but why not cut off 5mm from the right side of the bb housing? with the right tools it a minute job and it will be a perfect fit afterwards with no additional spacers or stuff. and the motor will be moved upwards by at least a cm which will be welcome to add ground clearance.
i guess i will sleep over it one more night and decide what to do tomorrow.
btw: it's not that you have any options if the customers want a special bike to be converted. do it or leave it. i chose to take the challenge :)
samsavvas   100 W
Post by samsavvas » Aug 31 2014 4:57am
izeman wrote:thank you all for your input. sure i can add some rubber spacer and can make some aluminium or stainless steel spacers on the lathe for the gap between the motor on the bracket and use longer screws.
Sure thing - I agree - if you feel up to the challenge, then go ahead. I guess I am just aware that the notion of 'grinding' away at the BB has been raised a number of times, probably by less well equipped users when - for them - there are probably easier solutions. I missed mention of it being a customer's bike I'm afraid. Good luck,
Savvas.
izeman   100 GW
Post by izeman » Aug 31 2014 6:03am
thanks. i'll post pictures. all will be good in the end ;)
maxwell92036   100 W
Post by maxwell92036 » Aug 31 2014 2:24pm
A bike has a 73mm bottom bracket for a reason! If you grind off some width then the chainring might hit the chain stay. That is what would happen on my 73 mm bike. Do the install first before you take that drastic measure particularly with someone else's bike.
rolls   10 mW
Post by rolls » Sep 01 2014 6:20pm
rolls wrote: Totally agree about the service from Paul and Moon at em3ev. Top stuff!
I shouldn't have written that so early. Just after I posted that I went out to the bike, turned it on and gave the back wheel a quick spin with the throttle and hopped on to ride around the yard. Dead. Nothing from the PAS or throttle. The display was still on with no error messages. Every time I touch the throttle there is a faint click in the motor. Less than 20km on the kit.
Going by what others have posted in the BBS02 faults and fixes thread it seems the controller has spat it. 2 emails to Paul at em3ev so far, but no reply.
If it had have been a few '000km I would still have been a bit peeved, but less than 20km? Confidence is really shot with this POS.
joshseitz   100 W
Post by joshseitz » Sep 01 2014 11:13pm
Man that sucks. Mine is supposed to be arriving this Friday from EM3. Been waiting for months for this thing. If it craps out in the first day I am going to be VERY upset.
Anyhow....I am trying to do all of my prep and hardware store runs before the drive arrives on Friday in hopes that I can actually ride it that night.
Mine will also be installed on a 73mm BB shell. Can anyone instruct me on the length of M6 bolts required and how many washers/spacers you needed? I assume you all have just used stainless hex cap bolts? Thanks.
rolls   10 mW
Post by rolls » Sep 01 2014 11:21pm
After sending a few emails to em3ev I have just received a message from Moon. Paul can't answer my technical questions because he is on the way to the USA.
So much for going with a "trusted" supplier. I could be stuck for a while.
I should have gone with an AFT kit.
Raged   1 kW
Post by Raged » Sep 02 2014 1:00am
Check your ebrake isnt being engaged. (disconnect them altogether).
Focus Black Forest 29er - MAC10T 14S Lipo - 50km/h, 50km range. (dead)http://endless-sphere.com/forums/viewto ... 91&start=0
Cube Reaction 29er Cyclocross BBS02 http://endless-sphere.com/forums/viewto ... =6&t=70549
rolls   10 mW
Post by rolls » Sep 02 2014 1:15am
Raged wrote:Check your ebrake isnt being engaged. (disconnect them altogether).
I have hydro brakes, so I'm not using the ebrakes, but I hooked one up for a test. When I activated the ebrake I couldn't hear the click coming from the motor.
izeman   100 GW
Post by izeman » Sep 02 2014 2:26am
joshseitz wrote:Mine will also be installed on a 73mm BB shell. Can anyone instruct me on the length of M6 bolts required and how many washers/spacers you needed? I assume you all have just used stainless hex cap bolts? Thanks.
as this kit it supposed to go on a 68mm bb and you have 73mm you will need screws that are 5mm longer. stainless steel m6 hex will be fine. if you want it could measure the length of the supplied screws.
izeman   100 GW
Post by izeman » Sep 02 2014 2:31am
if it would really be an ebrake problem than there would be NO SOUND at all. ebrakes totally kill the motor. it may be something in the controller. i hope my kit won't suffer from your problem and i hope you get it solved soon.
paul is very helpful, and i can understand that you're upset that you don't get your answer immediately, but even i can't answer my mail on a journey or on a transcontinental flight. ;) give him some more time and he will solve that. worst thing that could happen is, that he will send you a new controller http://em3ev.com/store/index.php?route= ... uct_id=188 and you have to replace it.
BBS01 Controller1-250x250.jpg (28.86 KiB) Viewed 2373 times
problems that don't show immediately at initial testing are impossible to sort out for a supplier :(
