Bafang BBSHD, 1000W, 68mm-120mm BB
robocam   10 kW
Re: Bafang BBSHD, 1000W, 68mm-120mm BB
Post by robocam » Oct 09 2016 2:16pm
You can be our guinea pig =) Did you have chainline issues before the Luna Eclipse? 42T is the minimum for that kind of offset (in order to clear the gear housing), so this 36T chainring will probably have the same or similar offset as the Mighty Mini. I guess I shouldn't really mind what my chainline is as long as the chain stays on in all the gears. I wonder if too much slant can cause teeth wear.
I wonder why your chain wasn't happy with the chainring. And you're sure the wide teeth were in the wide slots and the narrow teeth in the narrow slots?
I'm thinking about getting the OneUp 50T cog to go along with the 42T chainring. That will be almost the same as my 42 and 38 setup right now. But if that 36 turns out to be ok, I might want that instead =)
Another alternative is to drop down to 26" wheels from 29". A 42T on a 26" would be the same as a 38T on a 29".
Dogboy1200 wrote:
robocam wrote:Has anyone tried this 36T chainring on the BBSHD?
http://precialps.com/uk/accueil/31-plat ... uleur-noir
Wow! That looks sweet. Wonder what the offset is? Think I might have to try one. I'm currently running the Luna eclipse. I had some trouble with it at first. I had to shorten all the teeth a little so it wouldn't suck up my chain.
robocam   10 kW
Post by robocam » Oct 10 2016 11:57pm
I just found another option. You could use this Luna spider along with a 38T narrow wide chainring.
http://lunacycle.com/luna-bbshd-130bcd- ... g-adapter/
http://www.ebay.com/itm/J-L-Narrow-Wide ... _NTQeCjWRg
Lurkin   100 kW
Post by Lurkin » Oct 11 2016 3:40am
Pity they aren't making those for BBS01/02... very nice.
Samd   1.21 GW
1.21 GW
Post by Samd » Oct 11 2016 3:59am
Would be easy to do, albeit better in a 104bcd to suit that drive if thats what people want? Hey Lurkin will you be at Swinburne on Sunday?
http://ballaratebikes.com/
Lurkin   100 kW
Post by Lurkin » Oct 11 2016 4:12am
Highly likely work and hangover dependent.
Have you come across any Kingmeter J-Lcds in the shed by any chance? I've pretty much given up on the arduino display idea in favour of getting the beta cranking sooner than later. Don't care about condition/looks so long as it still works? 8)
tomjasz   1.21 GW
1.21 GW
Post by tomjasz » Oct 11 2016 4:28pm
Dogboy1200 wrote: Wow! That looks sweet. Wonder what the offset is? Think I might have to try one. I'm currently running the Luna eclipse. I had some trouble with it at first. I had to shorten all the teeth a little so it wouldn't suck up my chain.
There will be a big difference in chainline I believe. AND I've discovered that the Wippermann Connex "eBike" chains don't like to take up on a Narrow Wide chainwheel, no go on Race Face or any of the Luna products with the long teeth. I'm thinking a 36T will fit about like Luna's 30T. Bad chainline on all my bikes.
What chain was the problem for you?
Dogboy1200   100 W
Post by Dogboy1200 » Oct 11 2016 5:16pm
It was a KMC ebike chian X9e EPT. I had the chian on it right and everything was ok when it was clean and lubed but the slightest amount of dirt would make it wanna stay in the sprocket and it would get all jammed up between the sprocket and swing arm. I ground a little off each tooth with the bench grinder and that fixed it. I have had maybe 5 chian drops in 500 single track miles. The stock sprocket had the best chian line on my bike. With the eclipse I had to use the spacer, I was leery about this at first but nobody seemed to have any problems from that so I went with it. I think Woodlandhills had the same problem with sucking Chains.
2007 Transition Preston FR BBS02 https://endless-sphere.com/forums/viewt ... 28&t=73635 Now HD https://endless-sphere.com/forums/viewt ... &start=225
2006 KTM 250 XC-W
2005 crf50 stunt bike
Oset 12.5 (son's bike)
PW50 (son's bike)
Mongoose Kids Fat Bike BBS02 https://endless-sphere.com/forums/viewt ... =6&t=84133 https://endless-sphere.com/forums/viewt ... e#p1232034
robocam   10 kW
Post by robocam » Oct 11 2016 10:33pm
If you search eBay, you'll find many spiders available in 104, 110, and 130 BCD sizes (search BBS01 chainring adapter).
http://www.ebay.com/itm/California-Ebik ... Sw-kdX0IGF
Lurkin wrote:Pity they aren't making those for BBS01/02... very nice.
robocam   10 kW
Post by robocam » Oct 11 2016 10:35pm
The chainline might be too skewed with a 104BCD.
Samd wrote:Would be easy to do, albeit better in a 104bcd to suit that drive if thats what people want?
Lurkin   100 kW
Post by Lurkin » Oct 11 2016 10:41pm
I have and own a number already.
However the Luna one has an offset to it whereas the ones I have are exactly as you have linked to- cut from a flat piece of metal. Not ideal, doesn't fix things if the chainline is out, which is why I replaced it with an expensive, but super functional, Lekkie Ring.
Samd   1.21 GW
1.21 GW
Post by Samd » Oct 11 2016 11:13pm
The flat ones offset by the chainwheel sitting internal.
robocam   10 kW
Post by robocam » Oct 11 2016 11:30pm
Ah, I see what you mean now. Couldn't you offset the chainring by using chainring spacers?
Lurkin wrote:I have and own a number already.
Lurkin   100 kW
Post by Lurkin » Oct 12 2016 12:28am
There was a spacer provided with the adapter which makes the adapter protrude out from the motor unit, creating a gap for the chainring.
But this means the chainring will be where the original one was, rather than actually offsetting over the motor unit itself. The Lekkie actually puts the chain ring teeth in over the unit, the flat cut out adapter with spacer to allow it to work, does not. Hence the flat adapter allows a narrow wide to be used, but doesn't actually fix the problem I have - the chainline is out due to using a frame with 73mm BB. The Lekkie corrects this error as the Bafang BBS01 Gen 1 unit is designed to be used with a 68mm BB and is narrow wide. Win.
The Luna adapter is interesting because it looks like it will hang over the motor unit, exactly as a Lekkie ring does and will also allow the use of cheaper narrow wide rings. The offset over the motor is why it is interesting to me, rather than just the ability to use a narrow wide.
robocam   10 kW
Post by robocam » Oct 12 2016 12:55am
The Luna spacer is optional. If you don't use it, the Luna Eclipse provides an even greater offset than the Lekkie.
With a flat adapter, you can still make it hang over by using chainring spacers. You would place the spacers on the spider before you mount the chainring. Wouldn't that be the same as the Luna adapter?
I wish there was an affordable mid drive like this one where the chainrings are on the inside so that the chainline isn't messed up.
http://www.bikeebike.com/
Lurkin wrote:There was a spacer provided with the adapter which makes the adapter protrude out from the motor unit, creating a gap for the chainring.
robocam   10 kW
Post by robocam » Oct 12 2016 12:58am
Looks like California Ebike also has one available.
http://california-ebike.com/product/baf ... ter-hd130/
g725s   100 mW
Post by g725s » Oct 13 2016 11:04am
EDIT: Don't go by the picture of the chaining measurements below!!! Since I made this post I have found out that the measurements in the Luna video were wrong. If you go to the Luna knowledge base they have new measurements. Even though they still measure in an odd way, it's not perfect but probably +/- 1mm to 2mm accuracy
robocam wrote:Looks like California Ebike also has one available.
And Lunacycle.com has 2 chainring adapters available.
Luna does a youtube video where they measure from the faceplate(inside the chainring) to the outside of the inset or offset, whatever is best way to describe it. But they don't include the California Ebike chainring adapter, which I think has just about 1mm more inset than the Bafang Alloy chaingring adapter. So I think its amount of inset would be between the Bafang Alloy Chainring Adapter and the Lekkie:
Luna Youtube chainring video
sather   100 W
Post by sather » Oct 31 2016 8:19am
sather   100 W
Post by sather » Nov 13 2016 8:23pm
Here is a thread on modifying a BBSHD controller:
https://endless-sphere.com/forums/viewt ... 0#p1239980
Ebikes4Real states: "The standard BBSHD controller is fitted with pretty low end mosfets from the factory (P75NF...). Not the same IRFB3077 as come fitted in the 750W BBS02."
3077 mosfets are rated at 210amps and P75NF mosfets are rated at 80 amps.
fechter   100 GW
Post by fechter » Dec 10 2016 11:08pm
The software in the BBSHD will cut off power if the voltage gets above 60V. 14s is really the max.
sather   100 W
Post by sather » Dec 11 2016 11:56am
I was watching an EBR interview with Chris of Lectric cycles on you tube. He showed new Lekkie 34 tooth and 36 tooth chainrings for the BBSHD. I went on Lekkies website and I couldn't find them??? They are not on Lectric Cycles site either.
tomjasz   1.21 GW
1.21 GW
Post by tomjasz » Dec 12 2016 1:10pm
Coming to many soon, but they will have a chainline like the 30T. Once below maybe 40 there's no room for deeper offset if I'm measuring correctly. A alternative 30T would be nice. Especially without the narrow wide teethe so higher quality Connex eBike chains could be used. I see someone else got that surprise on electricbike.
tomjasz   1.21 GW
1.21 GW
Post by tomjasz » Dec 12 2016 1:12pm
Remember narrow wide rings won't run some Connex chains.
robocam   10 kW
Post by robocam » Dec 13 2016 3:59pm
Is that the same offset as the Lekkie?
sly74 wrote:If you would like improve your torque and keep a good speed the chainring 36T is a good compromise but the chainline is not perfect.
With this chainring the offset is 8mm
sly744   1 mW
Post by sly744 » Dec 15 2016 2:30pm
Example of mounting the Bafang BBSHD on a Santacruz V10 with a chainring 42T "narrow wide"
sly744   1 mW
Post by sly744 » Dec 15 2016 2:32pm
Zoom on the chainring
