Transmagnetics 4-7Kw Motor
evolutiongts   10 kW
Post by evolutiongts » Jun 02 2015 3:23pm
Finally my motor has arrived took about a 1 month since its a custom wind from the factory. Mid drive single speed.
Very light 8lbs. Very narrow 3inch wide. Custom wound for 5000RPM @96V. 4-7Kw. This will be replacing the big block. Comes stock with 10awg phase wires. Motor is pre-drilled and comes with internal cooling fan.
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
nutnspecial   1.21 GW
1.21 GW
Re: Transmagnetics 4-7Kw Motor
Post by nutnspecial » Jun 02 2015 4:22pm
Oh damnit the rest of us are just getting the bht goin! :o
Why is probably my biggest question. Besides the apparent smaller width, what are the benefits/details?
Ps, it looks hotter than a june bride in a feather bed!
evolutiongts   10 kW
Post by evolutiongts » Jun 02 2015 4:58pm
nutspecial wrote:Oh damnit the rest of us are just getting the bht goin! :o
Better cooling, this is going to be for track duty. BHT was overheating after 5 laps, 4950w burst.
Transmagnetics has higher continous power, higher RPM, internal cooling fan, slightly lighter. More power. And dead sexy. Custom wind for my application.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
bzhwindtalker   1 MW
Post by bzhwindtalker » Jun 02 2015 8:25pm
Price? I'd love to try one in a LMX frame. Or watercool the BHT :D
DanGT86   10 kW
Post by DanGT86 » Jun 02 2015 8:52pm
Any idea what the lamination thickness is? Looks like a nice width to work with.
duffmanaudio   1 W
1 W
Post by duffmanaudio » Jun 02 2015 8:57pm
What controller are you gonna use & are you gonna put your pedals on. I am just about done my cx project & don't really like my motor. It looks like this would be a direct replacement
evolutiongts   10 kW
Post by evolutiongts » Jun 03 2015 1:17am
duffmanaudio wrote:What controller are you gonna use & are you gonna put your pedals on. I am just about done my cx project & don't really like my motor. It looks like this would be a direct replacement
I am currently using the BHT motor in my mongoose CX its almost perfect but not enough top end for me.
Motor costed $450 but its custom wind for track use. 5000RPM @96V
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
speedmd   100 MW
Post by speedmd » Jun 03 2015 8:17am
Thanks for posting this. How much torque? What is the kv and do you have any plots showing its performance? You got our interest. :shock: Looks to be perfect for a light weight build.
evolutiongts   10 kW
Post by evolutiongts » Jun 03 2015 9:30am
speedmd wrote:Thanks for posting this. How much torque? What is the kv and do you have any plots showing its performance? You got our interest. :shock: Looks to be perfect for a light weight build.
This is for their 5" motor, @48V. Mine's is custom wound for 5000rpm at 96V.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
speedmd   100 MW
Post by speedmd » Jun 03 2015 1:13pm
Looks to be torque enough to go direct to rear wheel in a single stage reduction. 52 kv (5000/96) would yield aprox. 500 wheel rpms at a 6:1 reduction and 72 volts. Just over 40 mph with a average size wheel if my math is correct!
evolutiongts   10 kW
Post by evolutiongts » Jun 03 2015 3:07pm
I'm gearing for 50mph top speed
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
zombiess   100 MW
Post by zombiess » Jun 03 2015 3:15pm
evolutiongts wrote:I'm gearing for 50mph top speed
If you have a controller with field weakening you could gear a bit lower and use the field weakening to extend the top speed for straight away use. This would provide more acceleration due to the shorter gearing. Just tossing it out there as an option.
With 50 MPH top end (no field weakening) and +7kW the acceleration should be pretty good.
evolutiongts   10 kW
Post by evolutiongts » Jun 03 2015 3:46pm
Thats a good idea, I have one of your sabvoton controllers and it should pair well with the transmagnetics motor. 10awg phase wires as stock.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
neptronix   100 GW
Post by neptronix » Jun 03 2015 3:50pm
Damn, that's an impressive little motor for the size and weight. I'm glad you finally got your hands on one. What did it involve?
I'm thinking that this would be real nice for a slower speed e-motorcycle conversion.
evolutiongts   10 kW
Post by evolutiongts » Jun 03 2015 6:43pm
neptronix wrote:Damn, that's an impressive little motor for the size and weight. I'm glad you finally got your hands on one. What did it involve?
A lot of emails, phone calls, and a check. This would be even more powerful than the BHT motor.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
nutnspecial   1.21 GW
1.21 GW
Post by nutnspecial » Jun 03 2015 7:15pm
I'm curious how much more power it is really capable of?
6kw for bht or transmag geared to the same speed- we know the weight, size, and cooling go to the transmag!
Simply staying cooler will result in more energy to the wheel. . .
It'll be very exciting to see you put it thru the paces op! Any eta on the new motor mount and gearing being ready?
crossbreak   100 MW
Post by crossbreak » Jun 03 2015 9:43pm
as always, we need Rm and Kv/Kt to determine "how much" motor there is. Miles (guess so) defined this constant to compare motors of different Kv and Rm on their ability to produce torque. It's Km = Kt/sqrt(Rm)
in terms of acceleration: It all depends on phase current limit. I would rather disclaim field weakening. Instead i'd go for a slightly bigger controller and higher KV. Battery current will stay the same, but you gain better high speed efficiency (i think). I really dont get what field weakening may be good for as controller loss is so small even for low duty cycles (i think)
speedmd   100 MW
Post by speedmd » Jun 04 2015 8:24am
Speaking of KV, I am wondering what the stock winding of this motor is. It may be a very good starting place for many builds depending on sprocket availability.
Miles   100 GW
Post by Miles » Jun 05 2015 3:24am
crossbreak wrote: Miles (guess so) defined this constant to compare motors of different Kv and Rm on their ability to produce torque.
Nio it's not my constant! :)
Ref: http://control.com/thread/1026217558
Practical use of the motor constant Km.pdf
(72.75 KiB) Downloaded 169 times
speedmd   100 MW
Post by speedmd » Jun 12 2015 8:18pm
Noticed today the "build your own" option on the site and the segmented stator laminations. Nice!
evolutiongts   10 kW
Post by evolutiongts » Jun 14 2015 2:18pm
First test runs
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
neptronix   100 GW
Post by neptronix » Jun 14 2015 2:31pm
I can tell from spinning up many motors over the years... that that thing has some serious kick to it for it's size.
Excited to see what will come of it :)
evolutiongts   10 kW
Post by evolutiongts » Jun 14 2015 2:38pm
neptronix wrote:I can tell from spinning up many motors over the years... that that thing has some serious kick to it for it's size.
Oh yeah this motor is going on the mongoose, gearing for 50-60mph. Just need to fab up the motor mounts.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
iartem   10 µW
10 µW
Post by iartem » Jun 15 2015 4:32am
THAT looks really great! Looking forward for a build.
