Bafang BBSHD, 1000W, 68mm-120mm BB
eMax   100 W
BBS02-HD 1,000W
Post by eMax » Aug 29 2015 2:33pm
Just got back from Eurobike and had some words with Bafang regarding service, new products and improvements which can be made the the existing products.
New 1000w nominal motors incoming in 68mm, 100mm and 120mm. 12 FET controllers I believe. Its definitely a shame for Doug & Cali ebike and other dealers who are doing the 100mm conversions. The motor was a fair bit chunkier than the existing designs and also heavier. New displays also.
Riding LMX Freeride and eMax Edi 27.5 Prototype
eMax eBikes - Australian Based Electric Bike Sales & R&D
Ade   100 W
Re: New Bafang Crank-Drives
Post by Ade » Aug 29 2015 3:09pm
eMax wrote:Just got back from Eurobike and had some words with Bafang regarding service, new products and improvements which can be made the the existing products.
Did they give any clue when the new motor would be available?
Nakamura bigbob 4.0 Fatbike with (Luna) 120mm BBSHD and 14ah shark pack with QA cells.
tomjasz   10 GW
Post by tomjasz » Aug 29 2015 4:01pm
eMax wrote: Its definitely a shame for Doug & Cali ebike and other dealers who are doing the 100mm conversions. The motor was a fair bit chunkier than the existing designs and also heavier. New displays also.
I'll bet he knew his design would be copied. After all, It was all open source, and freely sold. It's the copy cats that will feel the burn with lower prices. Doug remains the same uber reliable shop and online source for parts, support, and motors with warrantees in the USA. Paul at EM3ev mentioned his relationship with Cali eBikes. A master machinist engineer coupled with the arguably most influential BBS0x dealer. Cali eBikes and EM3ev is one heck of a force.
Cell_Man wrote, "Also watch this space for the new 100mm conversion we'll be offering in the next 2 or 3 weeks (EM3ev and Calififornia Ebike collaboration), with other lengths to follow. We're working with Doug to make a cheaper conversion kit, that is also much easier to modify an existing kit."
Winning combination!
opperpanter   100 W
Post by opperpanter » Aug 31 2015 12:58pm
Ade wrote:
1boris wrote:Anybody knows more about this bafang bbs motor.it says 160nm!
http://www.szbaf.com/en/components/comp ... 350dv.html
Wow, finally, a stock 100mm+ BBS and not only that, but more powerful too - and are those funky cooling fins I see....
So, extrapolating from what I see on the motors page, this is a replacement for the BBS02 750W; http://www.szbaf.com/en/components/motor.html
It says 130-150rpm, which is 20rpm up from the 500W version. Will need in mini tiny chain ring to make it work optimal and will be difficult to peddle along?
toxictoad   1 W
1 W
Bafang Mid-Drive for 120mm BB Fat Bikes - BBSHD
Post by toxictoad » Sep 03 2015 7:39am
Happy to see that Bafang have produced a mid-drive unit for a fat bike with a 120 mm BB - http://electric-fatbike.com/2015/09/01/ ... iant-fins/
I've been looking into getting an e-kit for my fatty most of this year and the closest I got was with the Bafang 190 mm rear hub motor http://fatbike-motor.com/ but I really wanted the mid-drive to fit my 120 mm BB. Just gotta wait til they release it now.
Something that has come up before and I haven't found the answer to, is when they say 36v - 48v. Does it mean that it will run from a 36v battery?
On here http://www.szbaf.com/en/components/comp ... 350dv.html they say 'Nominal Voltage: 36/48v, Rated Power: 750-1000w. Does this mean a 36v battery will provide power up to 750w and a 48v battery will be needed to give power over 750w-1000w?
Thanks
KINNINVIEKID   1 kW
Re: Bafang Mid-Drive for 120mm BB Fat Bikes - BBSHD
Post by KINNINVIEKID » Sep 03 2015 8:36am
It will be 2 different motors,same as the current 36v and 48v models
BBSHD on 2017 Marin Muirwoods
BBS02 on Cannondale Trail 6
Dillenger 1000 watt front wheel kit on Trax TFS1 MTB.
250 watt chinese scooter!
Cyclamatic Power Plus 250 watt road bike.
spinningmagnets   100 GW
Post by spinningmagnets » Sep 03 2015 8:44am
There has been (and will continue to be) a wide variety of power levels programmed into the different kits inside the controllers. For instance, the power limit across "most" European Union nations is 250W, but...I believe Switzerland has a 500W power limit. Most of the USA has a 750W power limit, but I have been told that the state of Oregon has a 1000W power limit.
Watts are "volts times amps". 500W can be easily achieved with both 36V and 48V by varying the maximum amps that the controller is allowed to use.
lcrewse   100 mW
Post by lcrewse » Sep 03 2015 8:37pm
Lectric Cycles will be releasing information at Interbike about our newest e-RAD drive units that will be available in the coming months. We are already testing them and working out the kinks before they go into full production. The new HD motors will be in addition to the drive units we have that are already compatible with BB sized 68-110mm including the various Press Fit standards. With over 50 dealers in the USA, and various manufacturer partners, there will be a lot of the e-RAD HD Drive units on the road very soon.
Lectric Cycles
www.lectriccycles.com
jk1   1 kW
Post by jk1 » Sep 04 2015 12:48am
What is the motor radius in the BBS02 ?
And what is the KV of the motor ?
And also what is the internal gear reduction ratio?
I am just wondering what the Magnet speed mm per second is at the cranks and how it compare to other kits like the LR ?
which is like 13,400 mm per second at 48v.
tomjasz   10 GW
Post by tomjasz » Sep 04 2015 9:24am
Some guys just love blowing their horns.
sather   100 W
Post by sather » Sep 04 2015 10:43am
I hope Bafang redesigns the mechanical parts of the new 1000 watt instead of just reusing the old BBS01 design. The 750 watt BBS02 uses the same mickey mouse plastic gear and clutch as the 350 watt. It left me stranded many miles out in the mountains. I chose to de tune my BBS02 to 500 watts to keep from having more problems. Doug Snyder at California e-bike has fantastic customer service. He turned my defective BBS02 around in 1 day!!
tomjasz   10 GW
Post by tomjasz » Sep 04 2015 2:54pm
sather wrote:I hope Bafang redesigns the mechanical parts of the new 1000 watt instead of just reusing the old BBS01 design. The 750 watt BBS02 uses the same mickey mouse plastic gear and clutch as the 350 watt. It left me stranded many miles out in the mountains. I chose to de tune my BBS02 to 500 watts to keep from having more problems. Doug Snyder at California e-bike has fantastic customer service. He turned my defective BBS02 around in 1 day!!
We're all hoping better quality control happens. Good choice in vendors. Everything I've done with Doug has been peerless. Several BBS01's, and 3 hub drives through him have made me a loyal customer. The additional costs working with Doug come back in spades! Other USA dealers have not been as helpful and never as quick to respond and solve problems. Fact is mid drives are more finicky. Still my favorite motors but they are a bit more maintenance. For many users, who aren't dedicated wrenchers, cali ebikes is a score! And for those who can do their own work the parts turnaround is as fast as 2-3 day mail service. Beats the pants off China and really not that expensive once you factor ALL the China direct costs. Not to mention what happens with a problem.
bgt   10 W
Re: Bafang BBS-HD, 1000W, 68mm-120mm BB
Post by bgt » Sep 05 2015 6:20am
The 1000W drives have a whopping 160Nm torque..........................awsome!!!!
Bike: Batavus Mamboo
Motor: BBS02B-500W
Battery: 2x 20Ah/36V Dolphin
Folding Bike: Batavus Intro Versa + another 1
Motor: BBS01-250W...........2 off.
Battery:
Post by spinningmagnets » Sep 16 2015 8:46pm
Some pics from Interbike:
2015-09-16 10.46.34.jpg (100.8 KiB) Viewed 5344 times
2015-09-16 10.46.46.jpg (134.14 KiB) Viewed 5344 times
2015-09-16 10.47.03.jpg (117.35 KiB) Viewed 5344 times
allthingstech   1 µW
Post by allthingstech » Sep 17 2015 12:24am
First time I've seen the chain wheel side, Is that going to be standard that weird looking cover? I can only imagine its there to help the alignment issues that the earlier BBS02 had or for more strength? So you have ridden a prototype of this 1000w...What were your impressions? Any more info would be great...Will you be getting a unit to review soon?
Ade   100 W
Post by Ade » Sep 17 2015 2:51am
allthingstech wrote:First time I've seen the chain wheel side, Is that going to be standard that weird looking cover? I can only imagine its there to help the alignment issues that the earlier BBS02 had or for more strength? So you have ridden a prototype of this 1000w...What were your impressions? Any more info would be great...Will you be getting a unit to review soon?
I don't think it's a cover - it's the chainring. And yes, it's fugly indeed. I guess the 3rd party chainrings like the Lekkie will fit, if not, I'm sure someone will start making them.
speedmd   100 MW
Post by speedmd » Sep 17 2015 8:17am
From the looks of the cases, they put the controller on the other side and have the gearing all on the same side. If so, that would be a big structural improvement IMO. Any talk on ca adaptability or secondary controller/ tweeks. They need to allow access to at least a few simple programming /options. Having to see the dealer is just not going to cut it.
rsilvers   1 kW
Post by rsilvers » Sep 17 2015 8:47am
Unless you are putting these motors on a $149 or cheaper Walmart bike, it seems like an adaptor with an aftermarket chainring is needed just for acceptable looks.
Since these can't shift under power, and since they have no shift-sensor, what is the best way to shift these? Shimano internal geared hub? NuVinci?
Merlin Titanium XTR, Mac 10T, 48v 820Wh, CA V3.
speedmd   100 MW
Post by speedmd » Sep 17 2015 9:55am
I don't think the look of the ring is bad at all and who says you can't shift them under power. You can slam them all day long. Sturdy chain is a must. Don't sound pretty if you don't feather or brake lever it a bit but my bbso2 works just fine on my nine speed setup under full power! If you time it right it feels like a mx bike. :P Di setup may even be much better. Most Internal hubs are borderline at these torque levels. Check out Keplers shift lever switch if you can not master a smooth shift.
Post by spinningmagnets » Sep 17 2015 9:59am
I have had a fondness for Internally Geared Hubs (IGH), and a couple of years ago there was a great deal of discussion about using these as a transmission, and how much power they can take. For a BBS01, an IGH is a wonderful option. For the 750W BBS02, it depends on the "soft start" programming and which IGH you are using.
For the BBS-HD, I would never recommend any IGH. They would break with the tooth-loading being so high.
rsilvers   1 kW
Post by rsilvers » Sep 17 2015 10:48am
Good to know.
It seems like one needs to budget $100 for one of these:
http://www.lectriccycles.com/gear-sensor/
tomjasz   10 GW
Post by tomjasz » Sep 18 2015 8:22am
The Gearsensor models will soon be available from other vendors. My personal favorites, EM3ev and California eBikes will have them.
As an add on without the link to the controller, I think most will be disappointed. We tested them more than a year ago.
Wait until you can have a link to the controller, not the braking system.
When you see what you get for $100 you'll be disappointed. But that vendor gouges anyway. $81 for a $33 battery base($33 with $10 shipping)
I understand vendors need good markups but, seriously $75 for a $15 item that sells for a bit less than that wholesale. Why not support customers with reasonable markups?
https://endless-sphere.com/forums/viewt ... or#p911717
Samd   1.21 GW
1.21 GW
Post by Samd » Sep 26 2015 11:48pm
Hope someone can confirm the bcd of the chainwheels. Hopefully the same as current.
That chainwheel looks bloody ugly.
http://ballaratebikes.com/
Lurkin   100 kW
Post by Lurkin » Sep 27 2015 2:14am
looks aside, I would love to know the offset on that chainring.. perhaps my eyes are deceiving me, but looks like its a greater offset than the current standard chainring offers. Hopefully a cheaper solution to those currently using more expensive options, I'd be the first lining up for one if the offset is greater.
