Bafang BBSHD, 1000W, 68mm-120mm BB
DaDo.Bzz   100 W
Re: Bafang BBS-HD, 1000W, 68mm-120mm BB
Post by DaDo.Bzz » Sep 29 2015 4:34pm
160Nm, ordering in Jan. definitelly! Hope Lekkie will fit and every 2000km new chain and casette. ;))
LMX 81, 16S6P 60A
BBS02 on Cannondale Rz 120
BBSHD on CTM Scroll, XTR Di2, 700Wh 52V
Slovakia, Bratislava
o00scorpion00o   100 kW
Post by o00scorpion00o » Sep 30 2015 8:27am
Whatd speed do you think this 1000 W motor would be good for ?
Haibike EQ Trekking, powered by Bosch.
DaDo.Bzz   100 W
Post by DaDo.Bzz » Sep 30 2015 3:50pm
o00scorpion00o wrote:Whatd speed do you think this 1000 W motor would be good for ?
55-60 kmh
LMX 81, 16S6P 60A
speedmd   100 MW
Post by speedmd » Sep 30 2015 4:03pm
Do we know what rpm the crank spins at 48 -50 volts on the 1kw. My 750w feels like it runs out of gearing before power at just over 30 mph on 12s lipo running a 48/12T in a 26"mtb setup. Would think this would be the same with a bit higher speed possible then the bbs2 going up hills.
Post by o00scorpion00o » Sep 30 2015 4:29pm
Thanks.
DaDo.Bzz   100 W
Post by DaDo.Bzz » Oct 04 2015 6:04pm
according Paul on stock in 2 weeks!
LMX 81, 16S6P 60A
Ade   100 W
Post by Ade » Oct 05 2015 1:16pm
DaDo.Bzz wrote:according Paul on stock in 2 weeks!
But still waiting to hear first hand accounts of how this motors rides....
Nakamura bigbob 4.0 Fatbike with (Luna) 120mm BBSHD and 14ah shark pack with QA cells.
luna5k   100 µW
100 µW
Post by luna5k » Oct 06 2015 12:49am
Nathan   10 W
Post by Nathan » Oct 06 2015 7:04am
Interesting review but it seem quite heavy over 5kg for only a 1kw continuous motor ? My cyclone 48v 1680w continuous weighs less then that and has nearly double the power and nearly 3000w peak !
Also its dam expensive around 1200 usd thats like 3 times the price of my cyclone kit with that money would rather get the Upgraded AFT cyclone 1680w :
https://endless-sphere.com/forums/viewt ... 28&t=72792
luna5k   100 µW
100 µW
Post by luna5k » Oct 06 2015 7:12am
In fact the price for the kit in the review (as configured here http://www.lectriccycles.com/e-rad-1000 ... rsion-kit/) is closer to $2300.
I really can't afford that, so I hope one of the other sellers can do a lot better.
KINNINVIEKID   1 kW
Post by KINNINVIEKID » Oct 10 2015 3:37pm
BBSHD on 2017 Marin Muirwoods
BBS02 on Cannondale Trail 6
Dillenger 1000 watt front wheel kit on Trax TFS1 MTB.
250 watt chinese scooter!
Cyclamatic Power Plus 250 watt road bike.
brumbrum   100 kW
Post by brumbrum » Oct 10 2015 4:21pm
KINNINVIEKID wrote:Look what I just found on ebay!!!
http://www.ebay.co.uk/itm/2016-BAFANG-B ... 4d398ae238
25amp? I'm feeling a bit short changed. Is this not just the bbs02 in an woolly jacket?
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
cev   10 mW
Post by cev » Oct 10 2015 5:07pm
On Luna site the specs are different.
http://lunacycle.com/motors/bafang-mid- ... drive-kit/
KINNINVIEKID   1 kW
Post by KINNINVIEKID » Oct 10 2015 6:44pm
I think that may just be a typo as they are 30 amp.
Interestingly they do NOT list it on their own website though!
cev   10 mW
Post by cev » Oct 11 2015 8:57pm
Its also listed as the BBS03 as opposed to the BBSHD.
I already ordered mine so I will find out what it can really flow soon.
LyonNightroad   100 W
Post by LyonNightroad » Oct 19 2015 11:28am
I am surprised this isn't getting more attention, pretty exciting. I am not thrilled with the $800 price @ luna but I imagine that will go down eventually.
Ade   100 W
Post by Ade » Oct 19 2015 1:12pm
LyonNightroad wrote:I am surprised this isn't getting more attention, pretty exciting. I am not thrilled with the $800 price @ luna but I imagine that will go down eventually.
It will get more when it's actually available and people start putting it on their bikes.
jk1   1 kW
Post by jk1 » Oct 19 2015 11:14pm
I think the reason is its quite expensive for the power it has and heavy .
for half that price you can get the 48v 1680w (3000w peak) cyclone that is twice power and 1kg lighter !
or for around the same price get the 1680w AFT if you want better quality and twice the power if the BBS03.
Ade   100 W
Post by Ade » Oct 20 2015 5:11am
Cyclone is not so plug and play and who really knows the quality of the BBS03/BBS-HD?
The spec for the BBS03 says it rates at 150/160 Nm - what are the Cyclone and AFT rated at?
TorEddy   100 W
Post by TorEddy » Oct 20 2015 10:20am
I think the BBSHD is going to be my next kit, after my LR kit was stolen from me.
I'm really excited for it, but then i found this page, with a wish list of upgrades.
http://electric-fatbike.com/2015/09/24/ ... #more-2155
I totally agree on the low reduction and torque sensing points.
These things seems hard to modify.
cev   10 mW
Post by cev » Oct 20 2015 11:41am
I am hoping that everything that can be done on the BBS02 is possible on this one. Hopefully it is unlocked and we can edit the maximum current on the controller.
40-45amps will be great if the nylon gear doesn't grenade.
I went with a 26f battery pack which will give me a bit of head room if current can be modified.
Putting together the kit wasn't that expensive, it only cost like 1400 dollars.
With a 20ah battery and some accessories.
speedmd   100 MW
Post by speedmd » Oct 20 2015 1:11pm
They should also have stronger gear options (even if they make more noise) for aggressive off roaders. The plastic gears should be ok for light duty riding if designed correctly for the heat and torque. Agree, Torque sensing is a must as is easy programming options.
TorEddy   100 W
Post by TorEddy » Nov 01 2015 7:37am
Ade   100 W
Post by Ade » Nov 02 2015 6:01am
Wow, that Lunacycles chainring is just insane. :D Want one.
speedmd   100 MW
Post by speedmd » Nov 02 2015 8:45am
The solid sprocket looks cool, but I would like to see something like it with a replaceable sprocket section. You could use a steel sprocket that would not weigh much, last a long time, and be easy to make given that it is the consumable item in the assembly.
