Revolt Rv-120 pro/ norco aline Video teaser
boisrondevens   100 W
Post by boisrondevens » Oct 27 2014 4:43pm
Ok this is my new built. This built is all about stealthy , space management and look.
I only have access to the basic tools ( jigsaw, drill press ) no cnc or any other machinery.
The frame it's a norco aline 2009. The best feature about this bike frame is the removable dropouts.
I extended the swingarm to make room for the motor.
I use the rv-120 from revolt 45kV. I'm waiting for the max-e controller.
Nacent   10 mW
Re: Rv-120/ norco aline ( mid drive)
Post by Nacent » Oct 27 2014 5:14pm
Are you planning on having freewheel on the brake side and have only re-gen braking for the back wheel? or have a brake sprocket combo on your electric drive side?
Samd   1.21 GW
1.21 GW
Post by Samd » Oct 27 2014 6:21pm
Looks like a lot of fun! Nice mounting location.
http://ballaratebikes.com/
1KW   1 kW
Post by 1KW » Oct 27 2014 8:31pm
thats cool, the rv-100 doesn't look bad at all for a mid drive setup….
ARod1993   100 W
Post by ARod1993 » Oct 28 2014 8:12am
That's going to be pretty insane, especially given that the Adaptto should be able to give you 10kW peak and the motor's rated for around 15 peak, 5-7 continuous. Keep us updated!
Byte   1 kW
Post by Byte » Oct 28 2014 10:22am
Are that 2 brakes on the rear wheel?
boisrondevens   100 W
Post by boisrondevens » Oct 28 2014 5:08pm
Thanks.
So far the bike performers way beyond my expectations. like what the f... Is this THING!
I'm using a crystalyte 18fet stock, 100V 60amps.
The pedal side is on the left with a 16t freewheel.
For the motor side i use a 52t sprocket and for the beauty only i use a disk brake for the body part ( just look cool)
Videos soon...
Drum   100 W
Re: Revolt Rv-120/ norco aline ( mid drive)
Post by Drum » Oct 29 2014 1:32am
Awesome build! looks great. With that motor it should fly! Subscribed..
Are you using regen braking? If so, does it work well? ( I am asking because I am building something quite similar and plan to use regen braking).
What chain are you using?
boisrondevens   100 W
Post by boisrondevens » Oct 29 2014 2:04am
Thanks for the compliments!
You can't use regen on this drive because of the hub freewheel. The low kv make this motor ideal.
The bike is almost to scary to ride. With the batteries on my back pack, I only add 5 kilos to the bike with motor and controller. So verry lightweight compare to anything I have build so far. This motor can do 15000w peak so this is a completely different game.
Now I realy understand what Luke meant: choosing the right motor instead of adding transmission and gear to get performance.
I'm using normal bike chain for now, but I have a bmx chain for back up:twisted:
h0tr0d   1 kW
Post by h0tr0d » Oct 29 2014 2:26am
Great job, man! :wink:
Can you show more of the motor support (geometry, materials) and the chain tensioner?
And how is attached to the bike?
Thanks!
We want a video! :mrgreen:
Thank you Justin! Life is so much sweeter with this forum... ;)
Miles   100 GW
Post by Miles » Oct 29 2014 2:40am
boisrondevens wrote:I only add 5 pounds to the bike with motor and controller.
Are you sure about that? The motor alone is listed as weighing 4.3kg on the Revolt website.....
boisrondevens   100 W
Post by boisrondevens » Oct 29 2014 3:21am
Sorry 5 kilos Miles...
Miles   100 GW
Post by Miles » Oct 29 2014 3:32am
Ok! Thanks!
What size sprocket are you using on the motor shaft?
boisrondevens   100 W
Post by boisrondevens » Oct 29 2014 3:52am
Motor shaft: 11t
Rear wheel: 52t
gwhy!   1 MW
Post by gwhy! » Oct 29 2014 7:57am
boisrondevens wrote:Motor shaft: 11t
Rear wheel: 52t
so you are running 100v with a 45kv motor on a 26" wheel with a ratio of 11:52 if im understanding this correct :|
and the motor is happy is it i.e don't get hot :?:
ARod1993   100 W
Post by ARod1993 » Oct 29 2014 11:45am
Rear wheel: 52t
Here's my back-of-the-envelope calculation (please correct me if I'm full of BS):
According to Wolfram Alpha that would gear the bike up to about 73-74mph unloaded. Using Wolfram Alpha, the standard drag equation (Fd =0.5*Cd*A*p*V^2), and appropriate values for individual terms (effective frontal area (Cd*area) of 0.38m^2 taken from the abstract of this PubMed paper, 1.225 kg/m^3 as the density of air at sea level, and 33.1m/s (a little over 74mph) as the velocity), the drag force on the vehicle at 74mph is about 255N. That force is then acting over a radius of about 13 inches (assumes a 26-inch bike wheel), giving you a back torque on the wheel of 82.88Nm. Feed that through the 11/52 gearing you're using, and you get a back torque of about 17.5N*m on the motor. A motor with a KV of 45 requires about 4.72 amps per N*m of torque you want to put out, so you'll need about 80A or so to actually sustain the torque to overcome drag at that speed. That motor's rated for 60-80A continuous, maybe more, so it should be fine.
gwhy!   1 MW
Post by gwhy! » Oct 29 2014 12:26pm
ARod1993 wrote:
Rear wheel: 52t
:-) i just have my doubts about the 80a cont with a kV of 45
Miles   100 GW
Post by Miles » Oct 29 2014 12:56pm
ARod1993 wrote:Here's my back-of-the-envelope calculation (please correct me if I'm full of BS):
That seems fine. I used a loaded speed of 65mph in my spreadsheet and got a torque at the motor shaft of 14.2Nm. The motor weighs 4.3kg so that requires a specific torque of 3.3Nm/kg, which is believable....
RLT   10 kW
Post by RLT » Oct 29 2014 1:17pm
Great job. Very clean build.
You have made me re-think my whole approach to my RV-120 build.
What rear hub are you using?
Where did you get the 52 tooth sprocket?
Thanks.
boisrondevens   100 W
Post by boisrondevens » Oct 29 2014 1:39pm
That seems fine. I used a loaded speed of 65mph in my spreadsheet and got a torque at the motor shaft of 14.2Nm. The motor weighs 4.3kg so that requires a specific torque of 3.3Nm/kg, which is believable....[/quote]
Thanks again Miles!
I dont have any real numbers in term of top speed and temperature for now.
I did a ride with my friend Benoit last weekend and atfer the run is cromo was not really touchable and mine was warm to the touch.
I have made the 52t sprocket to fit the rear hub freewheel.
cycborg   1 kW
Post by cycborg » Oct 29 2014 4:05pm
boisrondevens wrote:I have made the 52t sprocket to fit the rear hub freewheel.
Looks like a 52t chainring bolted to a disc brake rotor? I wonder if you shouldn't flip it around so the rotor spokes are in tension rather than compression. What kind of hub is that with disc rotor mounts on both sides?
madin88   1 GW
1 GW
Post by madin88 » Oct 29 2014 4:22pm
wow, thats a badass middrive :)
do you know if Max-E works with this motor?
@ cycborg
it is fine that way the brake rotor installed ;) though i think it will not hold chain force..
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
Punx0r   100 GW
Post by Punx0r » Oct 29 2014 5:00pm
Only 255N drag at over 70mph? Very interesting - I would have guessed it would be much more than that.
I like the brake disc sprocket, very clever. Did you have to soften the metal to drill and tap it to attach the sprocket?
John Bozi   1 MW
Post by John Bozi » Nov 06 2014 3:08pm
What are the advantages over a hub motor with this build?
The unsprung weight is still there.
It would be easier to change your rear tyre I guess.
Can you pedal this bike? I cant see a chain
Warren   100 kW
Post by Warren » Nov 06 2014 3:42pm
John Bozi,
"The unsprung weight is still there."
The weight of the motor is barely unsprung. The center of the motor is about 4" from the swing arm pivot. The motor is moving up and down less than a quarter of the wheel travel. Plus the other benefits of better weight distribution and longer lasting wheels.
