Index of non-hub motors used on E-bikes, specs & links
spinningmagnets   100 GW
Post by spinningmagnets » Sep 17 2014 7:44am
This is intended to be a quick reference of non-hub motors that have been used on E-bikes. Each motor listed will have a concise block of basic specs listed, and links to threads where in-depth discussion can take place, Any ES member can post to this thread, and useful info posted will be added to the index in this first post.
Specs template:
____________________________________________________
_____Diameter:
_______Length:
_______Weight:
___________Kv:
__Commutation: brushed or brushless
__Configuration: inrunner radial/outrunner radial/axial-flux
_Shaft diameter:
(I expect this to be quite messy for a while)
Axial-flux:
Agni-95R
ETEK-R http://www.robotmarketplace.com/products/ETK-ETEKR.html
Golden Motor 3-kW http://www.goldenmotor.com/
Golden Motor 5-kW
Golden Motor 10-kW
Mars brushless axial http://www.motenergy.com/brdcmo2.html
Perm PMG-132 http://robotmarketplace.com/products/EMS-PMG132.html
Inrunners:
GNG standard (67-Kv) http://endless-sphere.com/forums/viewto ... 25#p675568
GNG "Big Block" (36-Kv) http://endless-sphere.com/forums/viewto ... 07#p857584
Headline (used on Cyclone, AFT, EGO) http://endless-sphere.com/forums/viewto ... 58#p935458
Transmagnetics 4-inch diameter http://www.electricbike.com/nahbs-2014- ... mid-drive/
Transmagnetics 5-inch diameter
Transmagnetics 6-inch diameter http://endless-sphere.com/forums/viewto ... 5&p=859600
Transmagnetics http://www.transmag.com/
outrunners:
MAC/BMC 600W (used by Ecospeed) http://endless-sphere.com/forums/viewto ... 16&t=11772
Revolt 100 http://www.revolt.org.il/ __ http://endless-sphere.com/forums/viewto ... 30&t=58893
Revolt 120
Turnigy 80-100 (130-Kv, 180-Kv)
Turnigy 80-85 (170-Kv)
Feel free to post any motors that have actually been used on an E-bike, but are not yet listed (plus any detail info)...
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
_____Diameter:
_______Length:
_______Weight:
___________Kv:
_Shaft diameter:
kolby   10 mW
Re: Index of non-hub motors used on E-bikes, specs & links
Post by kolby » Sep 18 2014 12:49am
I've built a prototype friction drive with the following motor:
E-Flite Power 160 (http://www.e-fliterc.com/Products/Defau ... =EFLM4160A
Brushless 14 poles
245 kV
Shaft diameter 8mm
overall length 64mm
diameter 63 mm
I've put on about 100 miles in the first week and it works great with a cheap Turnigy 85A ESC.
I'm currently building a bracket like Adrian's CommuterBooster.
Cheers,
Michael
